Re: 05 Matrix - no overdrive OK?
"catmandude" <churchillfields@comcast.net> wrote in message
news:1140831602.098284.34780@z34g2000cwc.googlegroups.com...[color=blue]
> I'm new here. Just got a used 05 Matrix XR w. 4 spd. auto transmission.
> It says in the manual to always use overdrive to boost gas mileage and
> reduce noise. I mostly drive in urban settings, and it seems driving
> w/out the overdrive offers a little more responsive. Am I right, or
> deluding myself? Will this harm the engine or transmission. Any idea on
> the hit it will cause on fuel efficiency?
> Thanks in advance.
> Ted
>[/color]
Driving with the overdrive disabled will improve responsiveness at the
expense of fuel efficiency, especially when driving at steady speeds at 30
MPH or higher. The engine will operate at higher RPM with the OD off so you
will get more wear and tear and lower fuel economy. The effect on fuel
economy really varies with your driving conditions and driving style. The
most accurate way to tell is for you to do your normal routine for a couple
of tanks with the OD off and then a couple more with the OD on and compare.
BTW, I would not routinely downshift from 4th to 3rd to provide engine
braking as that will quickly wear down the friction surfaces in the
transmission. It is a lot less expensive to replace brake pads than tear
down a transmission to replace friction surfaces.
Ray O
