Need to know where the 2000 Sienna O2 Oxygen sensors are - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-26-2006, 10:25 AM   #1 (permalink)
QuienEs
Guest
Posts: n/a
View QuienEs's Photo Gallery
1/ Check engine light came on.
2/ Private mechanic let me hook up his gizmo to read out what the
problem was.
3/ Readout was something like this [from memory, but the B1S1 is
accurate for sure]
B1S1 O2 SENSOR
B1S1 SHORT or OPEN IN HEATER CIRCUIT
4/ I paid $211 for the part, + labor. He reset the check engine
light with the code reader gizmo.
5/ Now, maybe 50 miles later, the check engine light is back on.
6/ Can anyone point me to a resource on the net which tells or shows
the locations of all 3 or 4 sensors, B1, B2, S1 and S2 ?
I was unable to find same with Google. The mechanic said he knew
B1S1 was the one in the middle of the exhaust manifold, closest to the
radiator, "by experience". I fear he was mistaken.
7/ A good online source of sensors would be welcome too - my plan is
the buy the right one at a discount and have him
put it in for free. I doubt he will be able to take the newly
installed one back for refund.
TIA, QE in NJ
Old 02-26-2006, 01:31 PM   #2 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
Re: Need to know where the 2000 Sienna O2 Oxygen sensors are
B1 refers to the cylinder bank that the sensor resides in. Bank 1 always
contains cylinders 1,3,5, and so on. Bank 2 has 2,4,6, etc. In your sienna
bank 1 is the bank in the rear of the engine compartment. The way to
determine this is by looking at the intake runners. The first runner will
go either left or right to cylinder #1. Follow the first runner and you
will see which side bank 1 is. This rule follows for all engines I've
worked on.
S1 or S2 refers to the location of the sensor relative to the catalytic
converter. Sensor 1 is in front of the cat, sensor 2 is behind. Thats
about it.
So anyway, if the code was B1S1, then your technician replaced the wrong
sensor. You should be looking at the one in the rear exhaust manifold.
Old 02-26-2006, 02:46 PM   #3 (permalink)
QuienEs
Guest
Posts: n/a
Thank you qslim for the great, clear lessons. I have heard other
ones but theseare the 1st ones I could really understand.
Cheers, QE in NJ
On Sun, 26 Feb 2006 14:31:48 -0500, "qslim" <Suckers@suckersdotcom>
always
sienna
will
you
|worked on.
catalytic
|about it.
wrong
manifold.
BB code is Off
Smilies are Off
[IMG] code is Off
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Error code 21 O2 heated Oxygen Sensor failure pkmorreira 89-95 Toyota Pickup/Hilux 11 02-05-2011 03:02 PM
2000 Echo - O2 sensor failure Ashla Yaris, Vitz and Echo Forum 4 03-15-2006 03:48 PM
O2 (Oxygen) Sensors - Replacing spup345 Camry & Solara Lounge 2 06-14-2005 05:07 PM
