I have a 1994 Tercel that a friend asked me to sell. It is making a loud
tapping
noise that is coming from the valve cover, it sounds exactly like a stuck
hydraulic
lifter. However in my research this car has the 3EE engine which has no
lifters?
I'm guessing it is just that it needs a valve adjustment, the engine also
idles rough
like it has a cylinder miss, and that cooresponds with the frequency of the
tapping.
Plugs on this were oil fouled and it failed emissions with high THC of
2.48 g/mi MAX
and very low CO, of about 3.4 g/mi MAX, I replaced the plugs and put new
wires, cap
& rotor on it, it still fails with high THC which is now 4.2 g/mi but the CO
has gone up
to a more normal 26.4 g/mi
Apparently the owner got it to pass inspection for the last 2 or 3 times
by
replacing spark plugs and pouring in a bottle of drygas to the fuel tank.
Unfortunately the owner (like a lot of people planning to sell a car)
pretty much
ignored maintainence on it, it was low on oil and the oil was pretty black,
I changed
it. The oil level is at the F mark and the tapping noise started up about 3
miles
after changing the ignition components and about 40 miles after changing the
oil.
At least the engine did stop smoking after changing the ignition components.
I'm pretty much at the end of what I want to spend money on it, so
suggestions
like replacing the head is pretty much out. The new owner can do that.
Would
there be a chance of getting rid of the tapping noise with a valve
adjustment or
getting it past emissions?
"Toyota Questioner" <toyquestions@toyota.com> wrote in message
news:newscache$p5dxwi$q7x1$1@news.ipinc.net...[color=blue]
> Hi All,
> tapping
> hydraulic
> lifters?
> idles rough
> the
> tapping.
> 2.48 g/mi MAX
> wires, cap
> CO
> has gone up
> by
> pretty much
> black,
> I changed
> 3
> miles
> the
> oil.
> components.
> suggestions
> Would
> adjustment or
> Mr. Question
>[/color]
There was a stretch where Tercels had electronic carburetors which were very
finicky and almost not worth trying to fix. I don't know if this Tercel is
one of them or is fuel injected. The fuel injected ones were reliable but
ones with electronic carbs could cause the emissions failures. The Tercels
with the electronic carbs were also prone to carbon buildup that was cleaned
with a walnut shell blast. Also, the chances of passing emissions are
better if you take the car out on the highway and give it a chance to "clear
its pipes."
Toyotas tend to run a lot better on OEM ignition components - some
aftermarket ones cause drivability problems.
Since the owner is getting rid of the car, try running some engine flush
through and changing the oil again and see if that quiets the tapping sound.
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:3413a$442b720e$180fead6$17384@msgid.meganewsservers.com...[color=blue]
> news:newscache$p5dxwi$q7x1$1@news.ipinc.net...[color=green]
> > Hi All,
> > I have a 1994 Tercel that a friend asked me to sell. It is making a[/color][/color]
loud[color=blue][color=green]
> > tapping
> > noise that is coming from the valve cover, it sounds exactly like a[/color][/color]
stuck[color=blue][color=green]
> > hydraulic
> > lifters?
> > I'm guessing it is just that it needs a valve adjustment, the engine[/color][/color]
also[color=blue][color=green]
> > idles rough
> > the
> > tapping.
> > 2.48 g/mi MAX
> > wires, cap
> > & rotor on it, it still fails with high THC which is now 4.2 g/mi but[/color][/color]
the[color=blue][color=green]
> > CO
> > has gone up
> > Apparently the owner got it to pass inspection for the last 2 or 3[/color][/color]
times[color=blue][color=green]
> > by
> > replacing spark plugs and pouring in a bottle of drygas to the fuel[/color][/color]
tank.[color=blue][color=green]
> > pretty much
> > black,
> > I changed
> > it. The oil level is at the F mark and the tapping noise started up[/color][/color]
about[color=blue][color=green]
> > 3
> > miles
> > the
> > oil.
> > components.
> > suggestions
> > Would
> > adjustment or
> > Mr. Question
> >[/color]
> There was a stretch where Tercels had electronic carburetors which were[/color]
very[color=blue]
> finicky and almost not worth trying to fix. I don't know if this Tercel[/color]
is[color=blue]
> one of them or is fuel injected.[/color]
It is fuel injected.
[color=blue]
> better if you take the car out on the highway and give it a chance to[/color]
"clear[color=blue]
> its pipes."
