I'm stumped. Challenge for tranny experts: Toyota transmission (A140E) slipping in 2nd gear in 'D' and '2' position. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2006, 12:18 AM   #1 (permalink)
eekthorp
Guest
Posts: n/a
View eekthorp's Photo Gallery
Tranny experts,
I have investigated so many things and now I'm wondering what you
tranny experts think could be causing the problem.
The problem is 2nd gear slips in [D] and (slightly less) in [2].. Also
2-3 shift is sometimes delayed and harsh.
This is a 93 camry 4 cylinder w/ 60kmi on a rebuilt A140e tranny.
If anyone has a good suggestion I'll post my result of the fix/test.
fwiw, here are my notes:
Shift feel
1-2: a) normal bump/flair when shifting but 2nd slips.
b) sometimes there's the normal bump, then it seems somewhat in
second, then about 1 second later there's a second more
noticeable 'bump' and it seems it is slipping much more now. This
happens in [D], not sure about [2].
2-3: sometimes delayed and harsh, especially if forced by letting off
gas abruptly.
3-4: perfect
4-3: perfect
2-1: perfect
4-4lockup:perfect
Shifts all seem to occur at reasonable speed/throttle.
Shifting w/ manual lever works like above.
Gear feel
1,3,4,4locked: perfect, no slipping when given lots of torque, etc.
2 in [D]: slips w/ any throttle, very light throttle will allow enough
slow acceleration to eventually get into 3rd.
2 in [2]: Less slipping--Seems to not slip too much if using less than
1/4 throttle. Engine breaking feel seems minimal. Engine speed seems
(only roughly) related to wheel speed (due to slipping?).
2 going from [D] to [2]:
Can't hear/feel one-way deactivating or break activating.
seems to slip slightly less in "2 in [2]".
Is one-way clutch engaged in both?
Maybe air test the break on 2nd's one-way clutch?
The first day it did this it seemed to happen after warming up and
while turning. After tests and extensive road tests 2nd seems to slip
when cold too.
Tests
Torque Converter Stall: passed. (2450RPM at R and D)
Engagement delay test : passed. (N-R < 2 seconds, N-D < 1 seconds.)
Electrical system : passed. Sol1, Sol2, SolL signals from ECM are
good.
Solenoids : passed. Resistance good. 70psi shop air causes
only small leaking at 0V, air rushes with 13V.
DTC : "Code 63--Sol 2 failed" existed when starting
debug, but the sols were tested above to be good.
Throttle cable : passed. Seems 'taught', +1mm and -1mm
adjustment didn't seem to impact slipping 2nd.
Hydrolic : pending.
Flushed full 7qt Fluid: No effect. Original fluid was dark but still
smelled good. No hint of burnt.
Valve Body : Rebuilt it. Looked clean, all balls, seals,
gaskets, valves seemed superficially ok. Paid particular attention to
1-2 Valve. Didn't measure spring tensions. Rebuild didn't seem to
affect 2nd gear slipping.
What do you guys think could cause this slipping?
Anything new I should check?
Anything I checked that I should re-check?
Old 04-03-2006, 01:18 AM   #2 (permalink)
mrdarrett@gmail.com
Guest
Posts: n/a
View mrdarrett@gmail.com's Photo Gallery
Re: I'm stumped. Challenge for tranny experts: Toyota transmission (A140E) slipping in 2nd gear in 'D' and '2' position.
eekthorp wrote:[color=blue]
> Tranny experts,
> This is a 93 camry 4 cylinder w/ 60kmi on a rebuilt A140e tranny.[/color]
Rebuilt tranny after only 60,000 miles?
Why so soon? (Are you the 2nd owner?)
Old 04-03-2006, 01:25 AM   #3 (permalink)
Ronald Matthews
Guest
Posts: n/a
View Ronald Matthews's Photo Gallery
In alt.autos.toyota [email]mrdarrett@gmail.com[/email] wrote:
[color=blue]
> eekthorp wrote:[color=green]
> > Tranny experts,
> > This is a 93 camry 4 cylinder w/ 60kmi on a rebuilt A140e tranny.[/color][/color]
[color=blue]
> Rebuilt tranny after only 60,000 miles?[/color]
[color=blue]
> Why so soon? (Are you the 2nd owner?)[/color]
Given that the car is a 93, it is likely he meant that the 60K is on
the rebuilt tranny.
cordially, as always,
rm
Old 04-03-2006, 01:46 AM   #4 (permalink)
Alan
Guest
Posts: n/a
View Alan's Photo Gallery
eekthorp wrote:
[color=blue]
> adjustment didn't seem to impact slipping 2nd.[/color]
Does the lever on the transmission move as soon as the throttle starts
to move?
Old 04-03-2006, 01:55 AM   #5 (permalink)
johngdole@hotmail.com
Guest
Posts: n/a
View johngdole@hotmail.com's Photo Gallery
You sound like an expert yourself doing all those tests. I don't know
much about these trannys, but just wondering if a marginal #2 shift
solenoid can cause problems that may seem like problms in the #2 brake
or the #1 one-way clutch, such as leaking line pressure. Or it may be
leaking from a seal some where.
2 to 3rd harsh is usually attributed to the accumulator. Of course,
clogged strainer can do that but it will show up in all the gears.
Fill us in when you find the problem. A friend had a slipping OD in a
96. He had to rebuild the tranny, but most of us wouldn't know other
than AAMCO.
> Tranny experts,
> Shift feel
> gas abruptly.
> 3-4: perfect
> 4-3: perfect
> 2-1: perfect
> 4-4lockup:perfect
> Gear feel
> when cold too.
> Tests
> good.
> Hydrolic : pending.
