Total immobilization - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2006, 04:09 PM   #1 (permalink)
David J
Guest
Posts: n/a
View David J's Photo Gallery
You are going on vacation for two weeks, leaving your cherished car on
the drive. You don't want to get home and discover that the local
scumbags have helped themselves and your car is gone.
In past times past you could easily remove the rotor arm from the
distributor, which generally stopped opportunist thieves. What would
folks do on a modern car that is guaranteed to beat a car thief.
Old 02-24-2006, 04:44 PM   #2 (permalink)
Art
Guest
Posts: n/a
View Art's Photo Gallery
Re: Total immobilization
If you have a late model car it probably cannot be started without the right
key. Many keys have a chip in them. That is why thieves resort to
carjacking and towing. Put it in a garage.
"David J" <david@btelecom.invalid> wrote in message
news:da0vv19g0oi7fblausl96dj3k71oa51n3n@4ax.com...[color=blue]
> folks do on a modern car that is guaranteed to beat a car thief.[/color]
Old 02-24-2006, 04:44 PM   #3 (permalink)
Mike Hunter
Guest
Posts: n/a
View Mike Hunter's Photo Gallery
Remove the Microprocessor? ;)
mike hunt
Old 02-24-2006, 04:55 PM   #4 (permalink)
Sharx35
Guest
Posts: n/a
View Sharx35's Photo Gallery
"Art" <begunaNOSPAMPLEASE@mindspring.com> wrote in message
news:7%LLf.3199$S25.1167@newsread1.news.atl.earthlink.net...[color=blue]
> right key. Many keys have a chip in them. That is why thieves resort to
> carjacking and towing. Put it in a garage.[/color]
Finally, something sensible from you. One shouldn't have a good vehicle if
they can't afford to PROPERLY garage it, most of the time.
[color=blue]
> news:da0vv19g0oi7fblausl96dj3k71oa51n3n@4ax.com...[color=green]
>[/color]
Old 02-24-2006, 05:17 PM   #5 (permalink)
Bonehenge
Guest
Posts: n/a
View Bonehenge's Photo Gallery
On Fri, 24 Feb 2006 22:09:13 +0000, David J <david@btelecom.invalid>
wrote:[color=blue]
> What would
Insure it.
Old 02-24-2006, 05:21 PM   #6 (permalink)
The Benevolent dbu
Guest
Posts: n/a
View The Benevolent dbu's Photo Gallery
In article <7%LLf.3199$S25.1167@newsread1.news.atl.earthlink.net>,
"Art" <begunaNOSPAMPLEASE@mindspring.com> wrote:
[color=blue]
> > folks do on a modern car that is guaranteed to beat a car thief.[/color][/color]
Yes, an immobilizer key. A clever device. You might ask how does it
work, how does it get power as the key does not have a battery.
"Welcome to President Clinton, Mrs. Clinton, and my fellow astronauts."
Al Gore
Old 02-24-2006, 05:53 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
In order from simple to difficult, you can try
EFI main fuse
battery
Access the fuel pump and unplug it
steering wheel (follow airbag precautions!)
ECU
starter
driveshaft (s)
transmission
engine
Be aware that NOTHING is GUARANTEED to beat a car thief. Disabling the car
will discourage thieves but will not absolutely make it theft proof. Even
if you removed everything I listed above, all a determined thief has to do
is use a tow truck to get the car.
Ray O
Old 02-24-2006, 05:57 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
"The Benevolent dbu" <relaxan.d@smeltherose.comm> wrote in message
news:relaxan.d-D91428.17205724022006@news-rdr-01.rdc-kc.rr.com...
<snipped>
[color=blue]
> --[/color]
When you insert the key in the ignition, it is very close to the
transponder...
Ray O
Old 02-24-2006, 06:22 PM   #9 (permalink)
The Benevolent dbu
Guest
Posts: n/a
In article <22d1d$43ff9e1e$44a4a10d$20749@msgid.meganewsservers.com>,
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
> <snipped>
>[color=green]
> > --[/color]
> transponder...[/color]
But how does it get it's power to operate?
Here is a clue: [url]http://www.spybusters.com/Great_Seal_Bug.html[/url]
It cannot be compromised. The crook needs to take apart the dash and
then know which wires to connect. Forget it crooks.
Al Gore
Old 02-24-2006, 09:40 PM   #10 (permalink)
mark_digital©
Guest
Posts: n/a
View mark_digital©'s Photo Gallery
A For Sale sign and a large oil puddle.
Old 02-24-2006, 09:52 PM   #11 (permalink)
Viperkiller
Guest
Posts: n/a
View Viperkiller's Photo Gallery
On Fri, 24 Feb 2006 17:53:22 -0600, "Ray O"
[color=blue]
>EFI main fuse
>battery
>ECU
>starter
>driveshaft (s)
>transmission
>engine
>is use a tow truck to get the car.[/color]
I'm with Art & Sharx35 on this one. It's more effective to garage the
vehicle. Besides, it's more salubrious to the vehicle.
Old 02-25-2006, 06:46 AM   #12 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Fri, 24 Feb 2006 22:40:05 -0500, "mark_digital©"
<976XXX@nospam.net> wrote:
[color=blue]
>[/color]
ROFL
Maybe put it up on blocks, too?
Scott in Florida
Old 02-25-2006, 07:57 AM   #13 (permalink)
mark_digital©
Guest
Posts: n/a
"Scott in Florida" <MoveOn@outa.here> wrote in message
news:4ck002p83b23scbppfq133md51ku4ah753@4ax.com...[color=blue]
>[color=green]
>>news:da0vv19g0oi7fblausl96dj3k71oa51n3n@4ax.com...[color=darkred]
>>[/color]
> ROFL
> Scott in Florida[/color]
If I did that the town would tow it away. Not a good idea.
Old 02-25-2006, 03:33 PM   #14 (permalink)
RT
Guest
Posts: n/a
View RT's Photo Gallery
wrote:
[color=blue]
Bump the fuel cut-off switch to trigger it so the fuel pump will shut
off. They won't be able to start it.
Old 02-25-2006, 08:12 PM   #15 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
"mark_digital©" <976XXX@nospam.net> wrote:
[color=blue]
>[/color]
....and let the air out of a couple of tires...
-Gord.
(use gordon in email)
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota reports December and year-end sales Bakemono Toyota News 9 01-12-2006 04:05 PM
transmission oil initial fill and total fill celica2004 Camry & Solara Lounge 3 10-10-2005 09:39 AM
total loss assesment?? snobdrblinkchik General Discussion 13 09-17-2004 07:02 PM
Total Electrical System Failure sargeusmc57 Camry & Solara Lounge 0 12-21-2002 03:55 PM
