"gp" <gpagmail-news@yahoo.com> wrote in message
news:1143000480.406104.308890@z34g2000cwc.googlegroups.com...[color=blue]
>I seemed to have had my wrist slapped for cross-posting this and even
> doing it incorrectly. Anyway, thanks for the help with part 1 diagnosis
> of my 88 toyota pickup and would appreciate help with this next part
> So it seems there is a leak or at least no antifreeze to see in the rad
> and little to none in the overflow. The oil is not milky and the
> antifreeze overflow ( what little there is) does not seem contaminated
> either. Water pump seems fine (no noise, no visible leak, no movement
> of pulley), now the question of finding the leak and I have still not
> ruled out head gasket --can you lose that much antifreeze via exhaust??[/color]
Yes, it is possible to lose that much coolant via the exhaust.
[color=blue]
> I have noticed some white exhaust but it is cold presently and I see
> many cars with similar white exhaust.[/color]
If the coolant was coming out the exhast you should it would look more
like smoke.
[color=blue]
> For the moment, I am going to top up the existing fluid with a economy
> antifreeze 50/50 mix with distilled water with the intent of flushing
> the system once I figure out where the leak is. Of course, there is no
> pool of fluid under the vehicle which is good and bad.[/color]
Top up the radiator and resevoir and then check for leaks. The easiest way
to do this would be with a cooling system pressure tester. They are
available at most auto parts stores or any decent garage would have one.
Places to check for leaks: water pump gasket and weep hole, all hose
connections, heater core, the radiator seams, fins and petcock. Also check
the engine block for leaking freeze plugs. Once you fill the system back up
the may be obvious.
[color=blue]
> The responses have been very helpful and if anyway would like to offer
> suggestions for the next step, it would be greatly appreciated.
>[/color]
Thank you very much, a little precision, I was reading a service manual
last night and it suggested to check under/inside the oil filler cap
and see if there was a milky/coffe/cream like build up and there was a
bit. It then suggested to change the oil (I will check again if there
is any milky stuff as there was none on the dipstick), run it for
50-100 continuous miles and check it again. I checked the antifreeze
again by drawing some out by the rad drain plug and all seems in order.
Now I am in a bit of denial here, so am hoping that the vehicle being
so old (88), there could have been some buildup over the past 20 years
as nobody actually looks inside the cap or cleans it.
Anyway, the book suggested the I get a Leak down? test done (if still
get milky after the oil change and drive) and a pressure test (for
leaks). As for the coolant coming out exhaust, if you suggest it should
look like smoke. Would it be fair to say, that it would be noticible by
others and/or somthing that is very evident?
news:1143040441.148637.308050@t31g2000cwb.googlegroups.com...[color=blue]
>[/color]
It would be very helpful if you quoted some previous posts so that people
responding would know and remember what has been suggested already as well
as other pertinent info like year, model, mileage, symptoms, etc.
I would not pressure test an 18 year old cooling system because Murphy's law
will kick in and cause additional cooling system leaks. I've seen this
happen numerous times.
Coolant coming out of the exhaust tends to be white steam and will have a
sweet smell like coolant. It is normal to see white clouds coming out of
the exhaust when you first start the engine until it is thoroughly warmed up
and the condensation in the exhaust has burned off. Depending on the
ambient temperature, the amount of white clouds you see should diminish but
if you still see billowing clouds out the exhaust, then that could mean that
coolant is getting into the combustion chambers somehow.
In article <1143040441.148637.308050@t31g2000cwb.googlegroups.com>,
gp <gpagmail-news@yahoo.com> wrote:[color=blue]
>again by drawing some out by the rad drain plug and all seems in order.[/color]
MY PSYCHIC POWERS PREDICT A BAD RADIATOR CAP.
--scott
"C'est un Nagra. C'est suisse, et tres, tres precis."
> as nobody actually looks inside the cap or cleans it.[/color]
It is normal for that engine to have a slight builup on the underside of
the oil filler cap when operated in cold weather. As long as it is only a
thin film you should be ok. All the 4 cyl toyotas I have seen will do that
in cold weather.