>[/color]
You mean, run it at high speed to get the cat good and hot, that is
generic advice for any emissions check and I tried that the first time
I tried getting it through emissions.
[color=blue]
>[/color]
I'll be sure to pass that info along to NAPA which is where I bought
the Napa/Echlin cap and rotor, and the Beldin Blue Max plug
wires, all of which looked identical to the OEM parts on the car.
Can we have a show of hands of everyone who thinks NAPA parts
are not as good as OEM parts?
Come off it, give me a break, I'm not a complete newbie
at this. And the spark plugs I used are the NGK parts listed as
recommended in the owners manual. I also replaced the PCV valve
and air filter.
[color=blue]
> through and changing the oil again and see if that quiets the tapping[/color]
sound.
If these are solid lifters or no lifters at all, how will engine flush make
any difference? I actually did buy a bottle of engine flush, the kind
you use right before changing the oil, before I discovered that they
might be solid lifters.
> very[color=green]
> is[color=green]
>[color=green]
>> a chance to[/color]
> "clear[color=green]
>> its pipes."
>>[/color]
> that is generic advice for any emissions check and I tried
> that the first time I tried getting it through emissions.
>[color=green]
>> components - some aftermarket ones cause drivability
>> problems.
>>[/color]
> I bought the Napa/Echlin cap and rotor, and the Beldin Blue
> Max plug wires, all of which looked identical to the OEM
> parts on the car. Can we have a show of hands of everyone
> who thinks NAPA parts are not as good as OEM parts?
> listed as recommended in the owners manual. I also
> replaced the PCV valve and air filter.
>[color=green]
>> some engine flush through and changing the oil again and
> sound.
> engine flush make any difference? I actually did buy a
> bottle of engine flush, the kind you use right before
> changing the oil, before I discovered that they might be
> solid lifters.
>[/color]
Hey Bozo:
You asked some questions & Ray gave some good answers &
advice.....Where do you get off having an attitude about what he
said.
Actually you probably have a stuck valve. Very common on this
era Tercel when not maintained properly. You'll need to pull the
head to make necessary repairs to pass inspection. Been
there\done that.
dc
"doncee" <nodbcspam9814wanted@charter.net> wrote in message
news:Xns979616A4591C3medbcSWBEll@216.196.97.131...[color=blue][color=green][color=darkred]
> > very[color=darkred]
> > is[color=darkred]
> >[color=darkred]
> >> a chance to[/color]
> > "clear[color=darkred]
> >> its pipes."
> >>[/color]
> >[color=darkred]
> >> problems.
> >>[/color]
> >[color=darkred]
> > sound.
> > solid lifters.
> >[/color]
> Hey Bozo:
> said.[/color]
I don't.
The question asked was how difficult a valve adjustment on
this engine would be, and if that would make a difference in
emissions. Neither was answered. The advice on the engine
flush was not bad, although I had already known it, it would
have probably been prudent to add that this is a last ditch
attempt, although a number of the engine flush products on the
shelves already say that right on the bottle.
Now as far as the rest goes, well the year of the vehicle was
supplied, a few minutes looking via Google would have established
that this year engine did not have a carburetor, which would have
taken less time than typing in a whole raft of advice for a
carbureted car. I also don't appreciate the knee-jerk response that
dealer-supplied parts are automatically "better" that seems to
go on in a lot of forums - that is nothing more than FUD and
baloney, since most times the dealer parts are OEMed by the
same manufacturers that make the aftermarket stuff.
Sure, there's some really cheapo crap out there - just visit your
nearest Autozone and you can ask for their "inexpensive" stuff and
gamble it might work. But if your going to slam "some" aftermarket
parts then you better start naming names. It is not fair to many
of the aftermarket suppliers who do make good parts to be
tarred by the same brush.
[color=blue]
> there\done that.[/color]
Thank you, that is very helpful. The only correction I would make
is that the new owner will have to pull the head, assuming that the
engine flush thing doesen't work. My experience with stuff like the
engine flush thing is that they usually don't, but it's worth a try for
the cost. And if I had known just how poorly the owner had
maintained this car I wouldn't have even wasted the time opening
the hood. The whole point in getting an emissions pass was to
add some value to this before selling it, but it looks like the advice
of "no good deed goes unpunished" applies for this one.
You really need to take the good advice of using OEM parts, not only on
Toyotas but also on GM and possibly other makes. The difference is that
part for part, the Toyota ones will typically be more reasonably priced than
other OEMs. Especially when it comes to ignition, brake and other
driveability related parts. The question is, do you want to work on your
car, or do you want to fix it?
