My replacement trans is acting up on my '85 Tercel wagon - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2006, 12:13 AM   #1 (permalink)
timagine@hotmail.com
Guest
Posts: n/a
View timagine@hotmail.com's Photo Gallery
I am suspicious that the $440 I paid for a trans replacement at the
junk yard was bogus, and that he never removed the old one, but flushed
it out.
Originally it was stuck in second gear. Now it doesn't often shift
into 3rd or 1st from 2nd.
I was told it probably has some dirt in it, and that I should bring it
in tomorrow so they can flush it out----possibly some more.
How can I assure myself that I have gotten a different trans? Scratch
something on the original one?
One thing I can imagine is, it would be pretty easy to tell if the
bolts have been removed recently.
Also, the fluid is up twice as high as it should be on the stick. When
I told him about it he laughed and told me it's a wives tale that the
seals can be blown; that it doesn't matter what the trans fluid level
is; he says it has a regulator for that.
voice from the past
Old 03-27-2006, 12:18 AM   #2 (permalink)
AirborneDSM
Guest
Posts: n/a
View AirborneDSM's Photo Gallery
Re: My replacement trans is acting up on my '85 Tercel wagon
dude its an 85, you should junk it!!!! its unsafe for u and if ur near me
while im driving, ur causing bad view of the freeway!
<timagine@hotmail.com> wrote in message
news:1143436430.295817.183210@i40g2000cwc.googlegroups.com...[color=blue]
> it out.
> voice from the past
>[/color]
Old 03-27-2006, 12:18 AM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
> it out.
> something on the original one?[/color]
The transmission should have a serial number stamped somewhere. Barring
that, I'd put a scratch on the case somewhere.
[color=blue]
> voice from the past
>[/color]
"Blown seals" won't necessarily make the transmission fluid level too high
on the dip stick. More likely, it was overfilled. It does matter what the
automatic transmission fluid (ATF) level is; it should at least be close to
the correct level on the dip stick.
Ray O
Old 03-27-2006, 12:39 AM   #4 (permalink)
Guest
Posts: n/a
Shut your stupid mouth.
Old 03-27-2006, 12:40 AM   #5 (permalink)
Guest
Posts: n/a
I mean, if it's too high the seals COULD blow.
voice from the past
Old 03-27-2006, 01:33 AM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:1143438003.409913.198850@v46g2000cwv.googlegroups.com...[color=blue]
> voice from the past
>[/color]
I have never heard of a high fluid level causing the transmission seals to
blow.
Synopsis from a Toyota repair manual: If the ATF level is too low, the oil
pump could draw in air and aerate the ATF. Aerated ATF lowers pressure,
causing damage to clutches and bands. If the ATF level is too high,
planetary gears and other rotating components agitate the ATF and aerate it,
causing the same problems as a level that is too low.
ATF level that is too high or to low causes insufficient pressure. Seals
"blow" from pressure that is too high, and seals can leak from normal wear,
contamination, or physical damage.
Ray O
Old 03-27-2006, 01:51 AM   #7 (permalink)
Guest
Posts: n/a
thank you, very much!
Old 03-27-2006, 02:00 AM   #8 (permalink)
Ray O
Guest
Posts: n/a
news:1143442287.194307.246810@z34g2000cwc.googlegroups.com...[color=blue]
>[/color]
You're welcome. good luck with the transmission!
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
...and now class...a brief history of the Tercel DuvalToyota Tercel, Paseo, Starlet, and Sera Forum 18 10-28-2010 02:43 PM
97 Tercel auto trans fluid capacities uptownwest Tercel, Paseo, Starlet, and Sera Forum 0 10-12-2005 01:40 PM
85 toyota tercel wagon cd player swiggyswag Tercel, Paseo, Starlet, and Sera Forum 0 07-05-2005 09:12 PM
Tercel 4WD wagon input shaft seal replacement happytrails Tercel, Paseo, Starlet, and Sera Forum 2 06-11-2004 07:46 PM
90 Tercel trans question shelbylancer Tercel, Paseo, Starlet, and Sera Forum 2 05-02-2004 09:56 PM
