Re: engine oil, warming up the car - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2006, 04:47 PM   #1 (permalink)
RT
Guest
Posts: n/a
View RT's Photo Gallery
On Fri, 24 Mar 2006 13:10:49 -0500, "Ph@Boy" <nowhere@somewhere.tv>
wrote:
[color=blue]
>I have owned a 2003 model and I now drive a 2005, both automatics. I
>live in the cold climates and have noticed that I get better mileage
>using 5-30 in comparison to 10-30. 5-30 is the recommended weight oil. I[/color]
I think you are supposed to use 5w30 in colder climates. 10W30 is only
good when in warmer climates.
[color=blue]
>usually let the car warm up for about one or two minutes and then drive
>off. Most oils now days will provide more than sufficient lubrication
>when cold. I don't think that it's bad to let a car idle for a
>reasonable amount of time but it may be a waste of fuel and your time
>when you could be on your way.
>slatt333 wrote:[color=green]
>> Two questions 1) which oil to use for a 2003 corolla with 23K miles,
>> automatic.
>> 2) Should I warm the engine up before driving, esp in cold weather?
>> Another car manual (VW Golf) instructed me to just start the car and
>> drive away even in the cold because (a) the car warms up faster this
>> way and (b) it's bad for the engine to leave the car idle warming up.
>>[/color][/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Toyota Engine code vivian General Discussion 22 12-27-2008 02:16 AM
first oil change 05tacoma 2nd Generation (2005+) 76 03-03-2006 12:08 PM
oil leak inside the car geolica Yaris, Vitz and Echo Forum 1 07-20-2005 08:38 PM
Puddle of oil leaking from where? 97&02camryleI4 Camry & Solara Lounge 13 10-31-2004 01:36 PM