Also true is the fact that your valve noise is most likely due to a sticking
valve, not just an adjustment. While changing the oil is always a good
idea, it will generally not correct this problem by itself. You may be
lucky enough to be able to remove the valve cover, remove the cam
follower/rocker arm for the affected valve, and then spray it heavily with
Gumout or other strong solvent while working it up and down. Be careful
when doing this to not apply any side pressure, since the valve stems are of
small diameter and will bend easily. Once you get it as free as possible,
reassemble and run the engine for 5 minutes. Then change the oil and
filter. If this does not correct it, then it will reply require pulling the
head to correct permanently.
Lee Richardson
Mech-Tech
Evansville, Indiana
>>[/color]
> and air filter.
>[color=green]
> sound.
> make
>[/color]
news:newscache$etjxwi$bhx1$1@news.ipinc.net...[color=blue]
> news:3413a$442b720e$180fead6$17384@msgid.meganewsservers.com...[color=green]
>> news:newscache$p5dxwi$q7x1$1@news.ipinc.net...[color=darkred]
>> > Hi All,
> loud[color=green][color=darkred]
>> > tapping
> stuck[color=green][color=darkred]
>> > hydraulic
>> > no
>> > lifters?
> also[color=green][color=darkred]
>> > idles rough
>> > the
>> > tapping.
>> > 2.48 g/mi MAX
>> > new
>> > wires, cap
> the[color=green][color=darkred]
>> > CO
>> > has gone up
> times[color=green][color=darkred]
>> > by
> tank.[color=green][color=darkred]
>> > pretty much
>> > black,
>> > I changed
> about[color=green][color=darkred]
>> > 3
>> > miles
>> > changing
>> > the
>> > oil.
>> > components.
>> > suggestions
>> > Would
>> > adjustment or
>> > Mr. Question
>> >[/color]
> very[color=green]
> is[color=green]
>[color=green]
> "clear[color=green]
>> its pipes."
>>[/color]
> I tried getting it through emissions.[/color]
Sory, I didn't mean to imply that you did not know what you were doing, but
there are a lot of people who are not aware of this simple trick, so I put
it out there.
[color=blue]
>[color=green]
>>[/color]
> and air filter.
>[/color]
Obviously, the NAPA folks are going to say that the stuff they sell is as
good as OEM parts, and the folks at Toyota will say that the OEM parts are
better. I'm not totally against aftermarket parts; I've used them many
times. I doubt if the PCV and air filter have any bearing on the emissions
failure.
I have a fair amount of experience dealing with Toyotas, and in that
experience, I have seen *some* aftermarket ignition parts cause driveability
problems that were cleared up when replaced with OEM parts. NGK is an OEM
supplier to Toyota, and assuming the store gave you the correct application,
they should not be a problem. The aftermarket cap, rotor, and wires may or
may not be the cause of the problem.
The high hydrocarbon numbers imply incomplete combustion, which is why I
would look at the ignition system if it was me working on the car.
If it is fuel injected, a leaking injector or poor spray pattern may also
cause incomplete complete combustion. The correct method for checking
injectors is to remove them and install them in the SST injector checker and
check the spary pattern. Few people have one of these SST's at home, so you
can try a bottle of Chevron Techron or Toyota branded fuel injector cleaner
and see if that makes a difference.
> sound.
> make
>[/color]
If the car has solid lifters or no lifters, an engine flush probably won't
make a difference in the tapping noise. If it has hydraulic lifters or
hydraulic timing belt tensioner, it may make a difference. The cost and
effort for doing one of those pre-oil change flushes is very low, nothing
ventured, nothing gained, which is why I recommended it.
If the engine uses shims to adjust valve clearance, then adjustment is a
pain because you'll need an assortment of shims to get it right.
news:newscache$rjsxwi$ftx1$1@news.ipinc.net...[color=blue]
> news:Xns979616A4591C3medbcSWBEll@216.196.97.131...[color=green][color=darkred]
>> > very
>> >> if this Tercel
>> > is
>> >> a chance to
>> > "clear
>> >> its pipes."
>> >> problems.
>> > sound.
>> > solid lifters.
>> >[/color]
>> Hey Bozo:
>> said.[/color]
> I don't.
> shelves already say that right on the bottle.[/color]
Yup, you're right about not getting a direct answer to your question - sorry
about that ;-)
I did try to give more direct answers in my other follow-up post.
