Re: Celica overheating
"dudette1186" <dudette1186@aol.com> wrote in message
news:1143006198.141450.73470@z34g2000cwc.googlegroups.com...[color=blue]
> My 1991 celica recently had its thermostat replaced along with some
> other work to fix its overheating problems (costing me a good 1100
> bucks) and my mechanic told me that it was no longer overheating and
> that he drove it around to make sure. yet, once again it is having
> overheating issues. it is fine until i hit 4th gear and the
> thermometer shoots up to the halfway mark...and by the time i hit 5th
> gear it has hit the red zone. once i stop and turn the car off it
> sounds like the noise of boiling water is coming from under the hood.
> the car wont stay on again after that until its cooled off for a good
> hour. one major thing i noticed was the cooling fan NEVER goes on.
> other then this problem its still a good car and i do NOT want to get
> rid of it...because so many of the parts are new and i know that
> without this overheating problem the car will go on for many more
> miles. any suggestions on what the overheating issue could be??
>[/color]
Have your mechanic check the operation of the cooling fan. That should have
been one of the first things he checked. Also, did he install the
thermostat correctly? It is a common mistake to install it upside-down. He
should check to see the coolant is circulating properly. If the cooling
system itself is operating properly, then the head gasket may be leaking.
Ray O
