97 corolla new brakes problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-27-2006, 10:03 PM   #1 (permalink)
Bhargava
Guest
Posts: n/a
View Bhargava's Photo Gallery
Hello,
I have a 1997 Corolla DX (1.8 liters). I got new brake pads installed
yesterday
and there is only a marginal improvement in braking. The brake pedal
still gets depressed
more than it would with new brakes on. While driving back from the
mechanic (NOT a large
store like Pep Boys, just a regular cheap shop in south Los Angeles) I
assumed there wasn't
enough heat/friction building up in the brakes yet so I let it go. But
I drove to work and
back today (almost 50 miles) and I was as apprehensive as I was before
I got the brakes fixed.
The car does not stop on a coin like new brakes should help it to, and
there's
no chance of going back to the mechanic for a refund. I did not get
brake fluid too, and I
don't know if that will fix my problem. A visual inspection after the
job was done looked like the
pads were indeed new.
Has anyone else had the same problem ever? Is there a fix that I can
implement with my rudimentary toolbox?
Any help is greatly appreciated.
Thank you,
Bhargava
Old 03-28-2006, 01:56 AM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 97 corolla new brakes problem
"Bhargava" <necrophobic@gmx.net> wrote in message
news:1143515029.233896.162510@i39g2000cwa.googlegroups.com...[color=blue]
> Hello,
> yesterday
> I drove to work and
> there's
> Thank you,
> Bhargava
>[/color]
If the brake pedal is very low to the floor, then it may need brake fluid or
if you have rear drum brakes, it may need the rear brakes adjusted.
Mis-adjusted rear brakes can also cause longer stopping distances. Another
possible cause of poor stopping ability is a stuck caliper slide bolt. All
of these items should have been checked by a competent technician.
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
05 Corolla starting problem phil 9th Generation (2003-2008) 676 04-07-2011 11:47 AM
99 Corolla intermittant starting problem wmcot Archived Corolla threads 9 05-18-2010 02:39 PM
can the 05 corolla starting problem hurt your engine??? Salduchi1785 Archived Corolla threads 9 03-29-2005 08:11 AM
03' Corolla S problem sick-boi Archived Corolla threads 3 03-01-2005 09:51 PM
ae92 corolla 91' problem help!! pcboy123 General Discussion 1 12-28-2004 04:08 PM
