02 Sienna brake noise (rear) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2006, 08:21 AM   #1 (permalink)
Paul
Guest
Posts: n/a
View Paul's Photo Gallery
I have taken this to the dealer twice and thay charge me $70 dollar a
pop.They put a break cleaner and lube kit to lower the noise. It works for
a week then comes back. I think the drum assemblies needs to be change.
What are your thoughts?....Paul
Old 03-26-2006, 09:08 AM   #2 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
Re: 02 Sienna brake noise (rear)
If you are talking about a high-pitched noise from the rear, then yeah,
Toyota has changed the drums for your van.
Another thing you can try that I've had luck with sometimes is placing a
WHOLE bunch of adhesive wheel weights on the backing plates of both drums.
I mean load them up. The extra weight should get rid of the vibration.
Sometimes it works, sometimes it doesn't, but thats what we were doing for
our customers before Toyota changed the drums.
Old 03-26-2006, 04:11 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"qslim" <Suckers@suckersdotcom> wrote in message
news:60b8aca9ba7c4ca047d297651b0bb9db@localhost.talkaboutautos.com...[color=blue]
>[/color]
Would peening the backing plates with a swing press/BFH so that it doesn't
resonate work? That was an effective method to stop heat shield vibrations.
Ray O
Old 03-27-2006, 07:39 PM   #4 (permalink)
qslim
Guest
Posts: n/a
Well, I don't think you'd wanna whack the backing plates with a hammer.
That is where the shoes rest, and you'd want it to be flat, otherwise you
could have other strange noises as well. We've had pretty good luck just
loading them up with weight.
Old 03-28-2006, 12:50 AM   #5 (permalink)
Ray O
Guest
Posts: n/a
news:593189696ec60b87ab6550d867b8f549@localhost.talkaboutautos.com...[color=blue]
>[/color]
Doh! I was ignoring the part about the drums and thinking about the backing
plate for disk brakes! Forget what I said about the "audio adjustment!"
Ray O
Old 03-31-2006, 08:10 PM   #6 (permalink)
Paul
Guest
Posts: n/a
Is a recall out on this or will I have to suck it up and pay to have the
drums changed out?....Paul
news:60b8aca9ba7c4ca047d297651b0bb9db@localhost.talkaboutautos.com:
[color=blue]
> yeah, Toyota has changed the drums for your van.
> placing a
> drums. I mean load them up. The extra weight should get rid of the
> vibration. Sometimes it works, sometimes it doesn't, but thats what we
> were doing for our customers before Toyota changed the drums.
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
just done my rear disc brake conversion now starts the problems gasman Archived Corolla threads 30 06-02-2006 02:39 AM
Rear Brake Valve Replacement spageroni 89-95 Toyota Pickup/Hilux 5 03-02-2006 02:31 PM
2005 Camry Rear Suspension Noise deban 5th & 6th Generation (2002-2006 & 2007-2011) 5 11-15-2004 04:55 AM
Break Noise from rear break(2000 Camry) abc_1126 3rd & 4th Generation (1992–1996 & 1997–2001) 5 10-10-2004 02:04 AM
