More 2000 Sienna O2 Oxygen sensors questions. Qslim ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2006, 08:55 AM   #1 (permalink)
QuienEs
Guest
Posts: n/a
View QuienEs's Photo Gallery
Van is 2000 Sienna w/California emissions, made 07/2000 -
engine is 1MZ-FE,
Looked around underneath and found one O2 sensor between the cat and
the engine, and one after the cat, toward the rear of the van.
I've spent a lot of time online and with online vendors' help ppl and
received somewhat contradictory information about what will do the
job.
2 questions:
1/ Are there actually TWO O2 sensors between the cat and the engine -
vendors' sites seem to suggest this - saying "2 required" ? As above,
I saw only one [towards the passenger side] but wasn't looking for a
2nd one at the time.
2/ I am a electronics buff and ham-radio operator who would have no
trouble doing the cut and splice wiring job required to install the
much less expensive Bosch Universal sensor[s]. Does anyone know if
they will work with the Calif. emissions engine ?
TIA, QE in NJ
Old 03-03-2006, 09:35 AM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: More 2000 Sienna O2 Oxygen sensors questions. Qslim ?
"QuienEs" <QuienEsREMOVETHIS@ANDTHISatt.net> wrote in message
news:v8lg021gi37nv9vb9gj47jipcc9khb6fbi@4ax.com...[color=blue]
> engine is 1MZ-FE,
> job.
> 2 questions:
> 2nd one at the time.[/color]
There should be ONE upstream and ONE downstream, two total.
[color=blue]
> TIA, QE in NJ[/color]
Yeah, they work. You may not get the mileage you're accustomed to, or you
may not be as clean at inspection as you were before, but they will work.
I use thim in 20 YO Celicas and Tercels when I want them to *JUST* pass
emissions. If the van is a beater and you're thinking of sending it to the
wrecker's in a year or two, buy the Bosch. It won't HURT (I used one in a
'95 Tercel; $30 at the CarQuest I was working at). But if I had the $$$, I'd
go OEM.
Old 03-03-2006, 10:34 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> engine is 1MZ-FE,
> job.
> 2 questions:
There is one O2 sensor per bank between the cat and the engine. On a V-6
engine with 2 banks, you would have 2 O2 sensors before the cat.
[color=blue]
I have no experience with Bosch universal sensors so I can't comment on how
they work, but if you are going to try one, I suggest cutting the pigtail
off of the old sensor and splice it to the new sensor so that you don't mess
with the harness to the ECU. You then have the option of going back to a
factory O2 sensor without any problems.
Ray O
Old 03-03-2006, 11:25 AM   #4 (permalink)
QuienEs
Guest
Posts: n/a
Thanks Ray, read 2 comments below interspersed with your text. QE
On Fri, 3 Mar 2006 10:34:16 -0600, "Ray O"
|> engine is 1MZ-FE,
and
and
|> job.
|> 2 questions:
engine -
above,
a
V-6
I read that to mean that besides the Air/Fuel sensor [ which is very
visable] on the exhaust manifold close to the radiator there is an O2
sensor somewhere on that manifold or whatever it becomes on its way to
the cat, that I have not yet discovered - will look when wife returns
home with the van. Thanks. Info on Bosch universals below.
no
if
|> TIA, QE in NJ
|on how they work, but if you are going to try one, I suggest cutting
|the pigtail off of the old sensor and splice it to the new sensor so
|that you don't mess with the harness to the ECU. You then have the
|option of going back to a factory O2 sensor without any problems.
Not having seen one, you guessed it anyway :-) !! That's exactly how
they work. Here's a link to the installation guide for Bosch
Universals, which sell online for less than $70 delivered.
[url]http://www.boschusa.com/images/OxygenSensorInstall.pdf[/url]
QE
Old 03-03-2006, 11:27 AM   #5 (permalink)
Hachiroku
Guest
Posts: n/a
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:df078$4408700e$44a4a10d$29653@msgid.meganewsservers.com...[color=blue]
> news:v8lg021gi37nv9vb9gj47jipcc9khb6fbi@4ax.com...[color=green]
>> engine is 1MZ-FE,
>> job.
