1987 Toyota Cressida - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2006, 03:28 PM   #1 (permalink)
shee
Guest
Posts: n/a
View shee's Photo Gallery
There is a child lock on the inside of the passenger doors. It must be locked
because I can't open the passenger doors from the inside, obviously. But, I
can't even open the doors from the outside. I'm completely lost, and kinda
need my doors to open, at least from the outside. Does anyone have any ideas??
? Thanks
Old 03-09-2006, 04:09 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1987 Toyota Cressida
"shee" <u19519@uwe> wrote in message news:5d03a9bf88cb4@uwe...[color=blue]
> locked
> I
> ideas??
> ? Thanks[/color]
When you say "passenger doors" do you mean the front seat passenger door or
the rear seat passenger door?
Have you tried unlocking the doors manually?
Most likely, a rod clip has fallen off inside the door. If this happened to
multiple doors at the same time, the most likely cause was someone was
attempting to use a slim jim and knocked the rod clips off.
Ray O
Old 03-09-2006, 04:29 PM   #3 (permalink)
shee
Guest
Posts: n/a
It is the two back passenger doors. They don't unlock from the inside or the
outside. Not even when you pull the door latch up. Nothing...nada....
Ray O wrote:[color=blue][color=green]
>> locked[/color]
>[quoted text clipped - 4 lines][color=green]
>> ideas??
>> ? Thanks[/color]
>attempting to use a slim jim and knocked the rod clips off.[/color]
Old 03-09-2006, 04:31 PM   #4 (permalink)
shee
Guest
Posts: n/a
Whats the next step I make??? How would I fix the rod clips???
shee wrote:[color=blue]
>[color=green][color=darkred]
>>> locked[/color][/color]
>[quoted text clipped - 10 lines][color=green]
>>attempting to use a slim jim and knocked the rod clips off.[/color][/color]
Old 03-09-2006, 04:51 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
"shee" <u19519@uwe> wrote in message news:5d0435e455a2c@uwe...[color=blue]
> Whats the next step I make??? How would I fix the rod clips???[/color]
Assuming that the temperature is not below freezing where you are and the
doors are not just be frozen shut, then yo uhave to remove the interior door
panel to access the hardware that releases the door and to the lock rod
clips. It is a lot harder to remove the interior door panel when the door
does not open. The doors panel is held on with a combination of screws and
clips. First remove all screws (usually screws holding the arm rest and
door release lever) and then pull the retaining clips our from the
perimeter of the door panel.
Ray O
[color=blue]
> shee wrote:[color=green]
>>the
>>[color=darkred]
>>>> locked[/color]
>>[quoted text clipped - 10 lines][color=darkred]
>>>attempting to use a slim jim and knocked the rod clips off.[/color][/color][/color]
Old 03-09-2006, 07:30 PM   #6 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
>"shee" <u19519@uwe> wrote in message news:5d0435e455a2c@uwe...[color=green]
>does not open.[/color]
SNIP
Ray, can he use a Slim Jim to open the door with the clips
disconnected?...be lots easier to get the panel off...
-Gord.
(use gordon in email)
Old 03-09-2006, 07:39 PM   #7 (permalink)
Gary L. Burnore
Guest
Posts: n/a
View Gary L. Burnore's Photo Gallery
On Fri, 10 Mar 2006 01:30:24 GMT, Gord Beaman <gord@islandtelecom.com>
wrote:
[color=blue]
>[color=green]
>>"shee" <u19519@uwe> wrote in message news:5d0435e455a2c@uwe...[color=darkred]
>SNIP
>disconnected?...be lots easier to get the panel off...[/color]
Just tried it on my 89 and it worked. Slant the slim jim at about a
35 or 40 degree angle from horizonatal towards the back of the door
and you catch the latch rod. Pull to open. Not sure if the 87 had the
same door.
gburnore at DataBasix dot Com
How you look depends on where you go.
Gary L. Burnore | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
Official .sig, Accept no substitutes. | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
| ÝÛ 0 1 7 2 3 / Ý³Þ 3 7 4 9 3 0 Û³
Black Helicopter Repair Services, Ltd.| Official Proof of Purchase
Old 03-10-2006, 12:38 AM   #8 (permalink)
Ray O
Guest
Posts: n/a
"Gord Beaman" <gord@islandtelecom.com> wrote in message
news:mgl1121isojncpb4m7scbjnebta19gc3ng@4ax.com...[color=blue]
>[color=green]
>>door
> SNIP
> -Gord.
> (use gordon in email)[/color]
In theory, yes - if the OP can get the slim jim on the door lock itself.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Toyota to Offer XM Radio as a Factory-Installed Option EKam Toyota News 1 08-17-2011 06:53 PM
1987 Toyota Van LE 4WD toyvan Vehicles 3 12-15-2008 09:51 PM
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
