Removing door panel? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-28-2006, 11:57 AM   #1 (permalink)
Herb
Guest
Posts: n/a
View Herb's Photo Gallery
I have an 89 Corolla that has te rear window stuck about 2 inches from
the closed position.
Using the handle,it just clicks as if the window mechanism is stuck.
I'd like to check it,but don't know how to rmove the handle and door
panel.
Any help would be appreciated. This group has helped me out many times.
Thanks
Old 02-28-2006, 12:32 PM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: Removing door panel?
look for screws in the door handles and the door latch, and along the bottom
of the panel as well, although there may not be any there.
Either go to AutoZone or CarQuest or ? and get a tool to remove the clip
from the window handle. you can use the rag method (get a shop rag and wrap
it under the window handle and work it back and forth until the retainer
pops off), or just get a flat screwdriver or needlenose and reach behind and
pry the clip off. Watch it; they have a tendancy to fly...
Check for screws on more time, grab the bottom of the door panel and pull
gently. The plastic clips will release, than work it over the lock.
Since it's an '89, you may break some of the plastic clips; these can be had
anywhere. If you pry gently enough you may not break any.
Good luck!
"Herb" <herb777@webtv.net> wrote in message
news:17885-44048F25-1375@storefull-3355.bay.webtv.net...[color=blue]
> panel.
> Thanks
>[/color]
Old 02-28-2006, 06:55 PM   #3 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
There is a metal panel remover that auto parts places sell for maybe $6 that
makes it easy and prevents damage. It has a hook like projection for
removing the window winder U clip. You can also use a shoe string to remove
it. Make sure the door opener trim screw is removed, it should slide
forward and out and arm rest screws. The using the tool or a putty knife go
around the door panel and pop the catches --- mayne 12 of them total. Once
panel is off you can gently remove the clear plastic moisture shield. Have
some grease ready for the window mechanism.
> panel.
> Thanks
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 06:53 PM
Help! Removing rear tail light assmbly on 1993 Corolla! winks Archived Corolla threads 10 03-03-2007 01:55 PM
Removing Lenses Illegal in CA? OneMnk 2nd Generation (2005+) 9 02-02-2006 03:46 PM
Removing EGR system White89SR5 Archived Corolla threads 1 12-21-2005 11:11 PM
removing the pinstripe bowlofturtle Camry & Solara Lounge 17 06-19-2004 02:38 PM
