Inadequate torque transfer from engine-02 corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2006, 02:05 AM   #1 (permalink)
sh-aly
Guest
Posts: n/a
View sh-aly's Photo Gallery
I have a manual 02 corolla. When I try to accelerate in any gear, the engine
starts reving hard but it does not transfer the power to the wheels the
power comes slowly and after some lag. What could be the problem?
Wajahat
Old 03-10-2006, 07:49 AM   #2 (permalink)
Ph@Boy
Guest
Posts: n/a
View Ph@Boy's Photo Gallery
Re: Inadequate torque transfer from engine-02 corolla
Check clutch master cylinder fluid level. If it is low fill to specs and
check slave cylinder on clutch to see if it is leaking. If both
components check ok, then you might just need a new clutch. Mileage?
sh-aly wrote:[color=blue]
> Wajahat
>[/color]
Old 03-10-2006, 11:16 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"sh-aly" <wqadeer@stanford.edu> wrote in message
news:durc0l$ov9$1@news.Stanford.EDU...[color=blue]
>engine starts reving hard but it does not transfer the power to the wheels
>the power comes slowly and after some lag. What could be the problem?
> Wajahat[/color]
It sounds like the clutch is slipping. Assuming that you are in the S.F.
Bay area and depending on mileage, driving conditions, and driving
technique, the clutch may be worn.
Ray O
Old 03-10-2006, 01:11 PM   #4 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
"Ph@Boy" <nowhere@somewhere.tv> wrote:
[color=blue]
>[/color]
I don't see what fluid level would have to do with it?...I'd say
its a slipping clutch for sure...
-Gord.
(use gordon in email)
Old 03-10-2006, 01:38 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
"Gord Beaman" <gord@islandtelecom.com> wrote in message
news:bnj3121ig9q5su2qehq6266vq3g8dh0taf@4ax.com...[color=blue]
>[color=green]
>>[/color]
> -Gord.
> (use gordon in email)[/color]
Gord is correct.
A low fluid level in the clutch master cylinder could cause hard shifting
but not slipping. On the other hand, if the clutch master cylinder were
hanging up somehow (very unlikely), it could cause slipping, as could weak
pressure springs (which would still require clutch replacement to fix).
Ray O
Old 03-10-2006, 01:58 PM   #6 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
It sounds like you've burned up the clutch.
> Wajahat
>[/color]
Old 03-10-2006, 01:59 PM   #7 (permalink)
Jeff Strickland
Guest
Posts: n/a
No matter the status of the hydraulics, the clutch is toast. The hydraulics
can also be toasted, but the description of the symptoms is not right for
this to be the case.
"Ph@Boy" <nowhere@somewhere.tv> wrote in message
news:441183F0.9040106@somewhere.tv...[color=blue]
> check slave cylinder on clutch to see if it is leaking. If both components
> sh-aly wrote:[color=green]
>> wheels the power comes slowly and after some lag. What could be the
>> problem?
>> Wajahat[/color]
>[/color]
Old 03-10-2006, 09:42 PM   #8 (permalink)
sh-aly
Guest
Posts: n/a
Thank you for your responses ppl. The mileage on the car is 67000 and it has
been used a lot in stop and go traffic. How much does a cluch change
generally cost?
"Jeff Strickland" <crwlr@yahoo.com> wrote in message
news:H6KdnZShTJrRR4zZnZ2dnUVZ_tKdnZ2d@ez2.net...[color=blue]
> news:durc0l$ov9$1@news.Stanford.EDU...[color=green]
>> Wajahat
>>[/color]
>[/color]
Old 03-10-2006, 11:04 PM   #9 (permalink)
harriswest
Guest
Posts: n/a
View harriswest's Photo Gallery
> generally cost?
>[/color]
Where? It's a labor intensive job requiring removal of both engine and
transmission. Prices do tend to vary depending on where you are in the
world and how much labor runs. In CenTex maybe $1,100 of which maybe
$200 is parts.
Got a Tacoma? Join spam-free
[url]http://autos.groups.yahoo.com/group/Toy_Coma/[/url]
Got a Corolla? Join spam free
[url]http://autos.groups.yahoo.com/group/Toy_Corolla/[/url]
Mike Harris
Austin, TX
Old 03-10-2006, 11:33 PM   #10 (permalink)
Ray O
Guest
Posts: n/a
news:dutgum$5u3$1@news.Stanford.EDU...[color=blue]
> has been used a lot in stop and go traffic. How much does a cluch change
> generally cost?
>[/color]
Unfortunately, it is probably $1,500 to $2,000 in the Bay Area.
Ray O
[color=blue]
> news:H6KdnZShTJrRR4zZnZ2dnUVZ_tKdnZ2d@ez2.net...[color=green]
>> news:durc0l$ov9$1@news.Stanford.EDU...[color=darkred]
>>>problem?
>>> Wajahat
>>>[/color]
>>[/color]
>[/color]
Old 03-12-2006, 11:45 AM   #11 (permalink)
Jeff Strickland
Guest
Posts: n/a
I had a mechanic install a new clutch in my BMW a year ago, it cost about
$900. The clutch itself wasn't too expensive, but the labor was huge.
If you can do the work yourself, I'd guess the clutch and associated parts
that go along with it will run to about $250, give or take.
> generally cost?
>>>problem?
>>> Wajahat
>>>[/color]
>>[/color]
>[/color]
Old 03-12-2006, 01:48 PM   #12 (permalink)
harriswest
Guest
Posts: n/a
Jeff Strickland wrote:[color=blue]
>[/color]
I'm betting your beemer wasn't front wheel drive.
Mike Harris
Austin, TX
Old 03-12-2006, 03:43 PM   #13 (permalink)
sh-aly
Guest
Posts: n/a
My mechanic has given me an estimate of $600 and the toyota dealer said
$1100
"harriswest" <harriswest@sbcglobal.net> wrote in message
news:44147A5A.9C564BB3@sbcglobal.net...[color=blue]
> Jeff Strickland wrote:[color=green]
>>[/color]
> Mike Harris
> Austin, TX[/color]
Old 03-12-2006, 06:34 PM   #14 (permalink)
Jeff Strickland
Guest
Posts: n/a
>>[/color]
>[/color]
That would be a good bet. But the cost of the clutch and associated parts is
still relatively small compared to the cost of the job so the point remains
the same.
BB code is Off
Smilies are Off
[IMG] code is Off
'98 Corolla engine noise earthmover Archived Corolla threads 5 10-28-2009 09:16 PM
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
88 Corolla engine years garrett simon Archived Corolla threads 5 02-10-2005 11:24 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