>> 2 questions:
>[color=green]
> how they work, but if you are going to try one, I suggest cutting the
> pigtail off of the old sensor and splice it to the new sensor so that you
> don't mess with the harness to the ECU. You then have the option of going
> Ray O
>[/color]
He also has to obey the color codes and make sure Signal and Ground are
wired correctly; the two white wires on the Bosch are the pre-heater and are
wired into the heater wires on the connector. I can't remember the codes
right now, but i think I googled it, IIRC.
Old 03-03-2006, 11:34 AM   #6 (permalink)
QuienEs
Guest
Posts: n/a
Thanks for the info and anecdotes Hachiroku - not sure exactly what
upstream and downstream mean - I think you mean before [upstream] and
after [downstream] the cat - if this is wrong further explanation
would be welcome.
Cheers, QE
|> engine is 1MZ-FE,
and
and
|> job.
|> 2 questions:
engine -
above,
a
no
if
|> TIA, QE in NJ
you
work.
pass
to the
in a
$$$, I'd
|go OEM.
Old 03-03-2006, 12:48 PM   #7 (permalink)
Hachiroku
Guest
Posts: n/a
news:1cvg02lu6e0ess6qfeq0e5kie857up5ecf@4ax.com...[color=blue]
> would be welcome.
> Cheers, QE
> =======================[/color]
Yup! That's it!
[color=blue]
> |> engine is 1MZ-FE,
> and
> and
> |> job.
> |> 2 questions:
> engine -
> above,
> a
> no
> if
> |> TIA, QE in NJ
> you
> work.
> pass
> to the
> in a
> $$$, I'd
> |go OEM.
>[/color]
Old 03-03-2006, 01:33 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
news:tuug02l0h9uo7fnh4d7efgsb3iaipakl82@4ax.com...[color=blue]
> |> engine is 1MZ-FE,
> and
> and
> |> job.
> |> 2 questions:
> engine -
> above,
> a
> V-6
> home with the van. Thanks. Info on Bosch universals below.[/color]
Think of an engine bank as an independent engine - in other words, in a V-6
engine, you would have two 3-cylinder engines that are connected at the
bottom. Each of the two engines/banks has two O2 sensors.
O2 sensor #1 is closest to the engine and measures the amount of oxygen in
the exhaust and vehicle's electronic control unit (ECU) adjusts how much
fuel gets mixed with the air based on what the O2 sensor is telling it.
O2 sensor #2 is after, or downstream of the catalytic converter. It is also
measuring the oxygen in the exhaust and is basically there to make sure that
the cat is doing its job. If the cat is not cleaning up the exhaust, then
O2 sensor #2 would sense it and let the ECU know.
Each cylinder bank has O2 sensor #1 and O2 sensor #2. Besides the O2 #1
sensor visible in the exhaust manifold near the radiator (Bank 2), there is
another one in the exhaust manifold near the firewall (bank 1).
As far as i know, there is not a 3rd one in the system, unless that is
something new.
[color=blue]
> no
> if
> |> TIA, QE in NJ
> QE
>[/color]
Check your local Toyota dealer for the price of an OEM O2 sensor. I may be
wrong, but I don't think they are that much more than an aftermarket one.
Good luck!
Ray O
Old 03-03-2006, 02:09 PM   #9 (permalink)
Hachiroku
Guest
Posts: n/a
news:b2a6e$44089abf$44a4a10d$31401@msgid.meganewsservers.com...[color=blue]
> news:tuug02l0h9uo7fnh4d7efgsb3iaipakl82@4ax.com...[color=green]
>> |> engine is 1MZ-FE,
>> and
>> and
>> |> job.
>> |> 2 questions:
>> engine -
>> above,
>> a
>> V-6
> V-6 engine, you would have two 3-cylinder engines that are connected at
> the bottom. Each of the two engines/banks has two O2 sensors.
> also measuring the oxygen in the exhaust and is basically there to make
> sure that the cat is doing its job. If the cat is not cleaning up the
> exhaust, then O2 sensor #2 would sense it and let the ECU know.
> is another one in the exhaust manifold near the firewall (bank 1).
> something new.
>[color=green]
>> no
>> if
>> |> TIA, QE in NJ
>> QE
>>[/color]
> be wrong, but I don't think they are that much more than an aftermarket
> one.
> Good luck!
> Ray O
>[/color]
Last I knew, the Bosch's were running anywhere from $19 to $149, and the
OEMs were around $135-175 on the ones I have checked.
