I've noticed ever since I bought my Corolla new in 2003 that when I'm
driving in wet or rainy conditions, the little red "open door" light starts
glowing, very dimly at first, then brightens gradually, but never gets to
even half as bright as it is when I actually open a door.
I've tried opening and closing all the doors to see if that'd make a dif,
and it didn't.
Where could water be getting in to partially short this circuit? The light
stays on even after I turn off the car and take out the key, which leads to
dead battery concerns... not from that one tiny light, but maybe water could
be partially closing other circuits as well or corroding something it's
never supposed to come in contact with...
Water is collecting somewhere, somehow and grounding the system.
Either something near the switch is getting wet and causing it to ground,
or, worse, it is puddling somewhere.
Look for leaves, foam, etc that could hold water near the switches.
Remember, the switches on a Toyota are switching to GROUND, NOT switching
+12V
"Ernie Sty" <fake_email@yahoo.com> wrote in message
news:rdWdnX3ymMzlKavZnZ2dnUVZ_uWdnZ2d@giganews.com...[color=blue]
> starts glowing, very dimly at first, then brightens gradually, but never
> gets to even half as bright as it is when I actually open a door.
> and it didn't.
> light stays on even after I turn off the car and take out the key, which
> leads to dead battery concerns... not from that one tiny light, but maybe
> water could be partially closing other circuits as well or corroding
> something it's never supposed to come in contact with...
>[/color]
More likely it is grounding a door post switch that indicates open door
mike hunt
> and it didn't.
>[/color]
> and it didn't.
>[/color]
I had a similar problem but not with an automobile. Bad solenoid. Whole
circuit board had to be replaced.
On Fri, 7 Apr 2006 13:50:32 -0500, "Ernie Sty" <fake_email@yahoo.com>
wrote:
[color=blue]
>and it didn't.
>[/color]
Someone I know had a similar problem. It apparently stemmed from the
aftermarket alarm that it had. The aftermarket one was faulty enough
that it was "bleeding" electricity into the door sensor causing the
door open light to glow slightly. We removed it and that fixed the
problem.
> and it didn't.
>[/color]
As Viperkiller suggested, check any aftermarket accessories and equipment
very carefully, particularly alarms and remote starters.
Another possibility is that the rubber boot on one of the door light
switches is torn or not positioned properly, letting water into the switch
or connections.
