98 camry won't stop - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2006, 11:48 PM   #1 (permalink)
nedliu@gmail.com
Guest
Posts: n/a
View nedliu@gmail.com's Photo Gallery
98 camry won't stop
My 98 camry can't stop when there is snow on the road surface--even
just a little. With speed less than 10 mile/per hour, I just can't
brake it to stop. I feel huge resistant when I brake. It like something
is pushing back. The brake works fine if there is no snow. The tires
are still in good shape. What is the possible culprit? TIA
Old 03-25-2006, 12:27 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 98 camry won't stop
<nedliu@gmail.com> wrote in message
news:1143262100.501804.239060@e56g2000cwe.googlegroups.com...[color=blue]
>[/color]
If the brake pedal is hard, then it sound like you are losing power assist.
It could be water or ice in the vacuum lines or stuck caliper slides. Get
your brakes checked by a professional ASAP.
Ray O
Old 03-25-2006, 04:05 AM   #3 (permalink)
n5hsr
Guest
Posts: n/a
View n5hsr's Photo Gallery
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:7a8db$4424d4eb$180fead6$1831@msgid.meganewsservers.com...[color=blue]
> news:1143262100.501804.239060@e56g2000cwe.googlegroups.com...[color=green]
>>[/color]
> assist. It could be water or ice in the vacuum lines or stuck caliper
> slides. Get your brakes checked by a professional ASAP.
> Ray O
>[/color]
Does it have ABS? I know my 95 Previa does. I get longer brake times on
ice, but not badly so.
Charles of Schaumburg
Old 03-25-2006, 05:33 PM   #4 (permalink)
Wolfgang
Guest
Posts: n/a
View Wolfgang's Photo Gallery
"Tires still good" --- if they are original they are 9 years old and the
rubber has hardened --- buy new ones that have a good wet/snow rating.
>[/color]
Old 03-26-2006, 05:18 PM   #5 (permalink)
nedliu@gmail.com
Guest
Posts: n/a
It does have a ABS.
n5hsr wrote:[color=blue]
> news:7a8db$4424d4eb$180fead6$1831@msgid.meganewsservers.com...[color=green]
> > news:1143262100.501804.239060@e56g2000cwe.googlegroups.com...[color=darkred]
> >>[/color]
> > Ray O
> >[/color]
> Charles of Schaumburg[/color]
Old 03-26-2006, 05:19 PM   #6 (permalink)
nedliu@gmail.com
Guest
Posts: n/a
Tires are 2.5 years old
Old 03-26-2006, 07:17 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
news:1143411595.522821.231710@i39g2000cwa.googlegroups.com...[color=blue]
>[/color]
If the ABS is activated, you may feel a slight vibration in the brake pedal
and hear the actuator whining under the hood. Age is not necessarily a good
indicator of tire condition. Tread depth on passenger car tires usually
start somewhere around 8/32" to 10/32". If you measure current tread depth,
you can get an idea of remaining life. Less than 4/32" will begin to
decrease traction in rainy and snowy conditions, and at 2/32" or less the
tires need replacement.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
Some questions - 98 Camry hugo 3rd & 4th Generation (1992–1996 & 1997–2001) 13 01-14-2005 03:31 PM
What OEM radio/cd for '98 Camry bnb1023 Audio, Video, and Security - Tech 0 01-05-2005 11:58 AM
98 Camry sway bars mjh1918 3rd & 4th Generation (1992–1996 & 1997–2001) 2 12-02-2004 02:37 AM
98 camry 5FSE to 3SGTE S13/R32 3rd & 4th Generation (1992–1996 & 1997–2001) 3 11-09-2004 08:56 PM
fitting for struct bar for 98 camry 6cyl toyocamboi 3rd & 4th Generation (1992–1996 & 1997–2001) 9 10-28-2004 11:53 AM
