Landcruiser 100 TBelt Light reset - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-07-2006, 03:46 PM   #1 (permalink)
Keith
Guest
Posts: n/a
View Keith's Photo Gallery
Hi Guys just done my cambelt on my Landcruiser Amazon 4.2 td 1999 can anyone
tell me how to turn off the Tbelt warning light please.
Keith
Old 04-08-2006, 11:45 AM   #2 (permalink)
Huw
Guest
Posts: n/a
View Huw's Photo Gallery
Re: Landcruiser 100 TBelt Light reset
Keith wrote:[color=blue]
> anyone tell me how to turn off the Tbelt warning light please.
> Keith[/color]
a) With ignition turned ON, using the trip switch (select/reset button)
change the display to ODO, and turn the ignition OFF
b) While pressing the trip switch, turn the ignition switch ON and hold it
for 5 seconds.
c) Release the trip switch, then press the switch again within 5 seconds.
d) The digital display should change to T-belt mode. The initial display
"15" (0,000km) is displayed (ie. 150,000km).
2. REWRITING REPLACEMENT VALUES
While in the T-Belt mode, each press of the trip switch will change the
displayed value by 10,000km increments. Once " 20 " (200,000km) is reached
the display reverts back to " 1 " (10,000km) again. Remember, this setting
is the number of kilometres to be travelled before the light comes on next,
and once reset this counter will start from zero.
I believe the timing belt interval for all the 100 series engine variants is
150,000km, but this should be checked against each different markets
servicing recommendation. This being the case, you shouldn't need to change
from the default setting of "15".
Obviously for the US, the ODO is in miles, and I guess the T-Belt warning
would be set in 10,000 mile intervals.
3. T-BELT WARNING RESET COMPLETION
a) After setting the replacement setting value, hold the trip switch ON for
more than 5 seconds then release the switch.
b) Check that the display has now changed back to ODO and that the warning
light has gone off when the engine is started.
NOTE: If the T-Belt mode is completed, even though the belt replacement has
not been performed, the T-Belt warning IS reset.
This is from [url]http://www.lcool.org/technical/100_series/timing_belt_reset.htm[/url]
Huw
Old 04-08-2006, 01:52 PM   #3 (permalink)
Keith
Guest
Posts: n/a
Thanks Haw your a star. I owe you one mate.
Best Wishes
Keith
"Huw" <hedydd[nospam]@tiscali.co.uk> wrote in message
news:49q7luFq4au9U1@individual.net...[color=blue]
> Keith wrote:[color=green]
>> Keith[/color]
> for 5 seconds.
> next, and once reset this counter will start from zero.
> is 150,000km, but this should be checked against each different markets
> change from the default setting of "15".
> for more than 5 seconds then release the switch.
> has not been performed, the T-Belt warning IS reset.
> This is from
> Huw
>[/color]
Old 04-08-2006, 02:14 PM   #4 (permalink)
Huw
Guest
Posts: n/a
> Best Wishes
> Keith
>[/color]
Large quantities of hard currency is always appreciated ;-)
Huw
BB code is Off
Smilies are Off
[IMG] code is Off
Consumer Reports on HID Phi General Discussion 28 01-17-2007 08:23 PM
what do u guys think? Geius Maniacal 89-95 Toyota Pickup/Hilux 33 05-26-2006 02:45 PM
2005 Gen 5 airbag light reset awfang1979 5th & 6th Generation (2002-2006 & 2007-2011) 2 03-01-2006 01:23 PM
Silver Streak: Airbag light reset help! EKam Camry & Solara Lounge 3 08-03-2001 03:13 PM
Just reset my airbag light.... Silver Streak Camry & Solara Lounge 16 07-20-2001 08:38 AM
