Adding AUX-Input to 2003 Toyota Matrix CD/Radio (again) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-11-2006, 12:21 PM   #1 (permalink)
JemH
Guest
Posts: n/a
View JemH's Photo Gallery
I would like to add an AUX-Input to my 2003 Toyota Matrix's stock single-
CD/Radio, and I cannot seem to find anything -- DYI or commercial -- to do
it.
I see that the topic has been covered at least once in another thread;
however, all the AUX Input 3rd-Party ads I see seem to indicate an
exception for the 2003 Toyota Matrix, so I was wondering if there is even a
reasonably-priced (or any) solution for that model, which I own?
I have the stock single CD player/AM/FM radio (the car's handbook says
AN17019 near its picture), that has a CD/AUX switch, but no apparent AUX
input.
Does anyone know if an AUX input already exists in this particular radio,
and if so, where might I find it?
If not, is there a 3rd-party solution available? And what's the CD/AUX
switch all about, then?
Any help is much appreciated.
JeffH
Old 03-11-2006, 08:18 PM   #2 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
Re: Adding AUX-Input to 2003 Toyota Matrix CD/Radio (again)
On Sat, 11 Mar 2006 12:21:26 -0600, JemH wrote:
[color=blue]
> it.
> input.
> JeffH[/color]
I believe on this model there is an option for a CD OR an Aux, but I have
been wrong once before.
I think if you have the CD plugged in, that's it. The best thing to do
would be to remove the radio and have a look. There may be another input
back there.
I believe this is a Delco unit; a lot of the Matrixes ("Matrices"?) have
Delco sound systems since they are built in Canada. Try contacting a
Pontiac dealer and approach it as though it were a Vibe and see if it
makes a difference.
This may also be the reason WHY the Matrix is the exception.
In the grand scheme fo things...
What difference does it make?
Old 03-12-2006, 11:35 AM   #3 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
"JemH" <JemH@aol.com> wrote in message
news:Xns978369AC111F0JeffHOrg@216.196.97.136...[color=blue]
> it.
> a
> input.
>[/color]
You might find it in the back. Just a thought ...
Have you bothered to pull the radio to see what is on the back?
Old 03-13-2006, 08:41 PM   #4 (permalink)
JemH
Guest
Posts: n/a
"Jeff Strickland" <crwlr@yahoo.com> wrote in
news:q7KdnWivxKxVxonZnZ2dnUVZ_tOdnZ2d@ez2.net:
Thanks for the replies. No, I haven't opened it up, yet, primarily
because it looks like a real chore, plus I've seen cautions about being
extremely careful working around the airbags (one of which is just above
and to the right of the radio).
I haven't yet found instructions on disassembling the dashboard around
the radio, but was going to check for a shop manual that might show how
to access that area. (I don't see any obvious screws holding the front
in place.)
I wanted to make sure I had a reason to take it all apart, before I
sallied forth.
Thanks,
JeffH
[color=blue]
> news:Xns978369AC111F0JeffHOrg@216.196.97.136...[color=green]
>>single-
>> to do it.
>> thread; however, all the AUX Input 3rd-Party ads I see seem to
>> indicate an exception for the 2003 Toyota Matrix, so I was wondering
>> if there is even a
>> says AN17019 near its picture), that has a CD/AUX switch, but no
>> apparent AUX input.
>> radio, and if so, where might I find it?
>>[/color]
>[/color]
Posted via UsenetRevolution.com - Revolutionary Usenet
** HIGH RETENTION ** Specializing in Large Binaries Downloads **
[url]http://www.UsenetRevolution.com[/url]
Old 03-14-2006, 12:28 AM   #5 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
news:Xns9785BE8135FE7JeffHOrg@66.250.146.184...[color=blue]
> in place.)
> sallied forth.
> Thanks,
> JeffH
>[/color]
Here are instructions for removing the trim around the radio:
[url]http://www.pro-fit-intl.com/Adobe/TY-55-02.pdf[/url]
I'm pretty sure that there is no aux input in the back of the radio.
Try crutchfield.com and see what they have. They are probably one of the
most complete aftermarket audio suppliers - if Crutchfield doesn't have what
you're looking for, it probably doesn't exist.
Ray O
<snipped>
Old 03-16-2006, 12:37 AM   #6 (permalink)
Viperkiller
Guest
Posts: n/a
View Viperkiller's Photo Gallery
On Sat, 11 Mar 2006 12:21:26 -0600, JemH <JemH@aol.com> wrote:
[color=blue]
>it.
>input.
>JeffH[/color]
Here's a simple fix. Exchange with one from a Scion that has the AUX
input. You may also exchange with a newer Toyota radio with the AUX
input. Just make sure the plugs on the back of the radio are the
same.
Old 03-18-2006, 07:49 PM   #7 (permalink)
JemH
Guest
Posts: n/a
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in
news:44d1$441662b6$180fead6$4555@msgid.meganewsservers.com:
Thanks much, for both the document and URL.
JeffH
[color=blue]
> news:Xns9785BE8135FE7JeffHOrg@66.250.146.184...[color=green]
>> being extremely careful working around the airbags (one of which is
>> just above and to the right of the radio).
>> around the radio, but was going to check for a shop manual that might
>> show how to access that area. (I don't see any obvious screws
>> holding the front in place.)
>> sallied forth.
>> Thanks,
>> JeffH
>>[/color]
> the most complete aftermarket audio suppliers - if Crutchfield doesn't
> have what you're looking for, it probably doesn't exist.
>[/color]
Posted via TITANnews - Uncensored Newsgroups Access[color=blue][color=green][color=darkred]
>>>> at [url]http://www.TitanNews.com[/url] <<<<[/color][/color][/color]
-=Every Newsgroup - Anonymous, UNCENSORED, BROADBAND Downloads=-
Old 03-18-2006, 11:22 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
news:Xns978AB60E57F5AJeffHOrg@66.250.146.154...[color=blue]
> JeffH
>[/color]
You're welcome!
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
surpercharge 3VZ-FE possible? gmfb3VZ-FE Hardcore Tech and Competition 24 04-26-2010 09:24 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
1985 Pickup starting problem...HELP twinturbonoy Pre-88 Toyota Pickup/Hilux 10 03-15-2006 01:25 AM
In hybrids, it's Toyota vs. the world EKam Toyota News 2 03-27-2005 08:04 PM
Big Matrix Meet, Irvine Toyota, Sunday 3rd of November, 10AM RAAMaudio Regional Meetings and Events 1 11-01-2002 01:22 AM