[color=blue]
> others and/or somthing that is very evident?[/color]
I would just fill the cooling sytem back up making sure you bleed out all
the air and the have it pressure tested for leaks. If all is ok drive it and
see if your problem returns, it may just be a sticking thermostat. If the
thermostat hasn't been changed in a long time I would do that also. I would
also replace the radiator cap as others have also stated. If after all the
above and you find no leaks then have a leak down test done.
If you have coolant in the exhaust you should be able to smell it. It has
a very distinct sweet smell.
I bought the vehicle about 2 years ago and do like it a lot -the rad
and a lot of the houses seem to be in very good condition. It is a 1988
toyota p/u 2wd, 2.4L, 4cyl, 22re engine with 190,000 km on it (marketed
as a one ton). It had one previous owner. I am grasping at any positve
news that it is not a head gasket. I have not smelt any sweet smell
from the exhaust or excessive --have been smelling rubber, but think
that is b/c new exhaust was placed a bit close to undermount spare tire
--hope it is not a rubber smell --no billowing clouds out the exhaust.
Tonight I will top it up with fresh antifreeze/good water mix, run it
with cap off, replace with new cap, and monitor the overflow container.
I will hold off on a pressure test for the moment and see how it goes.
Not sure when the thermostat was last changed, but that would not
explain coolant lose, would it?? Anyway, I do not mind taking it to a
shop in the near future, but I like to have some info if and when it
comes to that. Also, all this info has been useful so next time, I can
catch this earlier as there were signs that this was happening, like
longer for heater to heat inside, heat guage going up higher than
normal and then falling rapidly to a better baseline but this was in
that past 2 weeks, when the heat guage finally went up to red and
luckily I stopped and hope there was no damage done.
I will also copy and post from last series of dignosis.
"Mike" <mik@localnet.com> wrote in message
news:RcgUf.3566$kg.905@news02.roc.ny...[color=blue]
> news:1143040441.148637.308050@t31g2000cwb.googlegroups.com...[color=green]
> in cold weather.
>[color=green]
> and see if your problem returns, it may just be a sticking thermostat. If
> the thermostat hasn't been changed in a long time I would do that also. I
> would also replace the radiator cap as others have also stated. If after
> all the above and you find no leaks then have a leak down test done.
>[/color]
I would not recommend a pressure test on an 18 year old cooling system.
news:1143053273.859180.316650@j33g2000cwa.googlegroups.com...[color=blue]
> I will hold off on a pressure test for the moment and see how it goes.[/color]
I would not pressure test an 18 year old system unless whoever is doing the
test is very careful not to over-pressurize the system and actually cause
leaks.
[color=blue]
>[/color]
A bad thermostat can indirectly cause coolant loss because if it overheats
and turns to steam, it will flow out of the overflow tube. A bad radiator
cap can also cause coolant loss and overheating. The low coolant level can
cause a no heat condition. Also check to make sure the fins in the radiator
are not clogged and hindering airflow through the radiator, and that the fan
clutch is engaging.
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:1184e$4421e957$44a4a10d$9852@msgid.meganewsservers.com...[color=blue]
> news:RcgUf.3566$kg.905@news02.roc.ny...[color=green]
>> news:1143040441.148637.308050@t31g2000cwb.googlegroups.com...[color=darkred]
>> that in cold weather.
>>[color=darkred]
>> all the air and the have it pressure tested for leaks. If all is ok drive
>> it and see if your problem returns, it may just be a sticking thermostat.
>> If the thermostat hasn't been changed in a long time I would do that
>> also. I would also replace the radiator cap as others have also stated.
>> If after all the above and you find no leaks then have a leak down test
>> done.
>> has a very distinct sweet smell.
>>[/color]
> Ray O
> (correct punctuation to reply)[/color]
Why not ? If the cooling system is in that poor of a condition that a
pressure test will cause it to fail, those parts needed to be replaced
anyway. Think of it this way. If it were my vehicle I would rather have a
failure in the shop rather than on the road. He has already stated that it
was overheating, the coolant was boiling in the radiator and being blown
into the resevoir.That is already a toture test of the cooling system.
