Highlander - Check engine and VSC warning lights turned on simultaneously - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2006, 11:29 AM   #1 (permalink)
Bud H
Guest
Posts: n/a
View Bud H's Photo Gallery
I have a 2002 Highlander V6 which while driving to work, had the "Check
Engine" and "VSC" (Vehicle Stability Control) warning lights display on the
dashboard simultaneously. They have remained on for the last few days.
Anything significant that BOTH of these would light? Or is it coincidence
and expected from a VSC problem for both to be lit together?
Bud H
Old 03-11-2006, 11:38 PM   #2 (permalink)
Bud H
Guest
Posts: n/a
Re: Highlander - Check engine and VSC warning lights turned on simultaneously
"Bud H" <budh@REMOVETHISwmis.net> wrote in message
news:1216281naludk1b@corp.supernews.com...[color=blue]
> Bud H
>[/color]
I found a small rubber air hose disconnected from the air filter assembly.
Re-installed the hose, pulled out the EFI fuse near the battery for an hour,
re-installed the fuse, and now all warning lights are clear.
Bud H
Old 03-12-2006, 11:41 AM   #3 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
The NEXT time the Check light comes on, try going to an AutoZone store, or
the local auto parts store you like to use, and ask them if you can use the
OBD II Scan Tool. Many parts houses these days have Tool Loaner Programs
where you can check out a tool in much the same manner as checking a book
out from the library. Among the tools they have to loan is the Scan Tool for
OBD II compliant cars and trucks, which includes all cars and trucks offered
for sale in the USA since the 1996 model year. The scan tool plugs into a
data port located along the bottom of the dash board in the area near your
left knee while you are driving. The OBD II data port kinda reminds me of a
printer port on the back of pre-USB printers, except that the data port on
your car only has something like 16 pins, wheras the printer port gets 40
pins.
news:1217cuerigl90d2@corp.supernews.com...[color=blue]
> news:1216281naludk1b@corp.supernews.com...[color=green]
>>the dashboard simultaneously. They have remained on for the last few
>>days.
>> coincidence and expected from a VSC problem for both to be lit together?
>> Bud H
>>[/color]
> hour, re-installed the fuse, and now all warning lights are clear.
> Bud H
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
need help: vsc, trac off, check engine light ON chexmixb xB Lounge 15 10-03-2011 10:37 PM
VSC,check engine light & Trac Off lights all came on - '02 Highlander Pat Thomas 1st Generation (2001–2007) 1 01-03-2006 08:30 PM
VSC, engine light & Trac off lights on - '02 Toyota Highlander Pat Thomas Introduce Yourself Here 0 01-03-2006 01:59 PM
Toyota Announces Prices For All-New Hybrid Synergy Drive-Powered Highlander Hybrid SU Ratko Toyota News 6 05-13-2005 11:03 PM
