91 corolla electrical problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-08-2006, 07:54 PM   #1 (permalink)
Frosty Snowman
Guest
Posts: n/a
View Frosty Snowman's Photo Gallery
car would not start , had alternator tested said it was bad. changed
alt. and battery and now 3 days later it won`t start again. anybody have
any clues as to why this is happening.
thanks in advanace for any help
Old 03-08-2006, 08:15 PM   #2 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
Re: 91 corolla electrical problem
Need a little more info -- the starter is cranking it over and it won't
fire? Starter spinning but not turning engine over? No sound from starter at
all?
"Frosty Snowman" <frostysnowman46@webtv.net> wrote in message
news:3651-440F7CDD-47@storefull-3333.bay.webtv.net...[color=blue]
>[/color]
Old 03-09-2006, 08:06 AM   #3 (permalink)
dan gerrity
Guest
Posts: n/a
View dan gerrity's Photo Gallery
no sound from starter.
Old 03-09-2006, 10:45 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"dan gerrity" <dan070@webtv.net> wrote in message
news:2306-44102858-44@storefull-3336.bay.webtv.net...[color=blue]
>[/color]
It would help if you quoted previous posts so that people trying to reply
know what the problems, symptoms, and corrective actions were.
If there is no sound from the starter:
If you have an automatic transmission, try setting the parking brake and
shifting to neutral. If the car starts in Neutral but not in park, then the
neutral safety switch and circuit are suspect.
If you have a manual transmission, make sure that the clutch pedal is
depressed all the way, with no obstructions behind the pedal like the floor
mat. You can disconnect the clutch safety switch and jump the wires on the
harness side and see if the starter engages. Obviously, make sure you are
in neutral before you try this.
Next, check for power at the starter when it is engaged. If there is no
power at the starter, work your way backwards to the relay. It is not
uncommon for the starter relay to be bad.
Keep going backwards until you find the open circuit.
Ray O
Old 03-09-2006, 11:17 AM   #5 (permalink)
Frosty Snowman
Guest
Posts: n/a
i replaced the alt. and battery after they were tested at auto zone .
lasted about 3 days and the new battery went dead. it is a manual trans
what could be causing this problem. it seems the alt. is not working
again. thanks again for any help in advance.
Old 03-09-2006, 01:46 PM   #6 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
[email]frostysnowman46@webtv.net[/email] (Frosty Snowman) wrote:
[color=blue]
>again. thanks again for any help in advance.[/color]
Ok... we need more info...did it work normally for those three
days?...did it start ok?...how many times did you start it in
those three days?...pretty hard to diagnose your problem when you
don't give much info...
-Gord.
(use gordon in email)
Old 03-09-2006, 08:19 PM   #7 (permalink)
Frosty Snowman
Guest
Posts: n/a
good news to report , i went back over the work that was preformed . i
found that the plug was not put on correctly on the alternator. . .
anyways problem solved. thank you for some of your ideas. also sorry
for some of confusion in my post. have a good day. p.s. i did bring
it to the attention of the person who did the work.
BB code is Off
Smilies are Off
[IMG] code is Off
99 Corolla intermittant starting problem wmcot Archived Corolla threads 9 05-18-2010 02:39 PM
Intermittent Electrical Problem VancouverVan Pre-88 Toyota Pickup/Hilux 10 11-07-2005 01:38 PM
87 Corolla hesitation problem. Bad_dude Archived Corolla threads 8 10-25-2004 05:31 PM
Not sure what year, 93-96 corolla radio/center console lighting problem (Pics) SubaruWRXMike Archived Corolla threads 10 10-20-2004 06:53 PM
91 Corolla Starting Problem DRodriguez Archived Corolla threads 6 08-26-2004 05:45 AM
