Oil in the Antifreeze, but no Antifreeze in the Oil! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-03-2006, 07:49 PM   #1 (permalink)
72Capri
Guest
Posts: n/a
View 72Capri's Photo Gallery
Ok I have a 1990 Toyota Corolla Wagon, 1.6L EFI 5 speed. We (dad and I)
recently hauled the engine out to put a different one it upon realizing
that it was not all the same. So the antifreeze that came out of the
engine that came out of our car, had a skim of Oil on the top, and the
over flow bottle was about 25% Oil and 75% antifreeze. SO we didn't know
why this was, the car ran fine, there was no antifreeze in the Oil, and
there was no signs of a head gasket gone.
So we change the antifreeze and put the motor back in (This was the
first day of September) I was under the hood of the car poking around
making sure everything was doing great. And I pulled the Top off of the
Overflow bottle, and was surprised to find that again I had Oil in
there.so we took the rad cap off, and there was a small amount in there as
well. But again no Antifreeze in the Oil. and no signs of a blown head
gasket. and the car works great.
Does anybody know what might be the problem?? because oil in the
anitfreeze can't be overly good for the car?
Old 03-03-2006, 08:08 PM   #2 (permalink)
timbirr@mailcity.com
Guest
Posts: n/a
View timbirr@mailcity.com's Photo Gallery
Re: Oil in the Antifreeze, but no Antifreeze in the Oil!
72Capri wrote:[color=blue]
> there was no signs of a head gasket gone.[/color]
If this car has an oil/water heat exchange, that is often the cause.
Don't know if does, tho.
Old 03-04-2006, 01:03 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"72Capri" <corolla1990@hotmail.com> wrote in message
news:7a4f59738ffb356863a3c073226e21bd@localhost.talkaboutautos.com...[color=blue]
> anitfreeze can't be overly good for the car?[/color]
If the oil you are seeing in the antifreeze is motor oil, then the
possibilities are a head gasket leak, warped or cracked head, and cracked
engine block. The only way to tell for sure is to remove the head. It is
possible for oil to contaminate the antifreeze without antifreeze getting
into the oil.
Ray O
Old 03-05-2006, 12:22 PM   #4 (permalink)
72Capri
Guest
Posts: n/a
Yeah but if this were to happen (Cracked/Warped Block, Warped/Cracked Head,
Or Head Gasket, The car wouldn't run as well as it does?
Old 03-05-2006, 07:54 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:18959dfd2195347a375b6130fadc1324@localhost.talkaboutautos.com...[color=blue]
> Head,
>[/color]
I don't know how well the car runs, but a driveability problem will not
necessarily be evident if the coolant and oil are not getting into the
combustion chambers. In other words, a cracked block, warped or cracked
head, or leaking head gasket will not necessarily make the engine run
poorly. A warped engine block is not a likely event.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
HELP! Ran without oil due to leak Jakelukas Camry & Solara Lounge 4 08-14-2005 12:33 AM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 12:36 PM
? Bad Oil Pump Gen2 1989 2.0L ? mk3glx 1st & 2nd Generation (1983–1986 & 1987-1991) 1 10-21-2004 10:48 AM
