Re: Electrical Short
<gaskinsce@yahoo.com> wrote in message
news:1142026359.962050.134370@v46g2000cwv.googlegroups.com...[color=blue]
>I have a 1989 Toyota Supra Non Turbo.
> The problem; The tail light indicator, brake indicator and battery
> indicator are all on. The battery drains if I use any electrical. The
> lights flicker when I raised and lower idle. The cars starts without
> any problems. I can't get the lights to go out and the battery to stay
> charged. I did find that water was getting in the rear hatch somehow.
> Any suggestions.
>[/color]
First, measure alternator output to make sure it is charging the battery.
If the alternator output is OK, then check for a draw when the engine is
shut off. Draw should not be more than a few milliamps. If you are getting
more than a few milliamps draw, then check:
Any aftermarket equipment like fog lights, audio systems, alarms, remote
starters, GPS, etc. Improper installation of aftermarket equipment is the
most common cause of parasitic draws.
Check to make sure the dome lights, glove box lights, under hood lights,
etc. are not stuck on.
Ray O
