Checking Check Engine Lamp on '94 Camry V6 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-02-2006, 01:55 PM   #1 (permalink)
jim evans
Guest
Posts: n/a
View jim evans's Photo Gallery
Unfortunately all I have it a Haynes manual for my '94 Camry V6. The
engine lamp has come on. I got out the Haynes to check the diagnostic
code -- no luck.
It begins with an impossible instruction. I says, " . . verify that .
.. . the transaxle is in Neutral." Then it says, "Turn the ignition
switch to ON."
On my car you cannot put the transmission in "Neutral" until the
*AFTER* the ignition switch is on. So, this instruction cannot be
followed.
Assuming the possible order is correct, after the car is in Neutral
(not running) it says to jumper between terminals TE1 and E1 in the
test terminal under the driver's dash.
The Check Engine lamp is supposed to begin to flash. It does not
flash when I jumper these terminals. It stays on constantly, just as
it does when the terminals are not jumpered.
Anyone know what might account for this?
The test terminal illustrated in the manual is the one under the
dash, but it talks about another such test terminal in the engine
compartment. Thinking the dash terminal might be defective, does
anyone know where the one under the hood is located?
jim
NewsGuy.Com 30Gb $9.95 Carry Forward and On Demand Bandwidth
Old 04-02-2006, 03:30 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: Checking Check Engine Lamp on '94 Camry V6
"jim evans" <jimsTAKEOUTnews2@houston.rr.com> wrote in message
news:p460325ars5qramhdl62venrsckph2lkjj@4ax.com...[color=blue]
> code -- no luck.
> switch to ON."
> followed.
> jim
> NewsGuy.Com 30Gb $9.95 Carry Forward and On Demand Bandwidth[/color]
To check codes on your car, jump terminals TE1 and E1 and turn the ignition
to the on position. The shifter position does not have anything to do with
the check. Count the flashes to get the code. When the pattern repeats,
you have all of the codes.
Ray O
Old 04-02-2006, 04:38 PM   #3 (permalink)
jim evans
Guest
Posts: n/a
On Sun, 2 Apr 2006 15:30:58 -0500, "Ray O"
<rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
>news:p460325ars5qramhdl62venrsckph2lkjj@4ax.com...[color=green]
>>[A]fter the car is in Neutral
>> Anyone know what might account for this?[/color]
>you have all of the codes.[/color]
Thanks. As I explained the lamp does not flash when I jumper TE1 to
E1. Nothing happens. The lamp just burns steady as it does if you
don't jumper these terminals.
jim
Old 04-02-2006, 06:01 PM   #4 (permalink)
qslim
Guest
Posts: n/a
View qslim's Photo Gallery
You need to go under the hood, not under the dash. I don't remember its
exact location, but its about 1" by 3", black plastic, and it should say
'diagnostic" on the cover. Jump the terminals in there with the IG on, and
you should be good to go.
Old 04-02-2006, 07:04 PM   #5 (permalink)
jim evans
Guest
Posts: n/a
On Sun, 02 Apr 2006 19:01:54 -0400, "qslim" <Suckers@suckersdotcom>
wrote:
[color=blue]
>'diagnostic" on the cover.[/color]
I can't find the one in the engine compartment. Can someone describe
about where it is?
Something like, near fender on driver's side and near the firewall.
Or . . Near center left to right and near radiator (front). Can be
seen from above or must be accessed from underneath the vehicle, etc.,
etc.
jim
Old 04-02-2006, 09:10 PM   #6 (permalink)
Gord Beaman
Guest
Posts: n/a
View Gord Beaman's Photo Gallery
"qslim" <Suckers@suckersdotcom> wrote:
[color=blue]
>you should be good to go.[/color]
Dunno if it matters or not but you and Ray are giving a different
sequence here...Ray says to jump the connections then turn ign
on...you say the opposite...
-Gord.
(use gordon in email)
Old 04-02-2006, 11:10 PM   #7 (permalink)
Ray O
Guest
Posts: n/a
"Gord Beaman" <gord@islandtelecom.com> wrote in message
news:p0113294spqd4d75c3jmqinb63e6qjpttg@4ax.com...[color=blue]
>[color=green]
> -Gord.
> (use gordon in email)[/color]
The sequence - jump then turn ignition on, or turn ignition on then jump
doesn't really matter. My personal preference is to jump, then double check
the connections, then turn the ignition on so I don't inadvertently jump 2
live terminals.
Ray O
Old 04-03-2006, 12:47 AM   #8 (permalink)
FantomFan
Guest
Posts: n/a
View FantomFan's Photo Gallery
news:ddp032p0p548ib3iajf179ms3bc68rsrp0@4ax.com...[color=blue]
> wrote:
>[color=green]
> about where it is?
> etc.
> jim
On my Corona (96 AT211) it's mounted on the left side of the engine bay (US
drivers side) and visible from the top.
Suggested order is insert jumper then turn ignition, this way you're in the
right place for the first flash.
Old 04-03-2006, 09:19 AM   #9 (permalink)
jim evans
Guest
Posts: n/a
On Mon, 3 Apr 2006 17:47:29 +1200, "FantomFan" <reaper_nz@hotmail.com>
wrote:
[color=blue]
>news:ddp032p0p548ib3iajf179ms3bc68rsrp0@4ax.com...[color=green]
>> wrote:
>>[color=darkred]
>> about where it is?
