Corolla Verso 2004 fusebox location please? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2006, 07:20 AM   #1 (permalink)
bobthebuilder999@hotmail.com
Guest
Posts: n/a
View bobthebuilder999@hotmail.com's Photo Gallery
I'm looking for the one that cointains the cigarette lighter fuse -
I've found all the others!
Thanks
Old 04-10-2006, 11:18 AM   #2 (permalink)
Bruce L. Bergman
Guest
Posts: n/a
View Bruce L. Bergman's Photo Gallery
Re: Corolla Verso 2004 fusebox location please?
On 10 Apr 2006 05:20:33 -0700, "bobthebuilder999@hotmail.com"
<bobthebuilder999@hotmail.com> wrote:
[color=blue]
>Thanks[/color]
The cigarette lighter is usually fused with a few other items, like
the clock or the dome lights. If everything else works, remove the
lighter socket itself and check for power at the connection.
The lighter socket has a thermal fuse built in at the back, meant to
pop if someone forces the lighter element in to stay on past the
normal 'pop out' point, before it gets hot enough to catch the car on
fire. It will also pop if you run an inverter or 12V coffeepot
through the lighter socket, too much current for too long.
You replace the whole socket assembly - the 'cup' and the screw
shell that holds it in place are readily available at parts stores.
And if you run an inverter or large 12V powered items regularly,
they also sell 'Accessory Power' sockets meant for the duty - wire it
direct to the car battery per the included instructions.
--<< Bruce >>--
Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop
Electrician for Westend Electric - CA726700
5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545
Spamtrapped address: Remove the python and the invalid, and use a net.
Old 04-10-2006, 11:48 AM   #3 (permalink)
Guest
Posts: n/a
The manual indicates that there is a seperate fuse for the lighter, so
I need to check that first, assuming I can find it.
BB code is Off
Smilies are Off
[IMG] code is Off
02 Corolla Oil Filter location? lrsackville Archived Corolla threads 1 10-23-2005 04:53 PM
2004 Corolla engine rattle when warming up abeg9 Archived Corolla threads 3 01-19-2005 07:12 PM
JBL Amp Location on 2005 Corolla? Sonnie Audio, Video, and Security - Tech 6 12-14-2004 02:59 PM
Is there a specific name for the corollas??? balch104 Archived Corolla threads 30 11-23-2004 04:01 PM
Need help with 2004 Corolla Xenon Bulbs jay_da_man Archived Corolla threads 2 09-15-2003 06:11 PM