[color=blue]
> carbureted car.[/color]
Yes, I could have spend a little more time researching, but it was late at
night and my intent was to try to help by giving a quick answer before I
went to bed.
I also don't appreciate the knee-jerk response that[color=blue]
> tarred by the same brush.[/color]
That was not a knee-jerk response regarding aftermarket parts. I
specifically mentioned *some ignition* parts. It is generally not my style
to badmouth any particular brands, and I'm not going to say that all
aftermarket ignition parts for all Toyotas are bad. I have seen Champion,
Delco, and Napa branded ignition parts cause ignition problems in Toyotas,
and I've seen them work satisfactorally. The reason I recommend OEM
ignition parts in Toyotas is because of this hit-or miss (no pun intended)
experience with aftermarket ignition parts.
[color=blue]
>[color=green]
>[/color]
I knew about the stuck valves on this vintage Tercel and completely forgot
about it when responding - I apologize for blowing it on the valves.
news:3a80c$442c1d59$44a4a10d$23551@msgid.meganewsservers.com...[color=blue]
>[/color]
[color=blue]
> about it when responding - I apologize for blowing it on the valves.[/color]
Hi Ray,
No, my apologies, you were right to mention the cat trick since
other readers may be helped. I was just irritated with this stupid car
situation, the friend that owned this vehicle went and moved and
couldn't take it, so I offered to sell it.
If I had known how badly it was maintained I would have kept my
mouth closed. Even on my old cars that I've sold before for $500
were maintained better than this! I guess I've learned that you cannot
judge how well anyone takes care of their cars just by knowing them.
I bought a can of Seafoam and I'll try that before the pulling the
valve cover and working it with gumout and pliers. I am pretty
sure if I got the valve working it would in fact pass, the two emissions
reports from the two times I've tried to pass it were very revealing. The
first attempt had extremely low CO and high HC, the second has normal
CO and high HC. The valve wasn't sticking during the first test, or if it
was it was so quiet about it that I couldn't tell. The first report was
textbook misfiring, the second report really indicates a sticking valve,
as a non-firing cylinder will dump a bunch of HC into the exhaust. The
valve started sticking wthin 20 minutes of replacing the plugs and
ignition, so obviously what was going on here is that with the fixed
ignition, now the cylinder was actually firing all the time, so the cylinder
temps were actually up where they were supposed to be, that probaby
startd cooking all the sludge and crap in the combustion chamber and
on the valve stems, so now instead of slimy gooy crap on the valve
stem I had hard baked on crap, and the hard baked on crap jammed
the valve open.
The other thing that sucked was the ignition wires and cap and rotor
totaled $70 from NAPA, who was the only place that actually stocked
them. If the valve had been sticking before buying those parts I would
never
have bought them and just sold the car as it was, and if the buyer had
insisted on taking it through emissions before purchase, then oh well,
knock off $300 from the price. Now, with the valve making noise,
my friend will lose more than $300 on this unless I do something
about it, so as they say I'm stuck. I can easily see that what is the most
likely outcome here is that eventually I'll either get it to pass or get
it quiet again, and all the effort on it to get a good emissions report will
not add nearly enough to the sale price for it to have been worth all the
screwing with it I'm going to end up doing.
news:newscache$08j0xi$nz22$1@news.ipinc.net...[color=blue]
> news:3a80c$442c1d59$44a4a10d$23551@msgid.meganewsservers.com...[color=green]
>>[/color]
>[color=green]
>> forgot
> Hi Ray,
> cylinder
> the valve open.
> never
> most
> will
> Ted
>[/color]
Ted,
I don't have any personal experience with Sea Foam but I've read good things
about it in this ng. Some technician friends have mentioned that Motor-Vac
also works well but that involves finding a facility that has invested in
the equipment. At one time, Toyota dealers had to invest in a walnut-shell
blaster to fix carbon buildup problems with Tercels. I don't know if the
setup would work on this Tercel or not and the service is fairly expensive.
Since this is a car you're just getting rid of, I'd just give the Sea Foam a
shot and get rid of the car so you don't have to invest more time, money, or
sleep in it.
