Re: Foam in oil 98 Camry
It sounds as though you need a new head gasket. You should get it
looked at immediately.
On Mon, 10 Apr 2006 23:30:50 -0500, "Ray O"
<rokigawa@tristarassociatesDOTcomn> wrote:
[color=blue]
>"Dino" <dean1646@aol.com> wrote in message
>news:1144702452.326625.218360@g10g2000cwb.googlegroups.com...[color=green]
>> Thanks for the input! I noticed the foam in the oil I drained out
>> yesterday...(the reason for my post) It was not excessive or milkshake
>> like. Just a thin layer of foam. ( the engine was cool when it was
>> drained) My wife drove the car about 50 miles and I drained the oil
>> with no foam present (Engine was at operating temp) and refilled it.
>> Have I over reacted? As stated, I change the oil every 3K miles
>> religiously without ever noticing any foam.
>> The car starts like a champ doesn't appear to have any blue
>> smoke...coolant level seems consistant. I can hardly tell when its
>> running because it idles so nicely.
>> How long would it take to ruin an engine in the manner I described
>> above? (running with no coolant)Thanks again!
>>[/color]
>If coolant was getting into the oil, 50 miles is probably not enough for it
>to be detectable.
>If there are no other symptoms, you're probably OK. Just keep an eye on the
>oil and coolant levels and appearance.
>It would not take very long to ruin an engine without coolant, probably
>under 5 minutes.[/color]