> Anything I checked that I should re-check?[/color]
Old 04-03-2006, 06:18 AM   #6 (permalink)
Gary L. Burnore
Guest
Posts: n/a
View Gary L. Burnore's Photo Gallery
On 2 Apr 2006 23:55:11 -0700, [email]johngdole@hotmail.com[/email] top posted like a
morron and wrote:
[color=blue]
>much about these trannys[/color]
Heh.
gburnore at DataBasix dot Com
How you look depends on where you go.
Gary L. Burnore | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
Official .sig, Accept no substitutes. | ÝÛ³ºÝ³Þ³ºÝ³³Ýۺݳ޳ºÝ³Ý³Þ³ºÝ³ÝÝÛ³
| ÝÛ 0 1 7 2 3 / Ý³Þ 3 7 4 9 3 0 Û³
Black Helicopter Repair Services, Ltd.| Official Proof of Purchase
Old 04-03-2006, 08:24 AM   #7 (permalink)
eekthorp
Guest
Posts: n/a
Alan,
Yes (unfortunately?), the throttle, cables, and lever in the trans all
seem to move togeather nicely.
eekthorp
Old 04-03-2006, 09:50 AM   #8 (permalink)
Comboverfish
Guest
Posts: n/a
View Comboverfish's Photo Gallery
> Tranny experts,
> Shift feel
> gas abruptly.
> 3-4: perfect
> 4-3: perfect
> 2-1: perfect
> 4-4lockup:perfect
> Gear feel
> when cold too.
> Tests
> good.
> Hydrolic : pending.
You are probably leaking fluid pressure at your second brake piston,
which will cause flare-up in 2nd gear and eventual friction disc wear
out. It's difficult to test short of tear down and inspection, because
Toyota only gives you a main line pressure port. You can tap a gauge
in here and compare line pressure in all gears, then look for a small
drop in second when the vehicle is actively slipping.
Toyota MDT in MO
Old 04-03-2006, 10:09 AM   #9 (permalink)
eekthorp
Guest
Posts: n/a
Heh, thanks for the complement. Based on your comments it sounds like
you've been doing this much longer than me.
Does anyone have any suggestions on how to rule out "low #2 break
pressure", "poor 1-2 valve position", or "partially opening #2 Sol"?
It seems theoretically possible that #2 Sol not opening enough
(whatever that means) could cause the 1-2 shift valve to barely open
causing reduced pressure to the #2 brake or #1 one-way clutch, which
may only affect 2nd gear. Maybe someone more familiar can comment if
this type of thing actually happens in practice.
Strainers/filter all looked pristine when I rebuilt the valve body.
Bottom of pan was also fairly clean, but unfortunately there were no
magnets in the bottom.
eekthorp
Old 04-03-2006, 11:20 AM   #10 (permalink)
eekthorp
Guest
Posts: n/a
Does this mean that B2 and the one-way stays active in both 2 in [D]
and 2 in [2]?
Do you feel it would be worthwhile to take the valve body off and test
the piston for leaks with shop air before teardown and inspection?
None of my shop manuals cover replacing pistons. If you know off the
top of your head, is ordering a Toyota shop manual RM322 the
recommended one for overhaul? It would be nice if it also has a diagram
w/ labeled piston input ports and a full hydraulic schematic.
Thanks,
eekthorp
Old 04-03-2006, 03:23 PM   #11 (permalink)
Comboverfish
Guest
Posts: n/a
> and 2 in [2]?[/color]
Second Brake (B2) works along with the #1 one-way clutch (F1) to hold
spinning components in second gear range. B2 is hydraulically
activated in [Drive] 2nd and [Manual] 2nd. F1 grabs on acceleration in
[Drive] 2nd and freewheels on decel. F1 is not truly used in [Manual]
2nd because B1 (the one band in the tranny) is hydraulically activated
to keep the trans in 2nd gear engine braking mode.
[color=blue]
> the piston for leaks with shop air before teardown and inspection?[/color]
Slipping is not likely caused by any of the three accumulators in the
case.
[color=blue]
> w/ labeled piston input ports and a full hydraulic schematic.[/color]
Our online version for the A140E is labelled RM322U, so I guess the
RM322 is the paperback version. You won't find hydraulic schematics in
any of the repair manuals. RM322 offers a description of the unit,
powerflow diagrams, then complete component disassembly. The regular
repair manual covers basic on-car diagnostics and unit removal.
[color=blue]
> Thanks,
> eekthorp[/color]
P.S.
I still think your B2 piston is leaking. If you are slipping in [D]2nd
more than [M]2nd, it could be that the B1 band is slipping also, but
still offering some grabbing force. B1 is just a light duty band. It
is not anchored or designed very sturdily, as it's true intention is to
keep your engine from flaring down to idle during [M]2nd deceleration.
It is probably strong enough to hold for a while, but continued use of
it on a trans whose B2 was slipping would cause it to glaze/wear pretty
fast.
I don't hold the F1 as a likely cause of slippage. It is a metal
roller type one-way clutch, that if it were slipping, would be due to
metal fragmentation. There would be an accompanying noise when it
slipped along with metal in the pan.
Toyota MDT in MO
Old 04-03-2006, 07:11 PM   #12 (permalink)
Guest
Posts: n/a
Thanks Comboverfish. That's good information on this problem, even for
those of us who don't have it.
Since tranny is considered the most sophisticated component in a car,
what do you think for those of us who can disassemble/assemble engines
to try to fix our own trannys? Such as replacing B2 piston, brake
bands, etc.
Does the RM322 provide enough information for a backyard mechanic to do
a complete tear down and rebuild?
Is there a rebuild kit for the A140E?
Comboverfish wrote:[color=blue]
>[color=green]
> > Thanks,
> > eekthorp[/color]
> P.S.
> fast.
> Toyota MDT in MO[/color]
BB code is Off
Smilies are Off
[IMG] code is Off
