'02 Highlander 'check engine' light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-29-2006, 06:31 PM   #1 (permalink)
love48
Guest
Posts: n/a
View love48's Photo Gallery
Hi all,
I have an '02 Highlander with almost 60K miles. Four days ago my
"check engine" light came on. I thought it was the gas tank cap so I
opened it up & tightend it. Still didn't go away. So last night my
brother took it to AutoZone for me to get the code & the
troubleshooting. This is what they gave him.
(1) Catalytic converter defective possibly due to #2, 3 or 4.
(2) Engine misfire or running condition
(3) Large vacuum leak
(4) Engine oil leakage into exhaust valve guide seal
I had planned to take into the shop tomorrow but when I turned on the
ignition to drive home from work today I saw that the "check engine"
light was gone! So what does this mean? There's no problem? Do I
still have to be concern with those troubleshooting or not anymore
since that light is gone? TIA for the help!
Old 03-29-2006, 06:44 PM   #2 (permalink)
---MIKE---
Guest
Posts: n/a
View ---MIKE---'s Photo Gallery
Re: '02 Highlander 'check engine' light
Last summer I had a CEL (01 Prism) and I replaced the gas cap. It took
several days before the CEL went out.
---MIKE---[color=blue][color=green]
>>In the White Mountains of New Hampshire
>> (44° 15' N - Elevation 1580')[/color][/color]
Old 03-29-2006, 09:07 PM   #3 (permalink)
love48
Guest
Posts: n/a
Could be the gas cap huh? Few months ago "check engine" light also
came on but after opening up the gas tank & tightened it it went away
after a few hours. But why wasn't that one of the diagnoses (or
however you would word it :)) if it was simply the gas cap?
<<Last summer I had a CEL (01 Prism) and I replaced the gas cap. It
took
several days before the CEL went out. >>
Old 03-29-2006, 10:57 PM   #4 (permalink)
skewe
Guest
Posts: n/a
View skewe's Photo Gallery
take it to toyota dealer and pull the code
cost $35
check out my camry
[url]http://www.golfer-review.com/m_toyota/camry.htm[/url]
Old 03-29-2006, 11:34 PM   #5 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
"love48" <kandle2075@hotmail.com> wrote in message
news:1143678660.011774.140950@j33g2000cwa.googlegroups.com...[color=blue]
> Hi all,
>[/color]
A loose gas cap is the most common cause of check engine lights coming on
but the trouble code has to do with the fuel tank evaporative emissions
system, which wasn't one of the codes listed. The system uses 2-trip
detection logic to determine whether to illuminate the check engine light
(actually called a malfunction indicator light, or MIL). 2-trip detection
logic means that the condition must be present or absent for 2 driving
cycles so if the condition is not present any more, the MIL will go off.
The actual trouble codes would have been more helpful than the descriptions
you gave because the standard On Board Diagnostics generation II (OBD II)
system does not have a trouble code for large vacuum leak or engine oil
leakage into exhaust valve guide seal. The OBD II codes will tell you which
catalytic converter is bad (a 4 cylinder has 1 converter and a 6 cylinder
has 2 converters) and will also tell you which cylinder or cylinder is/are
misfiring and how severely. There is also no code for a defective
converter - the code will say what the converter is not doing. A bad O2
sensor can give you a code that says that the catalytic converter operation
is below threshold.
The MIL can go out because someone cleared the trouble codes when they
pulled them or because the condition is intermittent (2 trip detection
logic) or the condition is gone.
For now, don't worry, and if the MIL comes on again, take it to a dealer.
Some emissions components are covered for up to 80,000 miles in the U.S.
Ray O
Old 03-30-2006, 09:44 AM   #6 (permalink)
Mike Hunter
Guest
Posts: n/a
View Mike Hunter's Photo Gallery
The check engine light will illuminate when the process controller can not
keep the fuel/air ratio within it design parameters. Something as simple as
a fouled plug can be the cause. If the fault clears itself after a
predetermined number of restarts, the light will go off. At that mileage a
temporary glitch, like a piece of carbon, was the most likely scenario. Not
to worry, if it happens again take the vehicle to a dealership for
correction, WBMA
mike hunt
> Hi all,
>[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
Traction Light with P0135 check engine code fincobbler Solara 8 05-01-2008 07:51 AM
Traction Light with P0135 check engine code fincobbler Solara 1 02-17-2006 08:50 PM
Gen 1 - Gen 5.5 massive compile of bulb info ASG14 1st & 2nd Generation (1983–1986 & 1987-1991) 20 01-03-2006 03:51 PM
Check Engine Light Jal4950 Archived Corolla threads 12 09-11-2004 11:32 AM
02 check engine light italia490 5th & 6th Generation (2002-2006 & 2007-2011) 3 02-27-2004 09:41 PM
