92 tercel a/c question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-01-2006, 06:34 PM   #1 (permalink)
phil11@bp.com
Guest
Posts: n/a
View phil11@bp.com's Photo Gallery
I have a 92 tercel dx, and the a/c stopped working. I pulled the right
hand kick panel for the fuse, but need a little more direction for
location. Is it stored in one of the "holes" behind the panel? Thanks
for any help.
Old 03-01-2006, 06:51 PM   #2 (permalink)
timbirr@mailcity.com
Guest
Posts: n/a
View timbirr@mailcity.com's Photo Gallery
Re: 92 tercel a/c question
[email]phil11@bp.com[/email] wrote:[color=blue]
> for any help.[/color]
I don't remember. If you get no answer here, odds are your local
library has a Haynes or Chilton for that model with the information.
Old 03-01-2006, 06:54 PM   #3 (permalink)
phil11@bp.com
Guest
Posts: n/a
Thanks. I will check into that as well.
Old 03-01-2006, 07:29 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
<phil11@bp.com> wrote in message
news:1141259670.698036.223200@z34g2000cwc.googlegroups.com...[color=blue]
> for any help.
>[/color]
You did not mention whether you have a right hand drive or left hand drive
Tercel.
The fuse for the AC (if there is one) will be either in the fuse box under
the driver's side of the dash board or under the hood. The AC system
probably has a circuit breaker instead of a fuse.
Does the compressor engage when you turn on the AC? If the refrigerant has
leaked out of the system, then the compressor will not engage. If the
compressor engages, look for a round sight glass on the receiver/drier
mounted in front of the radiator and condenser. If you see foam in the
sight glass, then you need a refrigerant recharge.
Ray O
Old 03-01-2006, 09:37 PM   #5 (permalink)
phil11@bp.com
Guest
Posts: n/a
Sorry. left hand drive, US model.
BB code is Off
Smilies are Off
[IMG] code is Off
92 tercel died mknisley Tercel, Paseo, Starlet, and Sera Forum 12 08-10-2006 12:31 AM
A/C Question - Low Pressure Port noteworthyone General Discussion 2 06-15-2005 11:42 AM
A question regarding A/C TOYOTA CARS Camry & Solara Lounge 14 06-10-2005 04:00 PM
Help finding Flasher Unit (92 Tercel) notmyown Tercel, Paseo, Starlet, and Sera Forum 2 02-20-2005 06:57 PM