"Lee Richardson" <mechtech@sigecom.net> wrote in message
news:LdSdnXDUsrPPQbbZRVn-tw@sigecom.net...[color=blue]
> part for part, the Toyota ones will typically be more reasonably priced[/color]
than[color=blue]
>[/color]
Well here's kind of how I look at that. Yes, every once in a while you
come across an OEM part that is cheaper. For example, take an
EGR valve for a Chrysler 3.3L, it is about $60 from the dealer,
about $65-70 from aftermarket. But, for every once of those rareities
the dealer sells hundeds of other parts that the aftermarket does where
the dealers really stick it to you. So I have pretty much decided that
the aftermarket is going to get all my business unless there is a part that
is so horribly designed (like a motor mount for the above mentioned
Chrysler engine) that it is obviously substandard. And I'm very willing
to pay a few bucks extra for 1 part out of a bag of 20 that I'm buying from
a place like NAPA than what the dealer would charge, because I'm
still saving -overall-.
If there was a local dealer in the area that had -reasonable- pricing and
return policies I would frequent them. But, all of them sell the
manufacturers
parts at far above what I can find those same manufacturers parts for
online,
even including shipping, and all of the dealer parts departments in the area
do not take
returns -at all- even if the part was -never- used, never taken out of the
box or
the bag, not gotten all greasy, and returned the day after I bought it.
This
pretty much reduces you to the practice of starting the repair, then getting
everything apart and taking the defective part into the dealer, even when
you
know what you need in advance (such as brake pads) because there is always
the chance that some slight change in the part will cause trouble. That can
turn
an hour brake job into a 3 hour brake job, and forget doing anything on
Saturday
since all the dealer parts places are closed after 1:00pm Sat, and none open
Sunday.
I had one dealer once, Nissan it was, who I ordered a part from, and it came
a week later
and was all filthy and greasy, clearly was used, (not worn, just used, they
must
have tried using it and found it was the wrong one or something) and they
would
not order another one, and told me that the part was fine and to just take
it
and basically shut up about it. I did force them to write a note for me
guarenteeing
that I could return the part if I found out later it was damaged.
And as for buying the factory OEM parts online, well that's fine if you
know in advance exactly what you need. It's not fine if you are 3/4 the way
through
a project and discover something broken that was covered up, or some such.
And while the online people seem to have reasonable return policies, you
have to
pay to ship it back.
[color=blue]
> Also true is the fact that your valve noise is most likely due to a[/color]
sticking[color=blue]
> when doing this to not apply any side pressure, since the valve stems are[/color]
of[color=blue]
> filter. If this does not correct it, then it will reply require pulling[/color]
the[color=blue]
>[/color]
I will try that if I have to, in these sticking valve situations does the
valve
usually stick below the level of the piston head, this is an interference
engine
I think ( 3E-E)
Good morning, TQ.
Most recent bad experience with NAPA was a cap, rotor, plugs and wires for a
'97 Chevy pick up with the 4.3 liter V6. Complaint was rough running
especially on the first start of the day and when it was damp or rainy out.
Trouble was the same or maybe a little worse with the NAPA parts, but went
away entirely when a new cap and rotor from the dealer was installed. And
in my opinion, NAPA is the best of the aftermarket suppliers. Anymore, all
parts are expensive, so in my opinion it is worth the extra to get the OEM
part and pretty well be assured that it is the best available for the
application. Now if I ran a service facility and -knew- a given
aftermarket part would work well in a given application for a lower price, I
would go with it. But the cars I drive anymore are so reliable, and the
number of parts I need is so small, that for me it makes more sense to go
with the OEM. I have even in some cases started letting the dealer take
care of some things I used to do myself. Again, more money, and the hassle
of taking it in, but I have had very good experience of them doing it right
the first time.
I am not sure if your engine is an interference design or not. I know the
earlier models were not, that was in my opinion one big advantage that
Toyota had over Honda. But if yours is an interference design, then yes,
the piston may well be kissing the valve. The good news is that all that is
holding it open is the sticky goo, not the actual cam and valve train as
would be the case with a broken timing belt. So the chance of damage will
be reduced the sooner you can get it freed up. If the car has been sitting
a long time and there is old gas in the tank, it can cause this sticking
problem. Once you get the valve free, fresh oil in the crankcase, and nice
fresh gas coming through, the problem will probably be solved.
As for returning parts, that just is not cool unless they give us an
incorrect or truly defective one. First, if they take back returned parts,
that means they sell parts that have possibly been in someone elses
possession. For example, even if somebody returned that bad NAPA
distributor cap I had unopened, there is still nothing saying it could not
have been dropped or otherwise damaged by the original purchaser. Second,
returned parts drive up prices for everyone else due to the extra handling,
etc. required.
