Re: Handbrake problem
"FP" <ad@pottnerconsulting.ca> wrote in message
news:1144643858.567569.182490@z34g2000cwc.googlegroups.com...[color=blue]
> While I was putting my summer tires on my 95 Tercel I noticed I could
> turn one of my back wheels even though the handbrake was pulled tight,
> the other wheel was not moveable.
> Took the covers off the brakes to be able to compare one side to the
> other. On the side that does not work the lever to which the brake
> cable is attached is always in a forward position (as if you had the
> handbrake pulled). Completely disassembled the broken side, the lever
> can be moved with my baby finger however I really have to pull on the
> brake cable to get it to come all the way out.
> Tried spraying some WD40 on it, made it a bit better but still need to
> pull fairly hard.
> Does that mean I need to replace that brake cable?[/color]
I think you're answered your own question there. If the lever moves freely
but the cable does not, then the cable is probably binding.
[color=blue]
> If so should I replace both at the same time?[/color]
Since brake cables are usually not all that expensive, I would replace both.
[color=blue]
> I can get at all parts except where the 2 brake cables hook up to a Y
> thing from which 1 cable goes to my handbrake. This Y thing is above a
> heat shield under the centre of my car. I can't figure out how to
> remove the heat shield, looks like it's riveted on there. I assume I'm
> not the first person that needs to replace a brake cable and generally
> I can easily get at parts, a beautiful Toyota feature, so what am I
> missing to be able to get at this Y thing?
>[/color]
You can drill out the rivets on the heat shield and re-rivet or attach with
a screw and nut. Another possibility is to release the cable from the lever
to gain enough slack to pull it back to where you can reach the Y thing.
Ray O
