Corolla ignition - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2006, 09:25 PM   #1 (permalink)
TJ
Guest
Posts: n/a
View TJ's Photo Gallery
Corolla ignition
How do i test the ignitor in a 1988 Toyota 4AF carbureted engine?
Old 03-10-2006, 12:43 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Corolla ignition
"TJ" <132@132.com> wrote in message news:op.s56g5hjy3p34t1@ws01...[color=blue]
> How do i test the ignitor in a 1988 Toyota 4AF carbureted engine?[/color]
Sorry, I forget the specific procedure, but you will need a multi-meter.
Best bet is to refer to a repair manual.
Ray O
Old 03-10-2006, 02:26 AM   #3 (permalink)
TJ
Guest
Posts: n/a
I have a digital multimeter so if you know whatever resistances or
voltages needed to check it. Just wondering if you know are the igniters
in the 4AFE (fuel-injected engines) interchangeable with the 4AF
(carbureted) engines? I'm guessing probably not but don't know for sure.
Thanks
[color=blue]
> Best bet is to refer to a repair manual.[/color]
Old 03-10-2006, 11:18 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
"TJ" <132@132.com> wrote in message news:op.s56u21za3p34t1@ws01...[color=blue]
> Thanks
>[color=green]
>[/color]
If you do not have access to a Chilton or factory repair manual, you can
check the readings on another igniter and compare. Even if the igniters are
not interchangeable, they resistances will be in the same range.
Ray O
Old 03-11-2006, 03:33 AM   #5 (permalink)
TJ
Guest
Posts: n/a
Thanks, i'll do that
[color=blue]
> are
> not interchangeable, they resistances will be in the same range.[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
4A-F with programmable ignition and launch control Flashmn Archived Corolla threads 2 09-26-2005 02:19 PM
Ignition Fuse Help Please..... shadetree714 Camry & Solara Lounge 2 09-05-2005 02:24 PM
'92 2.2L Camary w/ ignition & other troubles DougB 3rd & 4th Generation (1992–1996 & 1997–2001) 7 11-07-2004 07:18 PM
