odometer/speedometer problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2006, 12:20 PM   #1 (permalink)
beastech
Guest
Posts: n/a
View beastech's Photo Gallery
It will go up to about 30 mph and thats it. Is this something that is
expensive to get fixed? I don't own the car with this problem but I'm
thinking about buying it.
Thanks
Old 04-10-2006, 12:39 PM   #2 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: odometer/speedometer problem
"beastech" <brittbottoms@gmail.com> wrote in message
news:1144689647.380392.195840@i40g2000cwc.googlegroups.com...[color=blue]
> Thanks
>[/color]
Assuming that the car is actually going over 30 MPH, there are several
possible causes for a speedometer that does not indicate correct speed.
Depending on the year and model, it may have a mechanical or electronic
speedometer. Possible causes are bad speedometer drive gear or speed
sensor, bad drive cable or speedometer wire harness, bad speedometer head.
Ray O
Old 04-10-2006, 01:18 PM   #3 (permalink)
beastech
Guest
Posts: n/a
Wow, I can't believe I forgot to say what model/year the car is! Sorry
about that. Its a 85 Celica GT-S.
Old 04-10-2006, 02:16 PM   #4 (permalink)
Hachiroku
Guest
Posts: n/a
View Hachiroku's Photo Gallery
I'd sell it.
Unfortunately, not knowing what make or model, I wouldn't be inclined to buy
it.
Or know how to fix it, either...
> Thanks
>[/color]
Old 04-10-2006, 05:01 PM   #5 (permalink)
Hachiroku
Guest
Posts: n/a
On Mon, 10 Apr 2006 11:18:22 -0700, beastech wrote:
[color=blue]
> about that. Its a 85 Celica GT-S.[/color]
OK.
NOW do you want to sell it?
Do you want to buy one?
I have a Midnight blue metallic, with minimal rust, the exception being
the crossmember under the radiator is almost through.. :(...
It has a 91 engine with 165,000.
It goes to the scrap heap very soon. I'll get $175 for it.
I paid $450 to get the motor and get it in.
I'd rather see someone use it for parts rather than just crush it.
5-speed, everything works. Everything that's in the car of course. The Ac
was removed before I bought it.
One of my favorite cars.
In the grand scheme fo things...
What difference does it make?
Old 04-10-2006, 09:57 PM   #6 (permalink)
beastech
Guest
Posts: n/a
I appreciate the offer, I really do. I'm looking into buying the
specific one in my original post because it is a convertible.
I hope you find someone who will take it off your hands, a Celica
getting crushed like that breaks my heart. What city/state/country are
you in? I may know someone who would be interested.
Old 04-11-2006, 07:25 AM   #7 (permalink)
Hachiroku
Guest
Posts: n/a
Re: odometer/speedometer problem (a possible answer, too)
news:1144724229.573650.313540@v46g2000cwv.googlegroups.com...[color=blue]
>[/color]
I don't want to see it go, either. I have a Corolla GTS, a Supra and the
Celica GTS, and after the Corolla the Celica was my favorite. I actually
like driving it better than the Supra!
I'm in Massachusetts.
I don't blame you for wanting a conv!
This car has a mechanical speedo. There are two ways to check it:
What I do is I pull the instrument cluster, and then look for an Allen type
bit that will fit my drill and fit the fitting on the inst panel.
I have found my drill does about 58MPH... I can't remember which direction
to spin the thing in, but going backwards won't hurt it.
If you get a reading on the meter, then the next thing to look at is the
cable. Some Toyotas are notorious for breaking Speedo cables; I know the
Supra is one, and some older Corollas, too. Check where the cable runs from
the firewall to the Trans to see if the cable is kinked, frayed or damaged;
also look at the 'elbow' where it joins the tranny. The elbow is actually
the worst place for
these things; sometimes the bend is too sharp and the piece inside breaks.
After that, there is the gear inside the tranny itself. It may be worn or
damaged. I don't know how to look at this on this car; as nice and as well
made as Toyotas are, on some models you have to drop the tranny to get
access to this gear!
Good luck. Now you've got me thinking about my Celica again and what a blast
it was to drive. All it needs is $300...
(on top of the $900 I have already put into a $200 car; every time I fix one
thing, something else breaks!!!)
Old 04-12-2006, 11:51 AM   #8 (permalink)
beastech
Guest
Posts: n/a
Thanks Hach, I'm going to print this out and run it by my father. (He
used to work on my original Celica years ago) and see if it will be
worth the effort.
Old 04-13-2006, 03:30 PM   #9 (permalink)
Hachiroku
Guest
Posts: n/a
news:1144860705.780481.167880@i39g2000cwa.googlegroups.com...[color=blue]
> worth the effort.
>[/color]
One thing I forgot; the speedo is actually (IIRC) a 'spring' and like all
clock type springs can develop problems.
I think I am going to wind up scrapping my GTS (The Celica, that is!)
If this happens, I can pull the instr. cluster and send it to you. There are
two minor problems:
The temp gauge sometimes dances a little jig; it goes up and down and up and
down ,then settles for a while.
From what I understand, this is common on this model; you can always pull
the gauge on yours and swap them.
Sometimes one of the bulbs goes out; the upside is that a good rap on the
side of the cowl solves both this and the gauge problem!
I am mildly toying with the idea of trying to eek another 12,000 miles or so
out of this car; it rerally is one of my favorites; I'm just waiting for the
next shoe to drop...
Old 04-28-2006, 03:53 PM   #10 (permalink)
beastech
Guest
Posts: n/a
This sounds like it might be out of my league to fix. How much do you
think it would cost for a mechanic to repair it?
Hach, do you still have that Celica? If so I have a buddy in need of a
car and I think I can get him to cough up 200 bucks if your up for it.
He just needs to know if it can make a trip from Massachusetts to
Georgia. If so I'm willing to bet he will come and pick it up. That
is if you are still looking to sell it that is.
Old 04-28-2006, 05:00 PM   #11 (permalink)
Ray O
Guest
Posts: n/a
news:1146257617.579181.52100@j33g2000cwa.googlegroups.com...[color=blue]
> think it would cost for a mechanic to repair it?[/color]
I don't remember what year and type of vehicle you have, but if it is a FWD
Celica, the speedo cable is easy to disconnect and inspect. Follow the
cable to the transmission and unscrew the cap where it goes in.
Ray O
Old 04-28-2006, 06:28 PM   #12 (permalink)
Hachiroku
Guest
Posts: n/a
On Fri, 28 Apr 2006 13:53:37 -0700, beastech wrote:
[color=blue]
> is if you are still looking to sell it that is.[/color]
I do...it needs work before it can make a trip that far.
Needs a new strut (I'd do 2) and some welding...
Old 05-07-2006, 08:36 AM   #13 (permalink)
beastech
Guest
Posts: n/a
How much do you think those repairs would cost? He is very interested
as long as we can get it to make that trip. Also, would it be possible
fo you to email me a picture of the car?
Thanks again.
BB code is Off
Smilies are Off
[IMG] code is Off
Electric problem! Please help!! 1987SR5 Pre-88 Toyota Pickup/Hilux 2 12-02-2005 09:58 AM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
