Re: transmission rumble
<xenon66@gmail.com> wrote in message
news:1143671826.826215.93730@z34g2000cwc.googlegroups.com...[color=blue]
>I have a 1995 4 runner with auto transmission. When sitting idle or
> decelerating there is an audible rumble under the transmission. I took
> it to the shop and they said that drive shaft was bent and the
> compression plate holding it to the transmission was loose. They
> replaced the shaft and tightened the compression plate. Seemed like it
> was gone but in a couple hours I started to hear it again. The car
> drives fine and I have had very little problems with it. It still goes
> into 4 wheel just fine. Any ideas about the sound and if this is a sign
> of inevitable transmission failure?
> thanks.
>[/color]
Actually, the drive shaft (A.K.A. propeller shaft) is attached to the
transmission and differential by companion flanges. I can never remember
which way is the correct way without looking at the book, but it is possible
for the universal joints to be 90 degrees out of phase. The easiest correct
way to remove and replace a drive shaft and maintain the correct phase is to
mark the companion flanges so that they go back the correct way. Also, if
the drive shaft is out of balance, Toyota dealers sell weighted bolts for
the companion flanges. If the drive shaft was bent, then the engine,
transmission, and transfer case mounts and alignment should be checked.
As hachiroku mentioned, it is possible that the transmission or transfer
case output shaft bearing can be bad but I'd check stuff related to the
original driveshaft damage first.
Ray O
