Re: engine oil, warming up the car - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2006, 02:46 PM   #1 (permalink)
Huw
Guest
Posts: n/a
View Huw's Photo Gallery
Built_Well wrote:[color=blue]
> Ray O wrote:
>[color=green]
>> 30 seconds is more than enough time for the oil to circulate so
>> you can start the engine[/color]
> Thanks Ray O! I'll never wait 10 long minutes even on sub-zero
> winter days again![/color]
I wonder what made you do such a pointless thing in the first place?
Huw
Old 03-24-2006, 03:14 PM   #2 (permalink)
Huw
Guest
Posts: n/a
badgolferman wrote:[color=blue]
> Huw, 3/24/2006, 2:46:18 PM, <48j0ktFkf796U1@individual.net> wrote:
>[color=green]
>> Built_Well wrote:[color=darkred]
>> Huw[/color]
> This is what we used to do when living in cold climates. It would
> warm up the inside of the car and clear the windows for safety's
> sake. Try living in sub-zero temperatures and see if you still care
> about wasting gas over warmth.[/color]
Believe it or not I have lived through several winters where temperature has
been down to -18C for periods. About 30 seconds then careful driving for a
few minutes has not failed me or any engine so far.
Huw
Old 03-28-2006, 10:14 AM   #3 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
news:i49922h606f0bmg7bag61cibv2fu6h6acf@4ax.com...[color=blue]
> On 24 Mar 2006 20:06:17 GMT, "badgolferman"
> <REMOVETHISbadgolferman@gmail.com> wrote:
>[color=green]
>>This is what we used to do when living in cold climates. It would warm
>>up the inside of the car and clear the windows for safety's sake. Try
>>living in sub-zero temperatures and see if you still care about wasting
> Visibility out the windows is another matter - if you can't keep a
> clear window wiped off, you might have to sit there and wait for
> heater output.
> But if you can make a 'sight slit' to see well enough to get out of
> the driveway and start carefully puttering on your way, you turn that
> expensive wasted gasoline into productive forward motion.[/color]
In Massachusetts you may be stopped and sighted for this.
When there is frost on the windows, I start the car and grab the scraper,
and scrape ALL the windows nice and clear.
This takes about...3 Minutes...
[color=blue]
> If this is a regular occurrence consider installing an electric
> block heater on the engine - you'll have heater output almost
> immediately, not a furnace but enough to start defrosting the windows.
> Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
> Electrician for Westend Electric - CA726700
> 5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
> Spamtrapped address: Remove the python and the invalid, and use a net.[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota Engine code vivian General Discussion 22 12-27-2008 02:16 AM
first oil change 05tacoma 2nd Generation (2005+) 76 03-03-2006 12:08 PM
oil leak inside the car geolica Yaris, Vitz and Echo Forum 1 07-20-2005 08:38 PM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 01:36 PM
