Fabricating a Filler Neck - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-13-2006, 05:29 PM   #1 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
I had no luck finding a fuel filler neck for my '88 Supra.
The dealer suggested a radiatior shop.
Anyone have any ideas how to make one of these that will interface
properly with the tank?
In the grand scheme fo things...
What difference does it make?
Old 03-13-2006, 07:48 PM   #2 (permalink)
Bret Ludwig
Guest
Posts: n/a
View Bret Ludwig's Photo Gallery
Re: Fabricating a Filler Neck
Any muffler shop that bends tubing can do it if you can give them a
sample or get the vehicle there. Whether they WILL is another question
but usually yes.
Old 03-13-2006, 09:46 PM   #3 (permalink)
Hachiroku
Guest
Posts: n/a
On Mon, 13 Mar 2006 17:48:23 -0800, Bret Ludwig wrote:
[color=blue]
> but usually yes.[/color]
Thanks.
Old 03-14-2006, 12:17 PM   #4 (permalink)
badgolferman
Guest
Posts: n/a
View badgolferman's Photo Gallery
Hachiroku, 3/13/2006, 6:29:44 PM, <IfnRf.1026$%b.520@trndny04> wrote:
[color=blue]
> properly with the tank?[/color]
Local junkyards, perhaps?
Old 03-14-2006, 01:59 PM   #5 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On 13 Mar 2006 17:48:23 -0800, "Bret Ludwig" <bretldwig@yahoo.com>
wrote:
(Bret deleted the part about the rusting out gas filler neck)
[color=blue]
If the 'top filler neck & gas-cap fitting' end and the 'connects to
the tank' end are in good shape, a muffler shop, sheetmetal shop or
blacksmith can always bend a new piece of mild steel tubing to go
between the two fittings and weld it all together.
(Welded on the shop bench far from the car's gasoline tank, of
course. But since there are people who would try fixing it on the
car, and that won't work <Boom!> I figured I'd better clarify.)
Or if the damage is not severe (I can't see it) you could cut out
the rusted section with a hacksaw, deburr the ends of the tubing, and
insert a piece of Gates Green Stripe straight fuel filler hose. They
make it in 1/8" steps for smaller sizes and 1/4" steps up to something
like 4" ID - just cut a chunk and use good worm-drive hose clamps. It
will bend, but in a very large radius only.
If there are multiple rust-outs and tight curves, you can have them
bend a new center section of tubing with the curves and use two stubs
of fuel filler hose to assemble it back into one unit. No welding
needed.
It gets trickier if you need a special fitting to go into a gasket
on the tank, and that fitting end has rusted away.
The gas cap end of the filler neck is interchangeable between brands
and models, anything that will fit and work - as long as the pressure
and vacuum relief settings of the cap match what the car computer
expects. Otherwise it can set off the Check Engine light over
emissions system pressures.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 03-14-2006, 05:41 PM   #6 (permalink)
Coyoteboy
Guest
Posts: n/a
View Coyoteboy's Photo Gallery
"Hachiroku" <Trueno@ae86.GTS> wrote in message
news:IfnRf.1026$%b.520@trndny04...[color=blue]
>[/color]
Check with TCB [url]http://www.tcbperformanceparts.co.uk/[/url] - well known and used
in the UK by us celica owners.
J
Old 03-14-2006, 08:58 PM   #7 (permalink)
Hachiroku
Guest
Posts: n/a
On Tue, 14 Mar 2006 19:59:17 +0000, Bruce L. Bergman wrote:
[color=blue]
>[color=green]
> needed.
> --<< Bruce >>--[/color]
Let's see if I can do this: It's right where the tube meets the flange
that connects to the tank:
| |Rust is at this junction
________| |________
_________________________
Old 03-15-2006, 02:41 AM   #8 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
On Wed, 15 Mar 2006 02:58:20 GMT, Hachiroku <Trueno@ae86.GTS> wrote:
[color=blue]
> ________| |________
> _________________________[/color]
Oh <expletive deleted>. Worst possible place.
Is this one of those setups where the tube and flange are all one
piece, and there's a gasket and screws holding it to the tank?
You may have to fab a new flange with two or three inches of
straight tube on it, make it look exactly like your ASCII picture.
Or find a filler neck from another car with the same flange, even if
the tube is bent different - because the rest of the tubing doesn't
matter, you're chopping it off to get a good tank flange.
Chop your existing filler neck to match, get a chunk of Green Stripe
filler hose and four clamps, and have fun.
--<< Bruce >>--
BB code is Off
Smilies are Off
[IMG] code is Off
Engine Moisture In Oil Filler Neck Dufman 2nd Generation (2005+) 10 01-19-2012 03:27 PM
crack in filler neck, 95 rolla wayfast Archived Corolla threads 3 03-11-2006 06:09 PM
Filler Neck - flapper piece roch00 Archived Corolla threads 3 08-11-2005 03:28 AM
differential filler plug neck Camry & Solara Lounge 16 05-16-2004 03:54 PM
