Musty A/C Odor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-05-2006, 12:34 PM   #1 (permalink)
Savalas
Guest
Posts: n/a
View Savalas's Photo Gallery
Musty A/C Odor
Hello all, I have a problem that maybe someone in these groups can help me
with. I not too long ago got my A/C working on my '90 Camry DX, 3SFE engine
with over 280,000 miles on the odometer. If I had known all was needed was
to have the system charged I would have done it 5 years ago instead of
driving around in the heat of Houston. Anyway, when I run the A/C for a
while and cut off the engine for like a day or a few hours and start it
again, there is a musty odor that comes from the vents. I asked my mechanic
about it and he said that it was most likely the evaporator which probably
had mold growing inside it from the moisture build up from the A/C running.
He said that on cars old as mine that they werent serviceable. There has got
to be some way of killing the odor and mold. I have sorta solved the problem
by just leaving the vent open and opening the windows and try to dry the
moisture out a while before I cut off the car. If anyone knows of some way
of solving this problem please let me know. It will be much appreciated.
Old 03-05-2006, 02:15 PM   #2 (permalink)
Stewart DIBBS
Guest
Posts: n/a
View Stewart DIBBS's Photo Gallery
Re: Musty A/C Odor
"Savalas" <thegaffler@yahoo.com> wrote in message
news:UiFOf.19910$n%2.526@tornado.texas.rr.com...[color=blue]
> Anyway, when I run the A/C for a while and cut off the engine for like a
> day or a few hours and start it again, there is a musty odor that comes
> from the vents.[/color]
The usual recommendation is buy a spray can of Febreeze and give all the the
vents a good squirt, and leave it overnite. If its really bad, you may have
to take the evaporator fan shroud off (if its accessible) and squirt the
fins directly.
May take several applications.
Stewart DIBBS
Old 03-05-2006, 02:59 PM   #3 (permalink)
Gary L. Burnore
Guest
Posts: n/a
View Gary L. Burnore's Photo Gallery
Re: Musty A/C Odor
On Sun, 5 Mar 2006 14:15:35 -0500, "Stewart DIBBS" <sjd@pixcl.com>
wrote:
[color=blue]
>news:UiFOf.19910$n%2.526@tornado.texas.rr.com...[color=green]
>vents a good squirt,[/color]
The problem with the usual recommendation is that it doesn't kill the
cause (mold) but just masks it.
You need to kill the mold.
gburnore at DataBasix dot Com
How you look depends on where you go.
Gary L. Burnore | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
Official .sig, Accept no substitutes. | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
| ÝÛ 0 1 7 2 3 / Ý³Þ 3 7 4 9 3 0 Û³
Black Helicopter Repair Services, Ltd.| Official Proof of Purchase
Old 03-05-2006, 06:32 PM   #4 (permalink)
ron
Guest
Posts: n/a
View ron's Photo Gallery
Re: Musty A/C Odor
I have had pretty good luck, in cars without a cabin filter.
By
Spraying Lysol thru the intake (cowl area) while running the fan. I
use the aerosol type and usually give it a real good shot several
times. Not sure if it will get all the mold but should help.
Ron
Old 03-05-2006, 08:51 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Musty A/C Odor
> engine with over 280,000 miles on the odometer. If I had known all was
> needed was to have the system charged I would have done it 5 years ago
> instead of driving around in the heat of Houston. Anyway, when I run the
> A/C for a while and cut off the engine for like a day or a few hours and
> start it again, there is a musty odor that comes from the vents. I asked
> my mechanic about it and he said that it was most likely the evaporator
> which probably had mold growing inside it from the moisture build up from
> the A/C running. He said that on cars old as mine that they werent
> serviceable. There has got to be some way of killing the odor and mold. I
> have sorta solved the problem by just leaving the vent open and opening
> the windows and try to dry the moisture out a while before I cut off the
> car. If anyone knows of some way of solving this problem please let me
> know. It will be much appreciated.[/color]
First, check the carpet under the passenger side of the dashboard for
dampness. If it is damp or if you hear water sloshing around under the
passenger side of the dashboard, then the evaporator drain tube is
mis-positioned or clogged. Make sure it exits out the hole in the floor of
the car, and stick a wire up from underneath to make sure it is not clogged.
Besides Lysol, you can spray water mixed with bleach to kill the mold, or
you can try Frigi-Fresh by BG - some auto shops may carry it.
Ray O
Old 03-06-2006, 12:39 AM   #6 (permalink)
RT
Guest
Posts: n/a
View RT's Photo Gallery
Re: Musty A/C Odor
On Sun, 05 Mar 2006 17:34:44 GMT, "Savalas" <thegaffler@yahoo.com>
wrote:
[color=blue]
>[/color]
What I usually do to preven this is I switch the AC off a couple
minutes before I reach my destination and just let it blow air. It
will prevent condensation in the system and you won't get the bad
smell. Make sure the ac is off but the fan is still running. This is
actually quite common in many cars.
