Motor and Transmission Mounts - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2006, 12:46 PM   #1 (permalink)
johnpcollinsjr@gmail.com
Guest
Posts: n/a
View johnpcollinsjr@gmail.com's Photo Gallery
Yesterday, while backing my 97 Camry (approx. 74,500 miles) into a
parking space I heard small pops/clicks coming from near the front
right tire every second or so the car was in reverse. Later in the day,
when I was pulling the car out of a spot in reverse, I heard the same
small clicks or pops. I have only heard these sounds when the car is in
reverse. After looking at some of the posts here, I thought it might
be the boot or CV joint. When I took the Camry into a local chain
mechanic, they said that the noise was the engine banging into the
firewall and that the motor and transmission mounts needed to be
replaced. They said that the boots were fine. They said that they
could only replace all these mounts with original Toyota parts. They
quoted me a price of $500 for the parts and $250 for the labor and
asked for a deposit of $200 for the parts. Does their diagnosis and the
price quoted sound right? Should I get a second opinion?
Old 04-03-2006, 01:02 PM   #2 (permalink)
badgolferman
Guest
Posts: n/a
View badgolferman's Photo Gallery
Re: Motor and Transmission Mounts
[email]johnpcollinsjr@gmail.com[/email], 4/3/2006, 1:46:18 PM,
<1144086378.106406.73980@e56g2000cwe.googlegroups.com> wrote:
[color=blue]
> day,
> in
> the
> price quoted sound right? Should I get a second opinion?[/color]
You should get a second opinion also. The dogbone and front motor
mount are relatively easy to replace. The rear one is difficult and
may be worth it to have someone else do it.
I bought motor mounts for my 94 Camry from local and online parts
stores. The two hydraulic ones were aftermarket and cost around $80 or
so. The Toyota dealer replaced the rear one for me using my mount for
something like $100.
Old 04-03-2006, 03:28 PM   #3 (permalink)
Guest
Posts: n/a
To clarify the problem, the Camry makes a couple of popping sounds when
in reverse and only when when being driven counter clockwise in reverse.
Old 04-03-2006, 04:08 PM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
<johnpcollinsjr@gmail.com> wrote in message
news:1144086378.106406.73980@e56g2000cwe.googlegroups.com...[color=blue]
>[/color]
If the engine and transmission is hitting the firewall, you would see dents
in the firewall. I have never seen this happen.
Clicks in reverse may also be caused by aftermarket brake pads
Ray O
Old 04-06-2006, 05:34 AM   #5 (permalink)
NeedforSwede2
Guest
Posts: n/a
View NeedforSwede2's Photo Gallery
In article <1144096111.131390.246860@z34g2000cwc.googlegroups.com>,
[email]johnpcollinsjr@gmail.com[/email] says...[color=blue]
>[/color]
That does sound like a failing CV joint (rather than the boot).
Carl Robson
Car PC Build starts again. [url]http://smallr.com/rz[/url]
Homepage: [url]http://www.bouncing-czechs.com[/url]
BB code is Off
Smilies are Off
[IMG] code is Off
