Previa oxygen sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-30-2006, 09:42 PM   #1 (permalink)
Fred
Guest
Posts: n/a
View Fred's Photo Gallery
This is my first post on this site
My 91 Previa burns too much fuel and there's a bit of black carbon on
the end of the exhaust pipe. I'm pretty sure I need to replace the
oxygen sensor. My question is do I need to replace both sensors or just
the one on the engine side of the catalytic converter.
Any suggestions for a source for the sensor in Canada? Is a universal 4
wire sensor OK? Prices seem to go from about $25 for a universal 4 wire
to $230 for a Denso with the right plug at the local parts store.
Old 03-30-2006, 10:04 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Previa oxygen sensor
"Fred" <waterrat@island.net> wrote in message
news:1143776578.194006.261990@j33g2000cwa.googlegroups.com...[color=blue]
> the one on the engine side of the catalytic converter.[/color]
The sensor on the engine side of the converter controls fuel mixture. The
sensor after the converter lets the ECU know whether the converter is
working or not.
[color=blue]
>[/color]
Just for grins, why not price the sensor at your local Toyota dealer? It
may be less than the OEM one at the local parts store.
Ray O
Old 03-30-2006, 11:54 PM   #3 (permalink)
Fred
Guest
Posts: n/a
Ray O wrote:[color=blue]
> news:1143776578.194006.261990@j33g2000cwa.googlegroups.com...[color=green]
> working or not.
>[color=green]
> >[/color]
> Ray O
> (correct punctuation to reply)[/color]
Thanks, that gets me down to one sensor to buy
The phone call to the dealer is free, but I think the 4 wire universal
at $25 will be a lot less expensive. It's a Denso, which is the brand
Toyota uses, I think. Any opinions on whether it will work?
Fred8
Old 03-31-2006, 01:06 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
news:1143784484.126854.221970@j33g2000cwa.googlegroups.com...[color=blue]
> Ray O wrote:[color=green]
>> news:1143776578.194006.261990@j33g2000cwa.googlegroups.com...[color=darkred]
>> The
>> working or not.
>>[color=darkred]
>> >[/color]
>> Ray O
> Fred8
>[/color]
Denso is the OEM supplier for Toyota. The 4 wire universal should work, but
if you're going to start snipping wires, I'd snip the connector off of the
old O2 sensor so that you don't damage the wire harness on the vehicle
itself. If the original sensor has only 2 wires, then you have to figure
out which wires are for the heater, sensor signal, and grounds. I have a
factory manual for a 93 Previa that should be OK if you get stuck.
Good luck!
Ray O
BB code is Off
Smilies are Off
[IMG] code is Off
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 11:49 AM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 2 03-30-2006 12:49 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
