Re: 1998 Corolla Head Lights out Simultaniously
"Kevin Miller" <kcmiller@rogers.com> wrote in message
news:1143066495.305762.23020@j33g2000cwa.googlegroups.com...[color=blue]
> Update:
> I tried to change the headlights, didn't work, I've checked the fuses,
> they work fine.
> I'm really new at this stuff so if someone can help me out with some
> more directed advice that would be great.... where can I find a wiring
> diagram? What is the best way to proceed once I do (I'm guessing start
> at the lights and work my way back..?[/color]
You can get a wiring diagram at [url]http://techinfo.toyota.com/[/url] but unless you
know how to read one, I wouldn't invest the money. Also, if you are not
familiar with DC power, how to check a relay, read an ohmmeter, etc., I'm
not sure that anyone can learn from reading one article.
I'd suspect a loose connection or bad combination switch on the steering
column, perhaps start there and work your ways forward.
[color=blue]
> Also, i noted there is a bunch of goup on the light connecters.. what
> should I use to clean this off?
> Thanks in advance for any advice you can provide![/color]
The goop on the light connectors is dielectric grease. It was put there by
the factory - do not clean the stuff off as it helps maintain a
corrosion-free connection.
Ray O
