Toyota corolla.. engine oil problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2006, 10:22 AM   #1 (permalink)
jag
Guest
Posts: n/a
View jag's Photo Gallery
Hi,
I recently purchased a used 2000 toyota corolla VE 61K, got all the
oils flushed and refilled. But after about 15 days there was no engine
oil in it. It was completely empty. I took it to firestone and he did
not tell me what the problem was he just filled the engine oil again.
But again after about 10 days the oil was completely empty. I took the
car to firestone near my house(a different one than the previous one)
he said there is no oil in the car, he checked for leaks, etc and said
he dosent know where the oil is going!!!!
He told me keep an eye on it and check the oil regulary.
any Ideas as to what is going on with my toyota corolla??
Thanks guys
Jag
Old 03-05-2006, 11:31 AM   #2 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: Toyota corolla.. engine oil problem
On 5 Mar 2006 07:22:37 -0800, "jag" <jagsjunk@gmail.com> wrote:
[color=blue]
>any Ideas as to what is going on with my toyota corolla??[/color]
No clue - but it has to go somewhere, it doesn't just disappear.
It's either leaking oil (which can be seen), burning oil (which can be
seen at that high a rate) or it's getting into another system (cooling
most likely).
You might want to check the history of the car - if it belonged to a
courier service for the first five years, the odometer might have been
rolled back from 300K to 61K some time before it was sold to you.
Was the car previously leased? Did the seller provide any service
records? If they never changed the oil you might have a "sludged"
engine full of muddy dirty oil, and that will wreck them internally.
People have been known to lease a car and turn it back in four years
later with the factory fill oil still in the crankcase.
Or while I'm guessing, here's an odd but possible one - the Positive
Crankcase Ventilation system is wonky, and it's blowing the oil up and
out the dipstick... (Hey, Weird Happens.)
Park the car over clean butcher paper or a plastic tarp - it will
show the drips and roughly where they are coming from. Check the
radiator for signs of oil.
Clean off the outside of the engine and the underside of the car so
you can see any external leaks, but be very careful with a pressure
washer to not force water into any electrical connectors or the
alternator or starter motor. It's possible that it only leaks under
pressure while running, but that type of leak will get oil on the
underside of the car.
And check the oil level once daily till you have a handle on how
fast it's going away - oil is cheap compared to a new engine because
it ran dry. If this is a family car, have only one person do it so
it's consistent. Keep a log book. And check it with the car parked
on a level surface, if your driveway is sloped more than a few degrees
that will affect the dipstick read.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 03-05-2006, 01:28 PM   #3 (permalink)
Alex
Guest
Posts: n/a
View Alex's Photo Gallery
If you have no leaks, check you plugs. My 95 1.8 has one or more valve
seals sucking oil in cylinder 4. I add a quart each 500 miles or so. It's
not too common, but easy to google.
"jag" <jagsjunk@gmail.com> wrote in message
news:1141572157.072394.207470@v46g2000cwv.googlegroups.com...[color=blue]
> Hi,
> I recently purchased a used 2000 toyota corolla VE 61K, got all the[/color]
Old 03-05-2006, 03:04 PM   #4 (permalink)
Pretty Boy
Guest
Posts: n/a
View Pretty Boy's Photo Gallery
Maybe not to firestone again. How about jiffy lube or something.
Suggestions from Bruce is worth trying if you to DYI.
Old 03-05-2006, 03:15 PM   #5 (permalink)
High Tech Misfit
Guest
Posts: n/a
View High Tech Misfit's Photo Gallery
Pretty Boy wrote:
[color=blue]
> Suggestions from Bruce is worth trying if you to DYI.[/color]
Don't go to Jiffy Lube either. Find a reputable private mechanic who
specializes in Japanese cars.
Old 03-05-2006, 03:25 PM   #6 (permalink)
Mark A
Guest
Posts: n/a
View Mark A's Photo Gallery
"Pretty Boy" <prettyboy988-google@yahoo.com> wrote in message
news:1141589077.348891.283940@i40g2000cwc.googlegroups.com...[color=blue]
>[/color]
Do not go to Jiffy Lube. Go to a locally owned oil change place (some
franchises are locally owned). Grease Monkey franchises are locally owned
and usually very good if you can find one in your area.
Old 03-05-2006, 08:46 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"High Tech Misfit" <me@privacy.net> wrote in message
news:uvl21hw6hj56.dlg@hightech.misfit...[color=blue]
> Pretty Boy wrote:
>[color=green]
> specializes in Japanese cars.[/color]
Toyota dealer service departments do know something about Corollas ;-)
If the leaks are coming from the front of the engine, check the timing chain
tensioner.
Ray O
Old 03-06-2006, 05:37 PM   #8 (permalink)
wenmang@yahoo.com
Guest
Posts: n/a
View wenmang@yahoo.com's Photo Gallery
When my car had 35K on it, it had the same problem. There was no smoke
or any visible leaking underneath, but the engineer oil kept
disappearing. Toyota dealer did re-build engine twice, finally fixed it
under warranty. My Corrola is also 2000 VE, and now it has 144K on it,
no leaking of engine oil ever since.
BB code is Off
Smilies are Off
[IMG] code is Off
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 12:48 PM
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 07:20 PM
How do you warm up your car? kenratboy General Discussion 64 09-06-2007 12:20 AM
In hybrids, it's Toyota vs. the world EKam Toyota News 2 03-27-2005 09:04 PM
92 Camry V6 engine problem..HELP Toy hilux 3rd & 4th Generation (1992–1996 & 1997–2001) 2 07-28-2004 05:15 PM
