<PMontalvo6@gmail.com> wrote in message
news:1144645688.932912.32120@e56g2000cwe.googlegroups.com...[color=blue]
> Does any body know an easy way to get the oil filter off this car?
> Every time I've done it that has been the hardest part.
>[/color]
Why, yes, it certainly is!
Not only is the filter in tough place to begin with, the damn engine is
sideways to boot!
If you don't have an old belt, go and buy a cheap leather belt. Wrap the
belt around the filter so that when you pull the belt, it will loosen the
filter. If you wrap it enogh times you can just pull and it will either come
out with the belt or fall to the ground.
[email]PMontalvo6@gmail.com[/email] wrote:[color=blue]
> Every time I've done it that has been the hardest part.[/color]
My Toyota dealer (and I suppose, any competent auto parts store) has a
oil filter cup that fits on the end of the filter and attaches to a
ratchet extension. It's a snap to remove the filter.
Most likely you are tightening the filter too tightly, when you install a
new filter, if you can not remove it with a filter tool.
mike hunt
>[/color]
On Mon, 10 Apr 2006 12:56:08 GMT, "Travis Jordan" <no.one@no.net>
wrote:
[color=blue]
>PMontalvo6@gmail.com wrote:[color=green]
>ratchet extension. It's a snap to remove the filter.[/color]
The cup wrenches work like a charm, except for one _little_ detail
you need to be aware of before you buy it - there are dozens of
different sizes of cup wrench for the different diameters and patterns
of gripping flutes on the bottom of the filter can, they are not
standardized between brands.
Go to the parts store and get your replacement oil filter and the
cup wrench that fits, but you may have trouble getting off the old oil
filter with the cup wrench if it's a different brand.
They do make a 'universal cup wrench' that has sliding teeth on arms
(think a kitchen jar lid remover gizmo from the '50's) but they are
meant for removal of old filters only. The teeth will scar the filter
can to the point it may puncture, or the scars could rust through the
steel of a new filter and leak before the next filter change.
There's also a premade strap wrench that has a nylon belt on an arm,
they work in tight spots but not nearly as easy as the cup style.
They'll only break it loose or tighten the new one, you still need to
get an arm in there to remove/replace the filter.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
I think perhaps the OP is a little more concerned with the *location* of the
filter, more than what to use.
My take, anyway.
I have a similar engine in my "Hachiroku" and the location of the filter is
a Biotch in a Longitudinally mounted postion, let alone transverse and
stuffed into a tiny engine bay in the rear of the car!
My take, anyway!
"Bruce L. Bergman" <blPYTHONbergman@earthlink.invalid> wrote in message
news:b00l32lved60nmm30qlj510tddkj3vu8vl@4ax.com...[color=blue]
> wrote:
>[color=green]
>>PMontalvo6@gmail.com wrote:[color=darkred]
> --<< Bruce >>--
> Spamtrapped address: Remove the python and the invalid, and use a net.[/color]
He has a similar engine to what's in my GTS, and you can put the damn
filters on *FINGER* tight, and when you go to take it off it's like King
Kong put the damn thing on!
"Mike Hunter" <mikehunt2@mailcity.com> wrote in message
news:epCcnc4GFfq4H6fZUSdV9g@ptd.net...[color=blue]
> mike hunt
> news:1144645688.932912.32120@e56g2000cwe.googlegroups.com...[color=green]
>>[/color]
>[/color]
"Hachiroku" <Trueno@ae86.GTS> wrote in message
news:egy_f.3464$ee6.1623@trndny01...[color=blue]
>the filter, more than what to use.
> My take, anyway.
> is a Biotch in a Longitudinally mounted postion, let alone transverse and
> My take, anyway!
>[/color]
The sales manager at one of the dealers I used to call on raced one in
showroom stock. His "expert race-trained mechanic" changed the oil prior to
a race, and double-gasketed the oil filter. The oil spewing out got on the
exhaust and caught fire, and a photographer that attends races to take
pictures to sell to the drivers got a beautiful photo of the car head on
with flames coming out from the back half of the car.
The sales manager was screaming lawsuits unless Toyota replaced his car, so
I drove up to the dealership, had the service department put it up on a
rack. With the service manager, dealer principal, and sales manager
standing there, I pointed out the oil all over the under carriage, and was
able to remove the aftermarket oil filter without any tools. Of course no
oil came out, but 2 aftermarket oil filter gaskets did come off.
On Mon, 10 Apr 2006 14:41:28 -0500, Ray O wrote:
[color=blue]
> news:egy_f.3464$ee6.1623@trndny01...[color=green]
>> My take, anyway.
>> My take, anyway!
>>[/color]
> oil came out, but 2 aftermarket oil filter gaskets did come off.[/color]
Why in hell would someone who works for Toyota use anything but Toyota
filters?
Or anyone else for that matter?
In the grand scheme fo things...
What difference does it make?
[color=blue]
>> My take, anyway.
>> My take, anyway!
>>[/color]
And, uh, considering your territory, which one would that be? :)
news:LCA_f.2109$s77.312@trndny09...
<story snipped>[color=blue]
> filters?
>[/color]
Good question, especially since the service and parts department at the
dealership where he worked was one of the better ones in the Boston metro
area.
news:6IA_f.3473$ee6.1769@trndny01...
<snipped>[color=blue]
>[/color]
I'll protect the names of the guilty but it wasn't in western MA ;-)
Over the years in New England, I had District 3 (MA west of 495 and north of
the Mass Pike, northern NH and VT); then after re-districting, the new
District 3 (all of MA west of 495 and northern RI), and District 1 (Boston
metro inside 495) as a district service manager. I had District 3 as a
District Manager, and the entire Boston Region (RI, MA, NH, VT, & ME) as a
service development consultant.
"Ray O" <rokigawa@tristarassociatesDOTcomn> wrote in message
news:e433f$443b35ce$180fead6$29379@msgid.meganewsservers.com...[color=blue]
> <snipped>[color=green]
>>[/color]
> of the Mass Pike, northern NH and VT); then after re-districting, the new
> Ray O
> (correct punctuation to reply)[/color]
Sure you aren't a Politician? You sure got on your bike fast!
news:pgN_f.3585$yg2.2672@trndny02...[color=blue]
> news:e433f$443b35ce$180fead6$29379@msgid.meganewsservers.com...[color=green]
>> <snipped>[color=darkred]
>>>[/color]
>> (Boston metro inside 495) as a district service manager. I had District
>> 3 as a District Manager, and the entire Boston Region (RI, MA, NH, VT, &
>> ME) as a service development consultant.
>> Ray O
> Sure you aren't a Politician? You sure got on your bike fast![/color]
Naw, I'd rather not burn any bridges (no pun intended) ;-)
He's right with the thing about tightening the oil filter finger tight.
When you try to get your arm in their it is very hard to take off.
The tools don't really fit cause there is hardly any room.