Lee Richardson
Mech-Tech
news:newscache$6qk0xi$l132$1@news.ipinc.net...[color=blue]
> news:LdSdnXDUsrPPQbbZRVn-tw@sigecom.net...[color=green]
> than[color=green]
>>[/color]
> that
> from
> manufacturers
> online,
> area
> do not take
> box or
> This
> getting
> you
> can
> turn
> Saturday
> open
> Sunday.
> came
> a week later
> they
> must
> would
> it
> guarenteeing
> way
> through
> have to
>[color=green]
> sticking[color=green]
>> with
> of[color=green]
>> possible,
> the[color=green]
>>[/color]
> valve
> engine
> I think ( 3E-E)
>[/color]
news:mcGdnbsYa_G38rPZnZ2dnUVZ_t6dnZ2d@sigecom.net...[color=blue]
> incorrect or truly defective one. First, if they take back returned[/color]
parts,[color=blue]
> returned parts drive up prices for everyone else due to the extra[/color]
handling,[color=blue]
> etc. required.
>[/color]
I don't agree with this but there are caveats. First let's talk about the
kind of returns I'm talking about. There's 4 kinds of common legitimate
returns of auto parts out there:
1) Defect, part installed, found to be non-working. Common on
stuff like rebuilt alternators, water pumps, etc. (why you should
always have the rebuilt alternator tested on their testing machine
before you leave)
2) Warranty returns - part fails within warranty period. For example
a new radiator starts leaking.
3) Didn't need it - purchaser buys part in advance thinking they will
need it for a job, turns out they didn't need it.
4) Wrong part - part sold to the purchaser based on a cross reference
out of a book and purchaser goes to install the part and finds out
it doesen't fit, or nearly fits but not quite, etc. Common with
stuff like aftermarket fuel pumps, generic one size fits all filters, etc.
Then there's 2 kinds of illigitimate returns, I am not talking about
these since it's a given that they drive up prices for everyone:
1) Scams where the buyer substitutes the replaced part with a
broken one out of the vehicle and tries to return it.
2) Shotgunners who don't know how to diagnose problems and
just are guessing, so buy part after part, trying them out until they
hit the broken one.
I don't see how returns 1-4 will drive up prices. For #1 & #2,
the manufacturer bears the cost, and furthermore those returns
are very important because they tell the manufacturer if there's
an inherent defect in their part, they can then fix that. For #3, once
again that isn't a problem because the retailer just reshelves the
part and sells it to someone else, and the retailer is happy to
do this because they make a profit on the parts that the buyer used.
For #4, well that's something the manufacturer and the retailer
can work out. If the manufacturer is for example shipping fuel
pumps that are supposed to work on years 75-85 GM,s and
they only work on years 75-80 GM's due to a change GM made
in 81, well the manufacturer needs to know this so they update
their cross reference, and the retailer can then either hang on to
the pump and sell it to someone with a 75-80 GM that needs a
pump, or return it to the manufacturer who can sell it to another
retailer. In #4, the problem is a manufactures problem anyway
since they put out the invalid cross reference, and they should
eat the cost of the part.
And as for the idea that with #3 the purchaser might have dropped
the part and damaged it, well the retailer needs to employ decent
people who actually look at the stuff coming back for defects
like cracks and damage that might have occurred from dropping.
And the truth is that ALL part sale prices have a built in allowance
for shipping damage. The truth is that a lot of times shipping damage is
latent, and your not going to find it out until much later. All of
the major shippers allow you to make shipping damage claims, but
they all restrict claim periods to 24 hours after receipt, or other
similar rediculous stuff, and the manufacturers as a rule don't pay
shipping damage claims, so the retailer usually gets stuck with these.
But the manufacturers can get stuck too, since a retailer can still
return a shipping damage part to the manufacturer claiming it's
an inherent defect, and the manufacturer cannot generally prove
otherwise. Shipping damage on a certain percentage of parts is
really unavoidable, and it is so difficult to figure out who did it,
that it is rare for the insurers to get stuck with the bill, although
they are the ones who really should be. The chances that a purchaser
who returned a #3 part damaged it in transport and didn't get it
detected by the retailer are small enough that it's not really of
much account.
Granted, the scammers #3 and #4 cost everyone money, but
good staff at the parts counter can catch on to this pretty quick,
and in any event, ultimately the retailer always has the ability to
refuse to accept a return, even one that is within their policy. I
have been in a parts store and heard that happen over a battery
before, the retailer refused to take it back even though it was
within warranty, because their battery tester said it tested out good.
The customer was pissed, as you might imagine, and was yelling.