[color=blue]
>[/color]
news:CipUf.3652$kg.3005@news02.roc.ny...[color=blue]
> news:1184e$4421e957$44a4a10d$9852@msgid.meganewsservers.com...[color=green]
>> news:RcgUf.3566$kg.905@news02.roc.ny...[color=darkred]
>>> of the oil filler cap when operated in cold weather. As long as it is
>>> only a thin film you should be ok. All the 4 cyl toyotas I have seen
>>> will do that in cold weather.
>>> drive it and see if your problem returns, it may just be a sticking
>>> thermostat. If the thermostat hasn't been changed in a long time I would
>>> do that also. I would also replace the radiator cap as others have also
>>> stated. If after all the above and you find no leaks then have a leak
>>> down test done.
>>>[/color]
>> Ray O
>[/color]
Exactly right! The reason for a pressure test is too find a leak or a weak
point in the cooling system. What benefit is their in putting off finding
the problem until help is miles away?
Bob
"Bob" <bob@n0spam.net> wrote in message news:jVpUf.171$qQ2.107@fe03.lga...[color=blue]
> news:CipUf.3652$kg.3005@news02.roc.ny...[color=green]
>> news:1184e$4421e957$44a4a10d$9852@msgid.meganewsservers.com...[color=darkred]
>>>>> manual
>>>>> order.
>>>>> should
>>>>> by
>>>> would do that also. I would also replace the radiator cap as others
>>>> have also stated. If after all the above and you find no leaks then
>>> Ray O
>> it was overheating, the coolant was boiling in the radiator and being
>> blown into the resevoir.That is already a toture test of the cooling
>> system.
>>[/color]
> Bob[/color]
A cooling system pressure test is not all it's cracked up to be. With the
engine running at operating temperature, if there is a leak, you'll see it.
I've seen careless technicians overpressurize the cooling system and cause
problems. If the radiator cap is working properly, it will act like a
pressure relief valve and vent excess pressure. Hooking a pump up to the
radiator neck means that you do not have the cap to relieve pressure if too
much builds up. Testing or replacing the cap is a much safer course of
action. I've visited a lot of dealerships and looked at a lot of problem
vehicles and have never had to resort to a pressure test.
I went to the dealer and bought a new rad cap, easy fix and this
weekend, I am going to add new antifreeze and distilled water, and run
it to see. As for letting bubbles out air, am I right to assume that I
start the engine cold and pour the antifreeze/water in while it is
running? Also, I noticed Canadian tire markets special deionized water,
am I okay with distilled since I already bought it.
I emailed a pretty big Radiator garage about a pressure test and this
is what they said; "The best we can offer to you at the present time is
to bring your vehicle in this Saturday and we will pressure test your
system for free and hopefully find out where your coolant is going.
More than likely, if you have never noticed any coolant on the ground
(leaks) your vehicle probably has a intake or head gasket leak."
It is free, I am inclined to do it this Saturday morning and let the
chips fall where they may. My thinking is usually, if it ain't broke,
but it is broke, so may as well go for it.
news:1143129360.542836.264260@z34g2000cwc.googlegroups.com...[color=blue]
>[/color]
To refill the coolant, first set the heater control all the way to hot.
With the engine cold, fill the radiator to the bottom of the neck and the
overflow bottle to just above the "cold" line. With the radiator cap off,
start the engine and watch the coolant level in the radiator. As the
thermostat opens, the coolant level should begin to drop. As this happens,
gradually top off the coolant until it no longer goes down and replace the
radiator cap. A properly functioning radiator cap should allow some coolant
in the overflow bottle to get sucked into the radiator to completely fill
the last bit. Watch the level in the overflow bottle - if it is going down
quickly, then coolant is either going out the exhaust or leaking.
Distilled water is fine for mixing with concentrated coolant. A lot of
people use tap water, which contains minerals that will eventually cause
build up in the cooling system. The factory fill is mixed with distilled
water.
