Re: CT-20 turbo questions
"jeffellisatwork" <jeffellisatwork@gmail.com> wrote in message
news:1141483305.978535.165410@p10g2000cwp.googlegroups.com...[color=blue]
>I have a 1986 Toyota 22R-TE with a CT-20 turbo that has blown out. I
> am having trouble finding a rebuilt turbo to replace it.[/color]
If yours cannot be rebuilt due to lack of parts, then any similar sized and
flow rate turbo can be used, with whatever adapting modifications are
necessary. Have you enquired at the local turbo shop about having your's
rebuilt?
[color=blue]
> Does anyone know of a way to remove the turbo
> and keep the engine running with decent power?[/color]
Yes, update the head to increase the compression from the current approx 7.8
to 9.5 or so, replace the cams with ones more suitable for a normally
aspirated engine, and change the engine management system. In other words,
completely change the engine. Its cheaper to do the above replacement turbo
route.
There's no cheap way to take the turbo off and expect the engine to run
normally.
Stewart DIBBS
