Jolt Brake Problem Or Something else ?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2006, 07:54 PM   #1 (permalink)
Indu Prakash
Guest
Posts: n/a
View Indu Prakash's Photo Gallery
Corolla 2002 Automatic 46K miles
When I first start the car and put into into forward gear then with brakes
pressed then I get a small jolt .. I can repeat the jolting but putting the
car in reverse gear and then back into forward gear. But after driving
around for 10 minutes the jolt was very less. Any suggestions ?
Thanks
Old 03-06-2006, 08:16 PM   #2 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Re: Jolt Brake Problem Or Something else ??
Sounds like your cold idle speed is set too high. When "choke" is on
(i.e.engine cold) the engine speed is higher than when it s warmed up. Choke
is old carb term - guess its the cold idle speed with FI.
"Indu Prakash" <leolite1@sbcglobal.net> wrote in message
news:CR4Pf.26399$2O6.21964@newssvr12.news.prodigy.com...[color=blue]
> the car in reverse gear and then back into forward gear. But after driving
> Thanks
>[/color]
Old 03-07-2006, 12:50 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Wolfgang" <NOwolfXgang_dieterSPAM@NOXcox.net> wrote in message
news:ca5Pf.29729$2c4.229@dukeread11...[color=blue]
> Choke is old carb term - guess its the cold idle speed with FI.
> news:CR4Pf.26399$2O6.21964@newssvr12.news.prodigy.com...[color=green]
>> brakes pressed then I get a small jolt .. I can repeat the jolting but
>> putting the car in reverse gear and then back into forward gear. But
>> after driving around for 10 minutes the jolt was very less. Any
>> suggestions ?
>> Thanks
>>[/color]
>[/color]
Since the cold idle speed is controlled by a computer, it may not
necessarily be too high. How long has the original poster owned the car?
Ray O
Old 03-07-2006, 06:26 AM   #4 (permalink)
Indu Prakash
Guest
Posts: n/a
I've been the only owner of the vehicle .. for around 5 years now.
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:d22a4$440d2476$180fead6$12695@msgid.meganewsservers.com...[color=blue]
> news:ca5Pf.29729$2c4.229@dukeread11...[color=green]
>> news:CR4Pf.26399$2O6.21964@newssvr12.news.prodigy.com...[color=darkred]
>>> suggestions ?
>>> Thanks
>>>[/color]
>>[/color]
> Ray O
>[/color]
Old 03-07-2006, 12:21 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:Y5ePf.68122$PL5.27589@newssvr11.news.prodigy.com...[color=blue]
> news:d22a4$440d2476$180fead6$12695@msgid.meganewsservers.com...[color=green]
>> news:ca5Pf.29729$2c4.229@dukeread11...[color=darkred]
>>>> suggestions ?
>>>> Thanks
>>>[/color]
>> Ray O
>>[/color]
>[/color]
Is the cold engine idle speed higher than normal? If the engine cold idle
speed is normal, then an abnormal jolting sensation can be caused by a
broken or worn engine or transmission mount or a transmission problem. If
the transmission fluid has never been changed as a part of a preventative
maintenance procedure, then I would start with that. Make sure that the
correct transmission fluid is used.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Brake Problem Help!!!!! tskelton1211 Camry & Solara Lounge 18 12-10-2004 01:09 AM
Serious brake like problem.. help?? Statiks Camry & Solara Lounge 3 08-17-2004 12:00 AM
problem: brake light on WYSIWYG Archived Corolla threads 1 03-01-2004 03:49 PM
brake problem john Hardcore Tech and Competition 9 12-11-2003 08:34 AM
gen 5 brake problem? fungke 5th & 6th Generation (2002-2006 & 2007-2011) 5 08-30-2003 05:35 PM