Old 03-06-2006, 06:40 AM   #7 (permalink)
=?iso-8859-1?Q?mark=5Fdigital=A9?=
Guest
Posts: n/a
View =?iso-8859-1?Q?mark=5Fdigital=A9?='s Photo Gallery
Re: Musty A/C Odor
>[/color]
Either steam clean your floor mats or replace them. Or, I highly recommend
Oust. Don't use Lysol it can attack your lungs. It's not meant to be used as
a air spray and definitely not in such a closed space. Read the warning
label.
mark_
Old 03-06-2006, 02:25 PM   #8 (permalink)
ron
Guest
Posts: n/a
Re: Musty A/C Odor
If your floor mats are wet on passenger side probably the drain hose
is plugged. Unclog it then try the other remedies. Easy to get mold
in high humidity areas if the drain is plugged.
Old 03-07-2006, 10:09 AM   #9 (permalink)
Art
Guest
Posts: n/a
View Art's Photo Gallery
Re: Musty A/C Odor
Won't the bleach mixture damage metal parts? It might take a while but
chlorine bleach eats metal. When furnace manufacturers thinned out metal
parts to make furnaces more energy efficient, people that had washing
machines near furnaces and used bleached often suffered premature failure of
the heat exchangers. It was traced to the use of bleach in the same room.
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:6a2fb$440b98dd$180fead6$23575@msgid.meganewsservers.com...[color=blue]
>> me with. I not too long ago got my A/C working on my '90 Camry DX, 3SFE
> of the car, and stick a wire up from underneath to make sure it is not
> clogged.
> Ray O
>[/color]
Old 03-07-2006, 10:10 AM   #10 (permalink)
Art
Guest
Posts: n/a
Re: Musty A/C Odor
Or use the lysol when you are not going to be driving the car for a while.
"mark_digital©" <976XXX@nospam.net> wrote in message
news:X5ednRvb7fkHgpHZnZ2dnUVZ_s-dnZ2d@comcast.com...[color=blue]
>>[/color]
> as a air spray and definitely not in such a closed space. Read the warning
> label.
> mark_
>[/color]
Old 03-07-2006, 12:26 PM   #11 (permalink)
Ray O
Guest
Posts: n/a
Re: Musty A/C Odor
"Art" <begunaNOSPAMPLEASE@mindspring.com> wrote in message
news:imhPf.1144$sL2.455@newsread2.news.atl.earthlink.net...[color=blue]
> of the heat exchangers. It was traced to the use of bleach in the same
> room.
>[/color]
I don't know whether the bleach mixture will damage metal parts or not, so
to be on the safe side, forget what I said about the bleach and stick to
Frigi-Fresh!
Ray O
[color=blue]
> news:6a2fb$440b98dd$180fead6$23575@msgid.meganewsservers.com...[color=green]
>> news:UiFOf.19910$n%2.526@tornado.texas.rr.com...[color=darkred]
>>> from the A/C running. He said that on cars old as mine that they werent
>>> I have sorta solved the problem by just leaving the vent open and
>>> opening the windows and try to dry the moisture out a while before I cut
>>> off the car. If anyone knows of some way of solving this problem please
>>> let me know. It will be much appreciated.[/color]
>> clogged.
>> Ray O
>>[/color]
>[/color]
Old 03-07-2006, 01:36 PM   #12 (permalink)
Mike Hunter
Guest
Posts: n/a
View Mike Hunter's Photo Gallery
Re: Musty A/C Odor
Not if properly diluted. It is like the 'bleach' in the water you drink
water, but you can't drink bleach ;)
mike hunt
> room.
>[/color]
Old 03-07-2006, 02:31 PM   #13 (permalink)
Guest
Posts: n/a
Re: Musty A/C Odor
news:fnhPf.1145$sL2.1065@newsread2.news.atl.earthlink.net...[color=blue]
>[/color]
Sprinkle some Old Spice in there while you're at it.
mark_
Old 03-07-2006, 04:50 PM   #14 (permalink)
Guest
Posts: n/a
Re: Musty A/C Odor
"Mike Hunter" <mikehunt2@mailcity.com> wrote in message
news:RBmdnU0jLMRQT5DZUSdV9g@ptd.net...[color=blue]
> mike hunt[/color]
OK. If one drop of bleach in a gallon of water is the equivalent of tap
water tell me how many drops will it take to be "properly diluted"?
mark_
Old 03-07-2006, 05:55 PM   #15 (permalink)
Gary L. Burnore
Guest
Posts: n/a
Re: Musty A/C Odor
On Tue, 7 Mar 2006 14:31:40 -0500, mark_digital© <976XXX@nospam.net>
wrote:
[color=blue]
>news:fnhPf.1145$sL2.1065@newsread2.news.atl.earthlink.net...[color=green]
>>[/color]
> Sprinkle some Old Spice in there while you're at it.[/color]
Better yet, some FDS. Heh.
BB code is Off
Smilies are Off
[IMG] code is Off
Weird smelling A/C... ATX_Tacoma 2nd Generation (2005+) 9 05-29-2006 09:54 PM
1990 Camry 3S-FE A/C Issue jrock80 1st & 2nd Generation (1983–1986 & 1987-1991) 4 01-20-2006 11:13 AM
An odd musty odor rblieber 1st Generation (2001–2007) 8 01-07-2006 05:48 PM
'94 Camry with musty smell in A/C big_john 3rd & 4th Generation (1992–1996 & 1997–2001) 2 01-06-2005 09:05 PM
