Re: T 100 VS Tundra rim compatibility
On Fri, 24 Mar 2006 16:00:19 -0800, wabky wrote:
[color=blue]
> Would a stock 16" rim from a 2004 Tundra be compatible for use on a
> 1997 T100 4x4?
> Both are 16 inch and both have 6 bolts. Are there other measurements t
> be aware of?
> Thanks, Abe[/color]
You'll need to know the bolt pattern and the offset.
The bolt pattern can be found on Google, somewhere. Search on Toyota T-100
Bolt pattern. Should be something like 6x125 or 6x1.25, etc. If that
matches you're halfway there.
Likewise for Offset, but they should be close enough to work.
In the grand scheme fo things...
What difference does it make?