And as for extra andling, that is baloney. Both the dealer parts
counter and the auto part store are NOT busy every minute of
the day, they have dead time. During this dead time they can
work on their returns, they do not have to waste it on blabbing
to each other about the latest basketball scores.
The problem, if you think about it, is that the dealer parts counters
and the auto manufacturers have much less incentive to take
returns back for the following reasons:
With #1 & #2, well the auto manufacturer bears the cost of the
part, the dealer parts counter takes no loss on it, as it should be.
However there is one difference - the dealer parts counter can't
buy from anyone other than the manufacturer, so they don't care
if a particular part keeps coming back over and over with the
same problem. That is a big issue with me since it removes the
incentive to improve parts, since the manufacturer knows they
can blow out their crap stock even if they redesign the part,
and still get paid for it.
With #3 and #4 well here's the problem. If it's a common part,
then the dealer parts counter is going to be able to sell it again,
so they don't lose. But if it's not common, perhaps it's something
like a custom-bent breather hose, well only the manufacturer really
has any chance of selling it to someone else, and they don't allow
dealers to return these.
The aftermarket doesen't seem to have a problem with taking returns
back unless it's a cut item, like a length of hose (which should be
obvious) or with some retailers, electrical parts. Yet their prices
are lower mostly than the dealer parts counter, which doesen't take
returns.
So I really think your statement about returned parts driving up
prices is incorrect for the aftermarket, but not for the dealer parts
counter, for the simple reason that the manufacturers will not
take parts back from the dealers unless it's warranty defect
return.
To give you an example one time I ordered a motor mount
bracket for a chrysler. The dealer required me to put money
down in advance which I did. The part arrived and I went to
get it but took the old bracket. When I got there I found the
old bracket had a machined area that the new bracket did not
have, the auto manufacturer had made a change but had not
updated their computer. So I demanded, and got, my money
back. (and had my old bracker welded by a local welder)
Well that is going to drive up prices at that dealer parts counter
and do you know why? Because the dealer is now stuck with
this $80 bracket. They are likely never going to sell it to anyone else
because it is so specialized, it is a bracket that rarely breaks,
and it the auto manufacturer isn't going to take it back because
there is nothing wrong with it.
And who is to blame for returns driving up prices at the dealers?
I'll tell you, it's the auto manufacturers.
To give you one more example, a number of years ago I owned an
olds that had an intermittent starting problem. I knew the problem
was in the ignition switch so I went to GM and bought an ignition
switch for it before tearing into it, because it was my only car and
it's kind of hard to drive to the parts store with the steering column
torn apart. Well there were two different kinds of ignition switches
for this, one was for the tilt column, the other was for non-tilt. The
GM parts counter did not ask if I had tilt or not, and sold me the
non-tilt switch. When I got into the column, I discovered that the
link mechanism inside the column was cracked, not a broken
switch. So I ended up having to take a bus back to the dealer,
get the link (part of a kit, as a matter of fact since this was a common
failure) come back, put it into the column. I then figured since I
had the new switch I might as well install it even through the old one
was good, just for reliabilities sake, that is when I found the
difference in switches, when I took the old one out.
So I took the new switch back. it was -still- in the bag, which
was a sealed bag. Never opened. The dealer refused to take it
back since it was an electrical part. That was a $45 switch. I
know perfectly well why they didn't want to take it back - because
they knew that 90% of the cars out there were sold with tilt,
and the ignition switches rarely fail. So they would probably have
not been able to sell it. The manufacturer would have been able to -
but they don't take them back.
One last thing I will point out, Nissan. Nissan's dealers parts counters
are all linked together, and dealers can order parts from each other
if Nissan does not have the part in their warehouse (obsoleted or
some such) This at least helps the dealers from getting stuck with
dead inventory. So at least one auto manufacturer is coming into
the 20th century. But Nissan dealers are still using the same bullcrap
return policieis.
[color=blue]
> Lee Richardson
> Mech-Tech
> news:newscache$6qk0xi$l132$1@news.ipinc.net...[color=green]
> > news:LdSdnXDUsrPPQbbZRVn-tw@sigecom.net...[color=darkred]
> >> Toyotas but also on GM and possibly other makes. The difference is[/color][/color][/color]
that[color=blue][color=green][color=darkred]
> > than[color=darkred]
> >> driveability related parts. The question is, do you want to work on[/color][/color][/color]
your[color=blue][color=green][color=darkred]
> >>[/color]
> > that
> > from
> > If there was a local dealer in the area that had -reasonable- pricing[/color][/color]
and[color=blue][color=green]
> > manufacturers
> > online,
> > area
> > do not take
> > returns -at all- even if the part was -never- used, never taken out of[/color][/color]
> > box or
> > This
> > getting
> > everything apart and taking the defective part into the dealer, even[/color][/color]
when[color=blue][color=green]
> > you
> > know what you need in advance (such as brake pads) because there is[/color][/color]
always[color=blue][color=green]
> > can
> > turn
> > Saturday
> > open
> > Sunday.
