1995 toyota camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-01-2006, 10:08 PM   #1 (permalink)
ksidharth@googlemail.com
Guest
Posts: n/a
View ksidharth@googlemail.com's Photo Gallery
1995 toyota camry
HI All
I am buying a used toyota camry, its 1995 make . It has issue with the
relay switch that moves the window. One of the window does not roll
down. any ideas wht could the problem and how much it cost to get it
done? toyota owners..kindly sugest
Old 04-01-2006, 11:06 PM   #2 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: 1995 toyota camry
On 1 Apr 2006 20:08:49 -0800, [email]ksidharth@googlemail.com[/email] wrote:
[color=blue]
>HI All
>done? toyota owners..kindly sugest[/color]
They usually are not too expensive to fix, but you have to track
down the root problem first. This is not difficult, but it is time
consuming and a bit of a logic puzzle. The window rolls down when you
apply power to Terminal 1 of the window motor (and ground to Terminal
2), and it goes up when you reverse the polarity.
But before you do anything else, get a spray can of silicone
lubricant and apply a small amount to the rubber channels that the
windows slide up and down in - if the channels are dry or sticky, you
can burn up a window motor fighting the friction. It only takes a
small amount, and you need to carefully control where it goes, you
might want to squirt a bit on a cotton swab applicator and swab the
lubricant onto the channels with the windows down.
If the 'bad' window rolls down easily but not up (even after
lubrication) this is usually caused by a dirty or burned contact in
one of the switches. The 'Master' switch on the drivers door is
always open - it only applies power and ground to the two wires to the
wires heading to the motor as you push the switch. In other words,
you have to test at the motor terminals both for presence of +12V
power and presence of a chassis ground path, they are both switched.
If the wires are heading to a different door, they pass through a
second switch on that door. If nobody is pushing the remote switch up
or down, the 'master' switch power passes through the remote switch to
the motor - and these contacts can go bad too, meaning the window
motor works fine from the remote door switch but not from the Master.
It's hard to write out - but easy to understand from a picture or a
repair manual. I could draw you a diagram, and then watch that little
"Got It!" light over your head come on. Not Rocket Science at all.
Another common thing to check for on a very high mileage car (but it
sounds like it's not your problem) are bad wires in the door jamb from
the door to the body, where the wires bend every time the door is
opened - if a window only works with one of the doors held halfway or
all the way open, that's your symptom to look for.
Just have to take some time and splice fresh wires into the
high-flex area between the door and body - and then waterproof and
insulate the splices properly so they are not the failure point next
time...
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 04-01-2006, 11:16 PM   #3 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
<ksidharth@googlemail.com> wrote in message
news:1143950929.526839.290150@t31g2000cwb.googlegroups.com...[color=blue]
> HI All
>[/color]
The most common reason that only one power window does not work is either
the master switch on the driver's door or the switch on the door. The
master switch is expensive, perhaps in the neighborhood of $300, the
individual door switch is probably half that. If you are handy, you can try
disassembling the switch and building up the worn connections.
Ray O
Old 04-01-2006, 11:22 PM   #4 (permalink)
Guest
Posts: n/a
Hi Bruce
Thanx a lot for this detailed reply. As I am totally new to the world
of auto, it gives me som eidea abt the proble. I took the car to the
technician. As per the technician, the relay switch, which is there on
the driver seat door needs to be replaced. the switch works fine for
all other three doors, except for the front passenger seat. So it seems
that the motors are working fine and he relay switch is also working
fine for other three doors.
My questions would be:
1) is it possible that there might be some issue with the electrical
circuit? I am asking so because the switch works fine ofor other three
doors. hence the switch moght be just fine, the technician might be
just wanting to make his money by suggesting me a replacement.
2) is it possible to replace just one switch? i understand that there
will be four switches, one for each door, controlled centrally by the
switch at the driver's side? if it is so, then I need to just get that
perticulay switch changed.
Reson why i am asking so is that the technician gave me an estimate of
450 dollars fo rthe repair, including the part replacement. the part is
going ot cost me some 350 dollars..
i just wanted to check out if the part indeed needs to be replaced.
pls let me knwo.
thnx in advance.
Sid
Old 04-01-2006, 11:26 PM   #5 (permalink)
Guest
Posts: n/a
Hi Ray
thax for this. As u hv mentioned, the master switch is expensive and
that what the technician has suggested me to to do. The switch costs
around $325. I was wanting to know if it is possible to replace the
individual door switch. Any idea how much will it cost?
Sid
Old 04-01-2006, 11:46 PM   #6 (permalink)
Ray O
Guest
Posts: n/a
news:1143955602.752876.40040@i39g2000cwa.googlegroups.com...[color=blue]
> Hi Ray
> Sid
>[/color]
Unfortunately, the master switch comes as an assembly - that is, the
switches for the 4 windows, door lock, and window lock come as 1 piece. It
is not possible to replace a part of the master switch.
To answer your question to Bruce, as far as I know, 1995 Camrys are not
known to have wiring harness problems with the power windows.
I think the master switch fails most often if the person who drives it the
most is a smoker or someone who drives with the window cracked open in the
rain, and the rain drips in on the switch. If you are handy, you may be
able to disassemble the switch and build up the contacts with some solder.
Ray O
Old 04-02-2006, 09:57 AM   #7 (permalink)
Ted Mittelstaedt
Guest
Posts: n/a
View Ted Mittelstaedt's Photo Gallery
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:81c8b$442f654f$180fead6$25997@msgid.meganewsservers.com...[color=blue]
> news:1143955602.752876.40040@i39g2000cwa.googlegroups.com...[color=green]
> > Hi Ray
> > Sid
> >[/color]
> switches for the 4 windows, door lock, and window lock come as 1 piece.[/color]
It[color=blue]
> able to disassemble the switch and build up the contacts with some solder.[/color]
Or find one in a wrecking yard.
Ted
BB code is Off
Smilies are Off
[IMG] code is Off
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
CA: For Sale 1995 Toyota Camry LE subie Vehicles 0 11-09-2005 12:47 AM
In hybrids, it's Toyota vs. the world EKam Toyota News 2 03-27-2005 08:04 PM
Toyota Hits Record CDNVITZ General Discussion 0 02-06-2004 01:27 AM
