stereo compatability - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-04-2006, 06:49 PM   #1 (permalink)
roake
Guest
Posts: n/a
View roake's Photo Gallery
I've got an 03 toyota echo with a basic am-fm stereo. Is a stereo from a
scion (am-fm-cd) compatable with my echo?
Old 03-04-2006, 06:59 PM   #2 (permalink)
Mike Hunter
Guest
Posts: n/a
View Mike Hunter's Photo Gallery
Re: stereo compatability
Sure, as long as you just intent to mount it under the dash somewhere.
mike hunt
"roake" <kandrharris@citynet.net> wrote in message
news:293e3864744f2968547be20310a276ee@localhost.talkaboutautos.com...[color=blue]
>[/color]
Old 03-04-2006, 07:17 PM   #3 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
On Sat, 04 Mar 2006 18:49:54 -0500, roake wrote:
[color=blue]
> scion (am-fm-cd) compatable with my echo?[/color]
For a real answer, yes, it should be plug-compatible, so you can just plug
it in.
Now, whether it is MODEL specific...It may require some 'modification' to
the face plate; I doubt a Scion faceplate will work.
They are ALL DIN or Double-DIN, so it will fit the alloted space in the
dash.
In the grand scheme fo things...
What difference does it make?
Old 03-06-2006, 01:33 AM   #4 (permalink)
andynewhouse@yahoo.com
Guest
Posts: n/a
View andynewhouse@yahoo.com's Photo Gallery
> Is a stereo from a scion (am-fm-cd) compatable with my echo?
Crutchfield.com has a good system for checking what stereos are
compatible with your car, so by entering both cars into their system,
you should be able to figure out whether they're the same size/fit/etc.
You can also get adapter plates/plugs/etc from them, but unless you
buy their stereo from them also, the adapters are pretty pricy, if I
recall correctly.
Andy
Old 03-08-2006, 12:17 AM   #5 (permalink)
Viperkiller
Guest
Posts: n/a
View Viperkiller's Photo Gallery
On Sat, 04 Mar 2006 18:49:54 -0500, "roake" <kandrharris@citynet.net>
wrote:
[color=blue]
The Scions use an 8" wide faceplate. If yours is the same width, then
it will go in. Your radio could be the older 7" wide faceplate
though. The plugs in the back are the exact same.
BB code is Off
Smilies are Off
[IMG] code is Off
*DIY* Stock Stereo LED color change - (Lots of PICS) - 56k no way SnakeyeS Camry & Solara Lounge 56 12-09-2010 03:51 AM
97 Camry LE V6 stereo questions xfactor Audio, Video, and Security - Tech 2 02-09-2006 01:52 AM
Gen 5.5 Factory Stereo sasair 5th & 6th Generation (2002-2006 & 2007-2011) 9 11-24-2005 05:34 PM
