I Have A Starting Problem With A 91 Toyota Previa - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-21-2006, 09:28 PM   #1 (permalink)
Pure Racer
Guest
Posts: n/a
View Pure Racer's Photo Gallery
It starts in the morning but as soon as you turn it off and try starting it
in 15 minutes it doesnt start Help Me if you can Because im about to change
the starter.
Old 03-22-2006, 08:00 PM   #2 (permalink)
Pure Racer via CarKB.com
Guest
Posts: n/a
View Pure Racer via CarKB.com's Photo Gallery
Re: I Have A Starting Problem With A 91 Toyota Previa
Gord Beaman wrote:[color=blue][color=green]
>>the starter.[/color]
>Then give us some clues to work with...does it crank ok but won't
>fire?, does it just 'click'?, does it make no sound at all when
>you turn the key?, auto transmission?, manual?[/color]
It cranks but doesnt fire you have to step on the gas after 7 times of
cranking it until it turns on and its automatic
Message posted via [url]http://www.carkb.com[/url]
Old 03-22-2006, 11:53 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"Pure Racer via CarKB.com" <u19935@uwe> wrote in message
news:5da97c6781405@uwe...[color=blue]
> Gord Beaman wrote:[color=green][color=darkred]
>>>it
>>>change
> Message posted via [url]http://www.carkb.com[/url][/color]
It sounds like a lack of fuel or spark. Since it eventually fires, then
fuel is the more likely culprit. You will need a fuel pressure gauge to see
if pressure is bleeding down. If so, then the fuel pressure regulator is
suspect.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Taco tailgate...POS arctic_front 2nd Generation (2005+) 102 05-14-2010 07:26 PM
TOYOTA ENGINES AND OIL SLUDGE - WALL ST JOURNAL bondobondo General Discussion 99 02-02-2007 06:54 PM
North County Toyota of Anaheim xpeed Toyota Dealers 3 09-27-2005 10:58 AM
91 Corolla Starting Problem DRodriguez Archived Corolla threads 6 08-26-2004 04:45 AM