>> etc.[/color][/color]
[color=blue]
>right place for the first flash.[/color]
Thanks for your reply.
I have two fuse/breaker panels on the left, near the fender about
midway fore-to-aft in the compartment, but I don't see a test panel.
jim
Old 04-03-2006, 10:14 AM   #10 (permalink)
Gord Beaman
Guest
Posts: n/a
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
>news:p0113294spqd4d75c3jmqinb63e6qjpttg@4ax.com...[color=green]
>>[color=darkred]
>> -Gord.
>live terminals.[/color]
Ok, good, you know these electronic gadgets though...sometimes
the sequence is all important...I missed a step once (only once!)
in the procedure to do some function to my very complicated Ham
radio transceiver and accidentally wiped out all my presets that
I had painfully programmed in there a couple years ago...jeez.
-Gord.
Old 04-03-2006, 10:58 AM   #11 (permalink)
Ray O
Guest
Posts: n/a
news:pke2329qftjgbp7of7csha66pcs7hg88cv@4ax.com...[color=blue]
>[color=green]
>>news:p0113294spqd4d75c3jmqinb63e6qjpttg@4ax.com...[color=darkred]
>>>>and
>>> -Gord.
>>check
> -Gord.
To be honest, the reason I followed that sequence is because customers would
get upset if I fried something in the car, and my boss would get upset if
the company had to pay for something I fried.
I remember looking at a customer's truckbed because he wanted Toyota to
cover the rust on the bed seams. It was a snowy day, and he had the usual
build-up of snow behind the rear wheels. I kicked the accumulated snow and
ice off so I could stick my head in and look at the back side of the seam
and told the service advisor and customer that I would authorize the repair.
The customer was happy and left to schedule an appointment with the body
shop, came back 5 minutes later and pointed out that when I knocked the snow
and ice off behind the rear wheel, it pulled the wires out of the rear
corner marker light because the snow and ice had built up around the wires.
Doh! Luckily, it was only an additional $40 to fix the wires.
Ray O
Old 04-03-2006, 08:46 PM   #12 (permalink)
jim evans
Guest
Posts: n/a
On Sun, 02 Apr 2006 13:55:29 -0500, jim evans
<jimsTAKEOUTnews2@houston.rr.com> wrote:
[color=blue]
>code -- no luck.
>flash when I jumper [TE1 to E1]. It stays on constantly, just as
I assume from the replies no one knows why it does not flash the code
when I jumper the designated terminals?
It makes this into a problem. I must take the time off to drive to
the nearest dealer, leave the car, get a ride home, then get a ride
back. All to pay them $50 to spend 5 minutes plugging in a reader,and
writing down the code. Gee.
-- jim
Old 04-03-2006, 10:25 PM   #13 (permalink)
Gord Beaman
Guest
Posts: n/a
jim evans <jimsTAKEOUTnews2@houston.rr.com> wrote:
[color=blue]
>[color=green]
>>code -- no luck.
>-- jim[/color]
C'mon now Jim, why the attutude?, you sound like you think maybe
it's someone's fault that you don't have the equipment (and
knowlege?) to do this for yourself...
-Gord.
Old 04-03-2006, 11:13 PM   #14 (permalink)
jim evans
Guest
Posts: n/a
On Tue, 04 Apr 2006 03:25:46 GMT, Gord Beaman <gord@islandtelecom.com>
wrote:
[color=blue][color=green]
>>when I jumper the designated terminals?[/color]
>knowlege?) to do this for yourself...[/color]
What kind of asshole are you? Just an ordinary dimwit asshole, or a
moderately bright one whose parents never taught her civil behavior?
Now that's attitude. All I was doing in my post was checking to be
sure that no one knows the answer.
-- jim
Old 04-04-2006, 03:12 AM   #15 (permalink)
FantomFan
Guest
Posts: n/a
news:9ib2325u3272hhnblu306874nqd9mktica@4ax.com...[color=blue]
> wrote:
>[color=green]
>>news:ddp032p0p548ib3iajf179ms3bc68rsrp0@4ax.com...[color=darkred]
>>> about where it is?
>[color=green]
>>(US
>>the
> jim[/color]
The one in my car is a smallish rectangle, but I have also seen a reference
to a round connector. They also seem to be mounted in different areas
depending on model. From left side to bulkhead and even on the engine.
The diagnostic sheet I have been looking at for a Celica says to check for
wiring faults to your diagnostic plug if the light fails to flash.
BB code is Off
Smilies are Off
[IMG] code is Off
94 Camry Check Engine Light Code: 71 Check EGR Valve laksh99 3rd & 4th Generation (1992–1996 & 1997–2001) 15 10-29-2011 07:52 AM
Official 2007 Toyota Camry Announcement, Images & Specs EKam Toyota News 1481 05-17-2007 09:50 PM
1990 Camry Check Engine Light Kep Hardcore Tech and Competition 4 05-20-2006 01:15 PM
94' Camry XLE V6 Auto........ cumminspuller 3rd & 4th Generation (1992–1996 & 1997–2001) 18 08-30-2005 04:39 PM
Can u fix up a v6 camry engine??? Celica noob General Discussion 10 05-02-2005 07:44 AM
