Re: help with echo rear wheel hub removal
Thanks;
The bolts from the back go through the axle mount, then the backing plate,
and thread into the cast iron bearing housing. Does the cap at the back need
to be removed to get it out? removing nut or whatever?
Has anyone been successful in rebuilding one of these rather then spend
($259. each).
"qslim" <Suckers@suckersdotcom> wrote in message
news:62e41279a9462298792691305b069daa@localhost.talkaboutautos.com...[color=blue]
> I'm trying to picture it, and I think you may be in the wrong place. The
> bolts on the back are for the drum backing plate. Toyotas rear bearings
> bolt in from the front. If you take the drum off and shine a light through
> the holes in the hub flange, you should see four bolts. I'm pretty sure
> those are the hub fasteners.
>[/color]
