Re: 2005 Solara 3.3 engine knocks
"Brian" <bbooth@nospam.nc.rr.com> wrote in message
news:vOIRf.39046$915.25399@southeast.rr.com...[color=blue]
> Hi,
> Have a 2005 solara with the 3.3 V6. What happens is the engine will
> knock around 2000 rpm at a slight load going up a slight incline. If you
> give it more throttle, it will stop. It doesn't do it all the time, so the
> dealer has not been able to reproduce it. I am using premium in it now and
> it still does it. I've tried different brands of gas and it doesn't seem
> to make a difference. It seems to be more prevalent when you let it sit at
> idle for 5 minutes after it's been driven and then start back up. It's an
> awful sounding noise, not your normal pinging...it's a definite knock. Has
> anyone run across this behaviour on the 3.3 liter? I am going to take it
> to the dealer again, but wanted to check to see what others thought.
> Thanks[/color]
A few seconds of pinging under load is OK if it goes away. That is the
electronic ignition timing doing its job. It should not ping or knock when
starting up, especially if the engine is hot.
Ray O
