Avalon 1997 Rear Wheel Noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-16-2006, 12:10 AM   #1 (permalink)
Bryan
Guest
Posts: n/a
View Bryan's Photo Gallery
Just for fun until daylight ...
At low speed car sounds like loose junk in the trunk. At freeway speed,
noise is gone (?).
When I kick the tire (right rear), it makes a clanking sound. Have checked
lug bolts for tightness. Will remove in AM and take a look.
Possibilities?
Old 03-16-2006, 05:25 AM   #2 (permalink)
cordest@sddc.army.mil
Guest
Posts: n/a
View cordest@sddc.army.mil's Photo Gallery
Re: Avalon 1997 Rear Wheel Noise
Bryan,
On my '95 a 'rattling 2x4s in the trunk' noise was solved by replacing
the 2 rubber bushings on the rear roll bar.
Hope this helps.
Tom
Old 03-16-2006, 02:23 PM   #3 (permalink)
Bryan
Guest
Posts: n/a
<cordest@sddc.army.mil> wrote in message
news:1142508308.751950.253950@v46g2000cwv.googlegroups.com...[color=blue]
> Bryan,
> Hope this helps.
> Tom
>[/color]
Brake pads are rattling!
Took it to Goodyear and they said everything is fine and rattling brake pads
are no problem except for the noise. Pads are still good; so will replace
in about 5000 miles. What do you think?
Old 03-16-2006, 02:57 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Bryan" <bryan.459@pac.bell.net> wrote in message
news:iPjSf.54536$H71.30854@newssvr13.news.prodigy.com...[color=blue]
> news:1142508308.751950.253950@v46g2000cwv.googlegroups.com...[color=green]
>> Bryan,
>> Hope this helps.
>> Tom
>>[/color]
> pads are no problem except for the noise. Pads are still good; so will
> replace in about 5000 miles. What do you think?
>[/color]
We have never had rattling brake pads in our 97 Avalon, which now has around
100,000 miles. Of course, the brake work was done correctly, using only OEM
pads.
If you can hear a clanking sound when the wheel is not moving, something
back there is loose. Check the clamps that hold the parking brake cable,
brake lines, and ABS sensor wires. Remove the rear rotor and check the
condition of the parking brake. Inspect both the inside and outside of the
pads for even wear.
Ray O
Old 03-16-2006, 06:37 PM   #5 (permalink)
Bryan
Guest
Posts: n/a
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:13832$4419d2b9$44a4a10d$23720@msgid.meganewsservers.com...[color=blue]
> news:iPjSf.54536$H71.30854@newssvr13.news.prodigy.com...[color=green]
>> news:1142508308.751950.253950@v46g2000cwv.googlegroups.com...[color=darkred]
>>> Bryan,
>>> Hope this helps.
>>> Tom
>>>[/color]
>>[/color]
> around 100,000 miles. Of course, the brake work was done correctly, using
> only OEM pads.
> the pads for even wear.
> Ray O
>[/color]
We're up to 187,000 miles. With the rim removed I can wiggle the pads and
get the same sound. Still, maybe this is one of those things that would be
worth a second opinion.
Old 03-16-2006, 11:13 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:AxnSf.1493$4L1.471@newssvr11.news.prodigy.com...[color=blue]
> news:13832$4419d2b9$44a4a10d$23720@msgid.meganewsservers.com...[color=green]
>> news:iPjSf.54536$H71.30854@newssvr13.news.prodigy.com...[color=darkred]
>>>> Bryan,
>>>> Hope this helps.
>>>> Tom
>>>[/color]
>> using only OEM pads.
>> Ray O
>>[/color]
> be worth a second opinion.[/color]
You should not be able to easily wiggle the pads with the caliper in place.
Something is missing, like the anti-rattle springs, or the caliper slide is
bound up.
Ray O
Old 03-17-2006, 11:33 AM   #7 (permalink)
Bryan
Guest
Posts: n/a
news:e1346$441a490a$180fead6$3324@msgid.meganewsservers.com...[color=blue]
>[color=green][color=darkred]
>>> cable, brake lines, and ABS sensor wires. Remove the rear rotor and
>>> check the condition of the parking brake. Inspect both the inside and
>>> outside of the pads for even wear.
>>> Ray O
>>>[/color]
>> and get the same sound. Still, maybe this is one of those things that
>> would be worth a second opinion.[/color]
> place. Something is missing, like the anti-rattle springs, or the caliper
> slide is bound up.
>[/color]
Thanks Ray, I'll pursue that idea.
Old 03-17-2006, 03:21 PM   #8 (permalink)
Ray O
Guest
Posts: n/a
news:EpCSf.39689$_S7.12700@newssvr14.news.prodigy.com...[color=blue]
> news:e1346$441a490a$180fead6$3324@msgid.meganewsservers.com...[color=green]
>>[color=darkred]
>>>> something back there is loose. Check the clamps that hold the parking
>>>> brake cable, brake lines, and ABS sensor wires. Remove the rear rotor
>>>> and check the condition of the parking brake. Inspect both the inside
>>>> and outside of the pads for even wear.
>>>> Ray O
>> slide is bound up.
>>[/color]
>[/color]
You're welcome. How about letting your son drive the Avalon and getting
something else for yourself? The Avalon is a known entity to you so you
know what he is driving, which is why we let our boys drive the Avalon
instead of getting rid of it and looking for something else.
Ray O
Old 03-17-2006, 05:27 PM   #9 (permalink)
Bryan
Guest
Posts: n/a
news:a3abc$441b289c$44a4a10d$1148@msgid.meganewsservers.com...[color=blue]
> "Bryan" <bryan.459@pac.bell.net> wrote in message[/color]
[color=blue][color=green][color=darkred]
>>> caliper slide is bound up.
>>>[/color]
>>[/color]
> --[/color]
Well, hmm ....
BB code is Off
Smilies are Off
[IMG] code is Off
History of the Toyota Avalon Ratko 1st Generation (1995-1999) 6 04-01-2012 09:05 AM
noise comin from rear inner fender wells sunruner19 2nd Generation (2005+) 2 03-15-2006 04:58 AM
Rear wheel alignment problem on 2004 corolla S Fv53 Archived Corolla threads 1 02-19-2006 07:50 PM
Camry Vibrates & Wheel Noise ?? GaviN Camry & Solara Lounge 6 09-28-2004 08:31 AM