Old 03-03-2006, 05:35 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
"Hachiroku" <Trueno@ae86.GTS> wrote in message
news:ao1Of.25$ky1.14@trndny06...[color=blue]
> news:b2a6e$44089abf$44a4a10d$31401@msgid.meganewsservers.com...[color=green]
>> news:tuug02l0h9uo7fnh4d7efgsb3iaipakl82@4ax.com...[color=darkred]
>>> |> engine is 1MZ-FE,
>>> and
>>> and
>>> |> job.
>>> |> 2 questions:
>>> engine -
>>> above,
>>> a
>>> V-6
>> in the exhaust and vehicle's electronic control unit (ECU) adjusts how
>> much fuel gets mixed with the air based on what the O2 sensor is telling
>> it.
>> something new.
>>[color=darkred]
>>> no
>>> if
>>> |> TIA, QE in NJ
>>> QE
>>>[/color]
>> one.
>> Good luck!
>> Ray O
>>[/color]
> OEMs were around $135-175 on the ones I have checked.[/color]
I guess it's been a while since I checked on O2 sensor prices!
Ray O
Old 03-03-2006, 08:58 PM   #11 (permalink)
njmodi
Guest
Posts: n/a
View njmodi's Photo Gallery
Actually, even the Bosch Universal sensors are fairly expensive for the
Sienna...
[url]https://www.automedicsupply.com/catalog4.php?PHPSESSID=f46a0986cb417976b6c1b4b6ce1e6fdd[/url]
For those prices, I'm guessing you can probably buy an OEM Toyota
replacement.
Cheers,
Nirav
Old 03-04-2006, 08:16 AM   #12 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
Sorry i didn't get back to you yesterday, Quienes, I was out of town. If
you have a Cali emnissions vehicle, then the sensor in your exhaust stream
is very different than a regular oxygen sensor. They are called air/fuel
ratio sensors, and there are fundemental differences in how they work in
their construction the circuit to the ECM in the vehicle. I don't have any
experiences with aftermarket AF sensors, but if you go with a Bosch or
other brand you should do your research and make sure that they
specifically say their unit is compatible with your car.
Expect to pay a bit, too. OEM AF sensors are about 240$ (at least at my
dealer ship). We always see the rear bank on your sienna go first and more
often than the front. I guess it has something to do with the heatbuildup
back there while running.
Old 03-04-2006, 08:28 AM   #13 (permalink)
Scott in Florida
Guest
Posts: n/a
View Scott in Florida's Photo Gallery
On Sat, 04 Mar 2006 09:16:11 -0500, "qslim" <Suckers@suckersdotcom>
wrote:
[color=blue]
>back there while running.[/color]
I wonder if a simple air duct to the sensor might make them last
longer?
Scott in Florida
Old 03-05-2006, 02:25 PM   #14 (permalink)
QuienEs
Guest
Posts: n/a
If
stream
air/fuel
in
have any
or
at my
more
heatbuildup
Thanks Qslim for the above information, which has finally solved a lot
of confusion. Since the code readout device my tech used said
"B1S1 O2 sensor" all my searching around for pricing etc has been
for *oxygen* sensors. Having looked at the Toyota box I can see that
the one he replaced in the front by mistake was an AF sensor, p/n
89467-41011, as in the one he took out, per numbers around the
thimble. So I have an extra, good used one for some day
in the future. Next week I think I'll bite the bullet and spring for
an OEM AF sensor for the rear bank - because he made a mistake 1st
time around, he isn't going to charge me labor for what looks like a
bear of a job. Should it turn out to have the same p/n [not likely]
we'll just put the new one from the front in the rear and the old one
back in the front.
It has been a real pleasure receiving your on-target advice, thank
you again and keep up the good work in this ng.
QE in NJ
BB code is Off
Smilies are Off
[IMG] code is Off
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Error code 21 O2 heated Oxygen Sensor failure pkmorreira 89-95 Toyota Pickup/Hilux 11 02-05-2011 03:02 PM
2000 Echo - O2 sensor failure Ashla Yaris, Vitz and Echo Forum 4 03-15-2006 03:48 PM
Oxygen Sensors grumpy Tercel, Paseo, Starlet, and Sera Forum 8 11-07-2005 11:46 PM
O2 (Oxygen) Sensors - Replacing spup345 Camry & Solara Lounge 2 06-14-2005 05:07 PM