> > came
> > a week later
> > they
> > must
> > have tried using it and found it was the wrong one or something) and[/color][/color]
they[color=blue][color=green]
> > would
> > not order another one, and told me that the part was fine and to just[/color][/color]
take[color=blue][color=green]
> > it
> > guarenteeing
> > way
> > through
> > a project and discover something broken that was covered up, or some[/color][/color]
such.[color=blue][color=green]
> > have to
> >[color=darkred]
> > sticking[color=darkred]
> >> valve, not just an adjustment. While changing the oil is always a[/color][/color][/color]
good[color=blue][color=green][color=darkred]
> >> with
> >> Gumout or other strong solvent while working it up and down. Be[/color][/color][/color]
careful[color=blue][color=green][color=darkred]
> >> when doing this to not apply any side pressure, since the valve stems[/color][/color][/color]
are[color=blue][color=green]
> > of[color=darkred]
> >> possible,
> >> filter. If this does not correct it, then it will reply require[/color][/color][/color]
pulling[color=blue][color=green]
> > the[color=darkred]
> >>[/color]
> > I will try that if I have to, in these sticking valve situations does[/color][/color]
> > valve
> > usually stick below the level of the piston head, this is an[/color][/color]
interference[color=blue][color=green]
> > engine
> > I think ( 3E-E)
> >[/color]
>[/color]
news:newscache$7by1xi$k51$1@news.ipinc.net...[color=blue]
> news:mcGdnbsYa_G38rPZnZ2dnUVZ_t6dnZ2d@sigecom.net...[color=green]
> parts,[color=green]
>> not
>> Second,
> handling,[color=green]
>> etc. required.
>>[/color]
> before you leave)
> hit the broken one.
> much account.
> and still get paid for it.[/color]
I don't know about other manufacturers, but Toyota does make production
changes if a particular part experiences a high failure rate, whether sold
over the counter, through the service department, or installed as original
equipment. Auto manufacturers actually have a greater incentive to improve
parts because they must pay the dealer his retail labor rate to repair or
replace a defective part installed by the dealership.
[color=blue]
> dealers to return these.[/color]
Dealers are allowed to return up to 10% of their annual stock purchases to
the manufacturer for credit, so if a dealer orders a muffler or bent
radiator hose for a 1980 Corolla on a regular weekly stock order and it
doesn't sell, it can be returned under the 10% program.
Dealers will not take returns on some parts unless they are defective,
including special order parts because they do not count towards the 10%
credit; electrical parts because of the difficulty in telling if it has been
installed or not; and parts that have been installed on a vehicle (unless it
is defective).
Dealers will take returns on parts that they normally stock.
Update on the Toyota Tercel:
Tapping noise was caused by a spark plug wire that fell off - boy I feel
dumb - I remember though when pushing it down, not feeling the "click" of
a positive connection, but I figured it wasn't a problem - it was. When
reconnected
the plug wire, tapping noise disappeared.
I "decarbonized" ie: flushed the engine with Seafoam.
As for the emissions reports, the HC is worse now, and the CO is still low.
The
engine does idle a smoother, however, and has more power on the highway
at cruising speed.
My take on it and knowing the history is that the valve guide seals probably
started
leaking at the 80-90K mile mark, the engine has 140K on it now. I think
that by now
the catalyatic converter has had so much burned oil dumped down it that it
is now shot.
And the valve guide seals are probably leaking a lot worse now than they
were when they
started leaking, to the point that so much oil is going into the combustion
chamber that
it is kicking up the HC an excessive amount.
This last passed emissions 2 years ago and they only got it through by
changing the
plugs and dumping a bottle of alcohol into it. I suspect the converter was
still barely
functioning then.
The only hope is that whoever buys it doesen't notice the oil smoke, but I
can't see how
that would happen, this is losing so much oil now that if you turn the car
off and let it sit
for a minute, then start it, you would have to be blind not to see the smoke
plume.
