Anti-Theft Radio Unlock? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-15-2006, 03:12 PM   #1 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
'93 4Rnr battery went dead after 4+ years. I recall setting the radio
anti-theft code but (argh) never wrote it down. Tried all my favorite PIN 3
digit combos. After 9 tries security lock went from SEC to it now it says
HELP. I did find
a 6 digit unlock sequence but how do you enter it? --- can"t get it to allow
entry of those digits.
I understand dealer can unlock usually for a cost but not sure real
value on a '93 OEM radio. It worked fine before the battery konked out.
Anyne ever reset with the code and do you know the keys to use to enter?
There are also several online sites that offer the unlock code for a fairly
reasonable
$25 --- do they work or is it crawl to dealer?
Old 03-15-2006, 04:16 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Anti-Theft Radio Unlock?
"Wolfgang" <NOwolfXgang_dieterSPAM@NOXcox.net> wrote in message
news:Cq%Rf.31616$2c4.10016@dukeread11...[color=blue]
> 3
> HELP. I did find
> allow entry of those digits.
> fairly reasonable
>[/color]
I would be a little nervous trusting any of the online sites that offer
online codes. After all, the entire purpose of having the code is to
prevent theft. What good would the audio security system be if any thief
could get the universal unlock code online?
You will have to take it to the dealer to get it unlocked. In the future,
you should record the radio unlock code and put it in the same place you
store the key code information. - You do have the key code information
stored somewhere you know, right? ;-)
Ray O
Old 03-15-2006, 07:15 PM   #3 (permalink)
Wolfgang
Guest
Posts: n/a
I have the little aluminum tabs that came with the keys (multiple yotas) ---
recently took one to dealer to have key cut for a 90 4Rnr (my daughter now
has) and, $7 later it, would NOT work. Had old worn key duped at HD for $2
and it worked fine. Why would't the original code cut key work? Old key
worn pretty smooth and sharp. You'd think the key tab would have part of VIN
on it too --- they all look the same so there is no way to tell which
vehicle unless you scratch something into the back of them.
Yota seems to have dropped the anti-theft radio thing now - thank goodness.
Doubt there was ever much marked for stolen OEM yota radios - just messes up
original owners who keep them past the battery life!
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:dc4aa$441892f1$44a4a10d$918@msgid.meganewsservers.com...[color=blue]
> news:Cq%Rf.31616$2c4.10016@dukeread11...[color=green]
>> PIN 3
>> says HELP. I did find
>> fairly reasonable
>>[/color]
> Ray O
>[/color]
Old 03-15-2006, 09:17 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
news:e%2Sf.31627$2c4.4057@dukeread11...[color=blue]
>yotas) --- recently took one to dealer to have key cut for a 90 4Rnr (my
>daughter now has) and, $7 later it, would NOT work. Had old worn key duped
>at HD for $2 and it worked fine. Why would't the original code cut key
>work? Old key worn pretty smooth and sharp. You'd think the key tab would
>have part of VIN on it too --- they all look the same so there is no way to
>tell which vehicle unless you scratch something into the back of them.[/color]
The replacement key didn't work because it fit the original pin pattern
perfectly (assuming that the key was cut correctly), while the original key
and cylinder pins were worn. If you were to file down the replacement key
so the wear matched the original key, it would probably have worked.
[color=blue]
> goodness. Doubt there was ever much marked for stolen OEM yota radios -
> just messes up original owners who keep them past the battery life![/color]
I agree, after Toyota dropped the 7 band graphic equalizer in Celicas and
Supras, the demand for OEM radios seemed to drop off quite a bit.
Ray O
[color=blue]
> news:dc4aa$441892f1$44a4a10d$918@msgid.meganewsservers.com...[color=green]
>> news:Cq%Rf.31616$2c4.10016@dukeread11...[color=darkred]
>>> PIN 3
>>> fairly reasonable
>>>[/color]
>> future, you should record the radio unlock code and put it in the same
>> place you store the key code information. - You do have the key code
>> information stored somewhere you know, right? ;-)
>> Ray O
>>[/color]
>[/color]
Old 03-15-2006, 11:16 PM   #5 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
On Wed, 15 Mar 2006 20:15:54 -0500, "Wolfgang"
<NOwolfXgang_dieterSPAM@NOXcox.net> wrote:
[color=blue]
I left my little key-code tag on the dealer's paper stock-number
tag. And I have a fairly fresh Original key on the same ring.
You have the key code, but if the dealer's key punch was worn or out
of alignment, or the person punching it was clueless (they couldn't
read the numbers right in the punch codes book, or didn't know how to
work the dials) it could easily punch a bad key.
The best way to get a 'factory fresh' key is with a pair of calipers
- the locksmith knows the height increments of the tumbler pins or
wafers, reads each notch on the old key with calipers, adds in for the
wear, and sets the punch heights on his key-punch machine by hand.
Problem is, now the interior parts of the locks are all worn out,
and don't know how to deal with a fresh key - seriously. The lock and
the most-used keys wear into each other. Some locksmiths have the
internal parts to rebuild the wear parts of the cylinders, but the
labor costs can eat you alive on work like that.
This is why the dealers sell complete 'sets' of replacement lock
cylinders (Doors, trunk/hatch, fuel door, ignition and glove/console)
keyed alike with the master and valet keys - so you can quickly re-key
the whole car with fresh.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 04-05-2006, 06:36 PM   #6 (permalink)
Wolfgang
Guest
Posts: n/a
Called dealer I bought it from and they said they would put their computer
reader on the car and reset the radio for $85. Guess I'll call back when
someone smarter is there --- they merely need to enter correct key sequence
and a 6 digit code. Service writer was sure he was right!
> 3
> HELP. I did find
> fairly reasonable
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Void warantee, if I install after market anti theft device? Vibroseis Archived Corolla threads 1 03-09-2006 02:08 PM
Anti theft device ALL MODELS n MAKES toyboyracer Off Topic 12 10-01-2005 07:54 PM
Highlander Anti Theft Code? WWLCCP Audio, Video, and Security - Tech 2 11-12-2004 01:39 PM
4TRESS Anti Theft Device FPS Audio, Video, and Security - Tech 0 05-27-2004 04:09 AM
Factory radio anti theft dsr377 Audio, Video, and Security - Tech 4 07-14-2003 09:05 PM
